Old 04-21-2013, 10:20 PM   #26
costabkz
Member#: 354187
I ran into this once when changing the wheel on a friend's Honda.
costabkz is offline   Reply With Quote
Old 04-23-2013, 10:59 PM   #27
sedonarex13
Member#: 313573
06 wrx
Kick the hell outa that mother
sedonarex13 is offline   Reply With Quote
Old 04-24-2013, 06:22 AM   #28
BeefCurtains64
Member#: 251257
12 WRX
Bring to the dealership if you still have warranty.
Bring it to Discount tire co if you don't have warranty.
easy.
BeefCurtains64 is offline   Reply With Quote
Old 04-24-2013, 11:42 AM   #29
Cinic
Member#: 349945
2015 WRX
GBP
Originally Posted by Bacon117 View Post
ADVICE: Once you do get it off, put a little anti-seize on the hub. This should help take care of it in the future.
Agreed. I had this problem the first time I tried to take my wheels off an older Accord. A little anti-seize spread lightly on the faying surface of the wheel and I never had a problem over the next 8 years.
Cinic is offline   Reply With Quote
Old 04-24-2013, 01:18 PM   #30
jrog28
Member#: 316269
2012 wrx premium
wrb
Originally Posted by Turd Nugget View Post
what kind of car is this?? On the last car I owned, I tac welded the wheels on from the backside right before I traded it in.......
Whata dick!
jrog28 is offline   Reply With Quote
Old 04-25-2013, 07:22 AM   #31
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Originally Posted by danbolsom View Post
PB blaster works wonders in this situation.... just don't get it on your brake rotor or pads.
also once you get it off, apply some anti seize to the wheel studs and face of the rotor to keep it from happening again.
Don't anti-seize or grease the wheel studs.
Old 04-25-2013, 07:48 AM   #32
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
Here is my winning formula.
1 Part red loctite
2 Parts anti-seize
1 Part Blue loctite
I usually coat all things threaded before I install anything.
King of Poop is offline   Reply With Quote
Old 04-25-2013, 09:58 AM   #33
arani rey
Member#: 346176
If you take it in for wheel/tire work you're most likely going to end up with copper anti-seize on your lugs. They don't care if they fall off as long as they don't get stuck and break a lug stud.
arani rey is offline   Reply With Quote
Old 04-25-2013, 10:00 AM   #34
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I have never been to a tire place that put anti-seize on the lugs.
Sounds like a quick way to get sued.
Old 04-25-2013, 10:24 AM   #35
05subysti
Member#: 268190
2005 STi
I just went through this situation last month on my dads solstice.
The passenger rear wheel was rusted on the hub.
This only happened because the aftermarket wheels we have are hub centric.
Thus leaving a hair size gap to allow rust to fuse the wheel and rotor. It feels like the wheel is welded lol
I took my 5 lb rubber mallet. Beat on it every 5 minutes in the back of tire.
Go in clockwise movements.
I used WD40 to help the rust loosen up. Some say it doesn't work, but it worked for me.
05subysti is offline   Reply With Quote
Old 04-25-2013, 10:46 AM   #36
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Stuck wheels are a common occurance. I ran into them several times a day when I worked in a shop. My usual approach went something like this:
-Thump tire with fist.
-Kick outer sidewall
-Chuck Norris roundhouse kick inner sidewall. By this point 80-90% of wheel have come loose. (Note: Put a lug nut back on a few threads first to keep the wheel from sailing/bouncing across the shop)
-10 lb deadblow/rubber sledgehammer to the inner sidewall.
-Same hammer to the inner lip of the rim.
-Hit harder.
-Hit more.
-Inform owner wheel may not survive.
-Use imagination.
-Get 12 lb steel sledgehammer.
-Break things.
I've only made it to the steel hammer stage twice. One was the rear wheels on an F-350 dualie. By this point we had exhausted everything that avoided metal-metal contact including (with the owner's permission) driving around our parking lot with the nuts finger tight, bumping the tires into curbs at moderate speeds. The final outcome of that one was a chisel between the rear wheels and a BFH, followed by new rear wheels.
Crazy_pilot is offline   Reply With Quote
Old 04-25-2013, 11:16 AM   #37
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
^ Lol
Navendra94 is offline   Reply With Quote
