Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 04-21-2013, 09:05 PM   #1
NateLS1
Member#: 132380
2004 WRX
rojo
Event: quarter mile
Ambient temp: 54
Elevation: 121 ft
Weather: Sunny
Conditions: strong breeze
Car: 2011 WRX
Tuner: self modified Cobb stage 2 map
Transmission: stock 5 speed
Target Boost: 19.5 psi
Target AFR: 11:1
Fuel: 93 octane
Engine Mods: Invidia downpipe
Q300 cat back
Cobb SF intake w/ box
Process West top mount
DW65C fuel pump
PTP turbo blanket
Driveline: stock everything
Suspension: SPT strut tower brace
SPT lower chassis brace
STi 19mm rear sway bar
Lowering springs, stock struts. Bouncy
Weight reduction: spare tire and tools removed
NateLS1 is online now   Reply With Quote
Old 04-21-2013, 09:09 PM   #2
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 480whp 468wtq
Wow 12.2 that's an amazing time dude, congrats and wtf did you race against in the first slip
freddy121389 is online now   Reply With Quote
Old 04-21-2013, 09:15 PM   #3
NateLS1
Member#: 132380
2004 WRX
rojo
Thanks! Weather was really great for racing today. I don't remember what it was...I remember I couldn't hear my own car over it and it was pulling a wheelie lol.
Old 04-21-2013, 09:18 PM   #4
alva8193
Member#: 318755
2012 Phatbotti Tuned
screw the e.t, that trap is amazing for 93 octane 113 is impressive as hell
alva8193 is offline   Reply With Quote
Old 04-21-2013, 09:44 PM   #5
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 480whp 468wtq
you need to get some videos up of you racing, i want to see you launch. Do you use launch control? and how hard to you launch would you say?
Old 04-21-2013, 10:12 PM   #6
NateLS1
Member#: 132380
2004 WRX
rojo
I was using launch control.... I'm pretty sure I set it to around 4500rpm. I logged the runs on the AP so I'll take a look. I do a quick slip of the clutch, it smells horrid after the run but it isn't slipping yet.
I keep the hood open in the staging lanes to minimize heat soak. I try to keep the coolant temp around 190F. After each run I put my hand on the intercooler, it was slightly warm on the inlet side but felt cold to touch on the outlet side. I could also touch the turbo heat shield for a second or so without getting burned. I think the blanket really helps out.
Old 04-21-2013, 10:14 PM   #7
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 480whp 468wtq
you make me want to go back to the track before it gets too warm out and try my luck to see what kind of ETs and traps I can get. You have motivated me sir.
Old 04-21-2013, 10:18 PM   #8
NateLS1
Member#: 132380
2004 WRX
rojo
Ya definitely do it if you can. I didn't decide to go until 6 a.m. when I woke up... cooler temps and sunny so I said F it I'm going! track is roughly 2 hours from me
Old 04-21-2013, 11:23 PM   #9
alva8193
Member#: 318755
at what rpm did u shift?
Old 04-22-2013, 06:09 AM   #10
NateLS1
Member#: 132380
2004 WRX
rojo
I was shifting at about 6500.
Old 04-22-2013, 07:31 AM   #11
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
very impressive. did using launch control result in any false knock and removed timing? I'm guessing not judging by your impressive traps! nice!!
did you use FFS or power shift or none of the above?
SenorDucK is offline   Reply With Quote
Old 04-22-2013, 07:57 AM   #12
NateLS1
Member#: 132380
2004 WRX
rojo
Thanks! I still haven't looked at my logs but I'm going to assume it didn't have false knock as well. Last year I was running open source with a torqued performance stage 2 tune and it pulled timing when using launch control. I was running 12.6 @ 103 lol.
No flat foot shifting. .. I use the clutch every time but shift as fast as the trans will let me.
Old 04-23-2013, 02:01 PM   #13
lugowrx
Member#: 269912
Chapter/Region: PRSIC
2011 Wrx limited
Red
Have you taken the rex to the Dyno?
lugowrx is offline   Reply With Quote
Old 04-23-2013, 03:13 PM   #14
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
Great run man!! A trap of 113 is enough to sneak into the 11's. If you get into the 1.6 60' range, you could make it into the 11's on 93 which is super impressive for stock turbo.
FCmaniac is offline   Reply With Quote
Old 04-23-2013, 04:03 PM   #15
NateLS1
Member#: 132380
2004 WRX
rojo
I've dyno'd it before but not with this setup. At the time it was only 267 whp on a mustang dyno at Dynotech Tuning in Seekonk, Ma.
I was thinking about lighter wheels and better tires to crack in the 11's. I'd really like to do it on 93... I'm not quite ready to jump on the E85 bandwagon yet. Closest station is about 1 hour from me.
Old 04-27-2013, 10:01 AM   #16
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Good Job Nate! I see you decided to forgo the 1000's for now. You don't really need them until you run E85 anyways.
BlazeRex is offline   Reply With Quote
Old 04-27-2013, 04:18 PM   #17
Anubis80
Member#: 341903
2013 WRX STAGE 5
Blue Magic
Nice damn timeslip. I think you could get that 60' down a bit and with that trap you should be singing 11s!
Anubis80 is offline   Reply With Quote
Old 04-27-2013, 08:03 PM   #18
NateLS1
Member#: 132380
2004 WRX
rojo
Thanks! Ya I held off for now. I do know my IDC is higher than I like though lol.
Old 04-29-2013, 07:43 AM   #19
Rideit636
Member#: 275099
Nice Job. Good To See A Local Running Good Times On Stock Turbo. Setup Matches My Plans Almost Exactly.
Rideit636 is offline   Reply With Quote
Old 04-29-2013, 09:34 AM   #20
NateLS1
Member#: 132380
2004 WRX
rojo
Thanks, hopefully I will be heading up again this Sunday for the Import Faceoff. I didn't spin at all so I might bump my launch rpm up and see what happens. I had my tires at about 19 psi.
Old 04-29-2013, 09:40 AM   #21
missmysubie
Member#: 313857
07 STI LTD
(Mustang) 306/346 VF48
great times....
missmysubie is offline   Reply With Quote
Old 04-29-2013, 09:47 AM   #22
Wrexflex
Member#: 326301
2012 WRX LR - Sold
2015 Forester Premium CBS
Wow, that's impressive man. I have yet to take my car to the strip, but I have the same mods + some 750CC injectors & EBCS. That is def. some motivation to get down there and run it, getting into the 11's would be a great achievement.
Wrexflex is offline   Reply With Quote
Old 05-06-2013, 09:02 AM   #23
IBFBSNIPEZ
Member#: 354138
2004 STi
My car dynoed at 370hp/340tq and my best time is 13.3. I was told I need a new clutch. I think I just can't drive this thing.
IBFBSNIPEZ is offline   Reply With Quote
Old 05-06-2013, 09:04 AM   #24
SenorDucK
Member#: 327511
13' WRX 6 Speed
what was the rest of the time slip? that'll tell the rest of the tale
Old 05-06-2013, 09:37 AM   #25
IBFBSNIPEZ
Member#: 354138
2004 STi
I don't remember...that was back in November. I know my 60' was like 1.8. Nd I did that without LC or FFS. Every time I used them my times got slower.
