Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-11-2013, 05:27 AM   #1
QuintonCheng
Member#: 369578
2008 Subaru WRX STi
Exclamation Tein Monoflex Preload issues! Emergency!
Hello guys,
I just got the Tein MonoFlex Kit for my 08 STi. There are A LOT of problems of setting. I've already put those on my car without preload them. So it's kinda urgent!!! The problem is I DON'T know how to adjust them at all. Like the camber, ride height, spring rate. What measurements should I set? I just wanna be a little be lower then stock ride height. The front and rear should be equal or not? Thanks for answering!!!
QuintonCheng is offline   Reply With Quote
Old 10-11-2013, 01:56 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
read the directions that came with them. put a little preload on them and adjust the bodys into the flange mounting. or just post up pics, or did you have these installed by a pro? if so have them adjust them
PARANOID56 is offline   Reply With Quote
Old 10-11-2013, 01:59 PM   #3
Dakota D
Member#: 293894
2006 wrx sti
cgm
There should be preload settings in your intructions.edit previous member said that sorry!
Dakota D is offline   Reply With Quote
Old 10-11-2013, 02:02 PM   #4
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Research
Buy
Install
In that order
Old 10-11-2013, 02:07 PM   #5
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Fire! Aim! Ready!
bushflyr is offline   Reply With Quote
Old 10-11-2013, 02:19 PM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Call the vendor whom you used for the purchase. After sale support is one of the reasons they are there.
Old 10-11-2013, 07:34 PM   #7
QuintonCheng
Member#: 369578
2008 Subaru WRX STi
I got the manual from Tein today. And I will just set those measurement as Tein said. By the way, really don't recommend the Tein monoflex+EDFC kit. If you set a lower ride height the motor of EDFC will be expose but it should be covered by the cylinder(the front motors are settled at the bottom).
Old 10-14-2013, 01:02 PM   #8
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
yes the beauty of inverted design!
the rear is way easier to adjust from the bottom because you don't have to take out the back seat every time (at least with the GD)..
KIMUTAKU is offline   Reply With Quote
