Old 10-12-2013, 07:26 PM   #1
SnowDuner02
Member#: 360519
2002 Impreza wrx
Midnight black pearl
Default What year or kind of pinks are these struts
Both are supposed to be Sti pinks. The left were on my car and the right I got fr feel suspension. They both are front right strut. Why do they look different
SnowDuner02 is offline   Reply With Quote
Old 10-12-2013, 11:50 PM   #2
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
The one on the left is a rear.
GDR is offline   Reply With Quote
Old 10-13-2013, 02:23 AM   #3
SnowDuner02
Member#: 360519
2002 Impreza wrx
No it was on the front passenger
Old 10-13-2013, 02:50 AM   #4
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Just because that's where it was, does not mean that's where it's supposed to go.
Bikelok is offline   Reply With Quote
Old 10-13-2013, 03:47 AM   #5
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
^^+1... that left one is a rear...
Zefy is offline   Reply With Quote
Old 10-13-2013, 11:21 AM   #6
SnowDuner02
Member#: 360519
2002 Impreza wrx
Okay so the right one all 4 look like that is that normal
Old 10-13-2013, 11:49 AM   #7
jam007
Member#: 174706
2008 LGT-B
The right strut (black) are fronts, throw pics up of all the struts you have that you are concerned about. Also google the p/n's on the struts that can help too.
jam007 is offline   Reply With Quote
Old 10-13-2013, 12:02 PM   #8
alx8283
Member#: 225024
2002 wrx
I agree with everyone else, black strut is front, cherry blossom red (aka the color of the warrior ) is rear. Here are some pics of the bases of a front 02-07 spring and a rear 04-07 spring if it helps.
Front
Rear
alx8283 is offline   Reply With Quote
Old 10-13-2013, 12:15 PM   #9
SnowDuner02
Member#: 360519
2002 Impreza wrx
Well the right are just spray painted black and pink underneath. I'll get pics of what are the rears later on
Old 10-13-2013, 12:47 PM   #10
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
It should be stamped on the strut which position it is. The JDM pink struts I had on my 04 were all labeled / stamped - LF, LR, RF, or RR.
MD04WRX is offline   Reply With Quote
Old 10-13-2013, 12:55 PM   #11
Bikelok
Member#: 254851
2002 WRX wagon 5mt
OP, if someone mounted a rear strut on the front of your car, they may be some other shenanigans and hijinks going on. Someone either did not know what they were doing or just threw it on because it fit.
Take a good look around your car and make sure things seem right. Ask for some help too if you are not familiar with how things are supposed to look.
On a side note, those Feals are NICE!!!
Old 10-13-2013, 01:50 PM   #12
SnowDuner02
Member#: 360519
2002 Impreza wrx
Okay I'll check my pinks when I get home so check back tonight around 7 I'm working now
Old 10-13-2013, 01:51 PM   #13
SnowDuner02
Member#: 360519
2002 Impreza wrx
Thanks I will look around . Have all feals installed already they are nice
Old 10-13-2013, 03:02 PM   #14
Bikelok
Member#: 254851
2002 WRX wagon 5mt
OP, how was the stock camber bolt installed in that rear strut? I don't think it would fit without drilling out one of the top holes. I'm baffled as to why someone would do that.
Does the car still have the stock, lobbed front upper camber bolt? Or did they just throw a regular straight bolt in the top front hole?
Old 10-13-2013, 03:40 PM   #15
SnowDuner02
Member#: 360519
2002 Impreza wrx
My pinks 2 say RH and 2 say LH
Old 10-13-2013, 03:41 PM   #16
SnowDuner02
Member#: 360519
2002 Impreza wrx
I didn't look at that I will have to look
Old 10-13-2013, 08:48 PM   #17
SnowDuner02
Member#: 360519
2002 Impreza wrx
Top hole had the camber bolt and bottom hole had regular bolt. It was like that on all 4 struts
Old 10-13-2013, 08:56 PM   #18
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I don't mean to sound like a smart a**, but can you tell if the front top camber bolt is a stock one and not an aftermarket one? It's very important that only a stock camber bolt goes in the front top. Aftermarket ones are not strong enough for that location.
Did you install the rear camber bolt or the previous owner? There were no camber bolts stock in the rear.
Old 10-13-2013, 11:19 PM   #19
SnowDuner02
Member#: 360519
2002 Impreza wrx
Yeah they were stock camber bolts and I checked out and they were only on the feont
Old 10-14-2013, 12:45 AM   #20
Bikelok
Member#: 254851
2002 WRX wagon 5mt
That's good.
Old 10-14-2013, 02:10 AM   #21
SnowDuner02
Member#: 360519
2002 Impreza wrx
That's good.
So back to my beginning question my car had 4 rear struts installed than?
Old 10-14-2013, 02:15 AM   #22
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Post a picture of them, but it seems so.
Old 10-14-2013, 02:20 AM   #23
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
i'm not sure it's physically possible to install rear struts on the front without modifying them excessively.
For instance, those camber bolts on the front won't fit in the rear struts. I also don't think that the top mounts will fit...
But ya.... like Bikelok said... we won't know until we see them... so take a pic...
A full set should look like this... Fronts are on the left, rears on the right.
Old 10-14-2013, 02:34 AM   #24
SnowDuner02
Member#: 360519
2002 Impreza wrx
Well 2 are shorter then the other 2
As you can see in pics. I just don't see why where the springs seats on is different then the other u have all showed me
Old 10-14-2013, 05:53 PM   #25
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I'm not an STI strut expert, but they look like they may be an older V6 or V7 type STI strut.
The newer versions front spring perch have a taller lip and have holes along the perimeter.
