Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 04-21-2013, 04:59 PM   #1
Member#: 352946
2002 Impreza WRX
Question Intermittent grinding/whirring, front right, before and after parts replaced
I found a couple similar threads but nothing specifically the same as my problem. Searched: grinding braking, grinding hard braking, grinding brakes turning.
Last week I was getting typical sounds of a dragging brake pad from the passenger side of the car. I removed tires front and back, cleaned up the slider clips and lubricated the pads and sliders. Front passenger rotor had a small raised line around the circumference of the inside of the rotor, inside pad was tapered from the outside in a small amount but plenty of life left.
Still hearing the sound, I inspected the front (problem is in the front) sliders and they were very worn/rusty so I replaced the bracket and pins and lubricated everything.
Sound got slightly better but still had a noise that occured in relation to speed, so I replaced the rotor figuring if it was a seized caliper, the sound would be constant. Got a little better.
Two nights ago, my caliper locked up on the highway resulting in some pretty bad grinding/vibrations and pulling hard right. Removed everything; lug nuts were less than finger tight, lots of filings on the lug studs, seized caliper. Wheel, rotor and pads still looked good. I replaced the caliper and bled the system.
Right now, the brakes work as they should. However, I had to brake hard :65-stop in about 500 ft. When I got the green light, there was a terrible grinding noise coming from the front passnger side. Driving normally, i occaisonally hear a light grindig noise coming from a stop and/or turning. Also, there is an intermittant whirring noise that last anywhere from 30 seconds to 3-4 minutes.
There is also a thumping noise that comes from the same location when I hit bumps.
Not wanting to throw **** at the wall, i wanted to get some outside opinions. I figure it comes down to a) stabilizer bushing, b)strut, c)brake pad, d)wheel bearing, e) brake pads and bearing, or d)bearing and strut/bushing.
techniker is offline   Reply With Quote
Old 04-21-2013, 08:27 PM   #2
Member#: 346258
I would be most likely say your bearing is bad and that could cause rotor to wobble off balance and caliper seize up too.
Wolfhead is offline   Reply With Quote
