Welcome to the North American Subaru Impreza Owners Club Friday August 29, 2014
Old 04-19-2013, 03:42 PM   #1
XSV Klutch
Member#: 259013
2007 Impreza 2.5i
greyish
Default Help!!
2007 2.5i this is the code that i got. plugged in the green connectors, is their something else i need to plug in?
[13:31:58.675] EcuFlash Version 1.44.3721
[13:31:58.675] OS Version Windows 7
[13:31:58.675] Qt Version 4.8.0
[13:31:58.680] 63 memory models read.
[13:31:58.680] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[13:31:58.770] 611 ROM metadata models scanned.
[13:31:58.770] checksum module "subarudbw" loaded.
[13:31:58.770] checksum module "mitsucan" loaded.
[13:31:58.770] checksum module "mitsuh8" loaded.
[13:31:58.770] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[13:31:58.770] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[13:31:58.771] flashing tool "wrx02" loaded.
[13:31:58.772] flashing tool "wrx04" loaded.
[13:31:58.774] flashing tool "sti04" loaded.
[13:31:58.775] flashing tool "sti05" loaded.
[13:31:58.775] flashing tool "mitsukernel" loaded.
[13:31:58.775] flashing tool "mitsukernelocp" loaded.
[13:31:58.775] flashing tool "mitsubootloader" loaded.
[13:31:58.775] flashing tool "shbootmode" loaded.
[13:31:58.775] flashing tool "shaudmode" loaded.
[13:31:58.776] flashing tool "subarucan" loaded.
[13:31:58.777] flashing tool "subarucand" loaded.
[13:31:58.778] flashing tool "mitsucan" loaded.
[13:31:58.779] error loading FTD2XX.DLL
[13:31:58.802] J2534 API Version: 04.04
[13:31:58.802] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:31:58.802] Device Firmware Version: 1.12.3688
[13:31:58.802] Device Serial Number: TAX$5Jsc
[13:31:58.805] interface close
[13:32:03.833] J2534 error [ERR_TIMEOUT].
[13:32:03.834] J2534 error [unable to open device].
[13:32:19.833] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[13:32:19.837] J2534 error [unable to open device].
[13:32:19.837] unable to connect to vehicle interface.
[13:32:19.837] interface close
XSV Klutch is offline   Reply With Quote
Old 04-20-2013, 08:02 PM   #2
quazimoto
Member#: 70395
Sounds like you did zero research before using this software. Read ALL the FAQ's.
quazimoto is offline   Reply With Quote
Old 04-20-2013, 09:24 PM   #3
Deano1022
Member#: 290277
2007 WRX Limited
Looks like you are trying to load data for an 05 STI....also on my 07 wrx I couldn't update past version 1.31.1396.
Deano1022 is offline   Reply With Quote
