Old 04-22-2013, 12:28 PM   #1
WindyCity_Scooby
Member#: 282543
08 STi
Default 425whp 1/4mile
I am very curious as to what gear I would be at end at the end of a 1/4 mile. I hit 425 whp on a dyno jet with 20gxt-r on e85 anyone with similar numbers can give me a hint? Also what times would I be looking at?
WindyCity_Scooby is offline   Reply With Quote
Old 04-22-2013, 01:03 PM   #2
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
You will get 50 answers, none of which will be at all accurate due to many factors such as weather, track conditions, ect.
Try this....
Click to View Search Results for 1/4 mile calculator - Google Search 1/4 mile calculator - Google Search
As for gears, very likely 4th in a wrx, 5th in an STi.
Cathexis is offline   Reply With Quote
Old 04-23-2013, 08:05 PM   #3
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Your answers will come from experience. Need to find the line between power falling off at high rpm while maximizing gearing. A dyno plot would help to visualize your powerband.
Steve.804 is offline   Reply With Quote
Old 04-23-2013, 08:34 PM   #4
Gex
Member#: 330000
05 LGT Wagon
RBP
Shoot for 12's with a solid 60'. Throw in launch control,ffs, cool day, sea level, with 425hp and a solid launch 11.4 maybe. I'm reaching here. Just go run then post!
Gex is offline   Reply With Quote
Old 04-23-2013, 08:35 PM   #5
C J
Member#: 132587
2006 JrTuned STi
[email protected]
4th gear.
C J is offline   Reply With Quote
Old 04-25-2013, 02:05 AM   #6
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Depending on the tire size you are running you may get away with 4th. If you have a short tire with the 20g you are better off shifting into 5th and using the TQ/Hp curve.
You have power to go deep into the 11s at 118-122mph. With some driving and a good wheel/tire combo that can keep you in 4th you might see 124mph traps and 11.20s
Junior2JZ is offline   Reply With Quote
