Old 05-27-2013, 08:46 PM   #1
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Question Oil leak near oil filter
My recently acquired MY02 WRX wagon has a very slight (but messy) oil leak. Slow enough that overnight in the garage it doesn't actually leave a drop on the floor, but it is clearly a mess underneath. Both valve cover gaskets look messy, I plan to replace those, but I'm wondering if this mess around the oil filter is a different leak? It appears to be coming from above the filter, are there any common leaks in here to look for before I tear it apart?
Thanks.
Snowphun is online now   Reply With Quote
Old 05-27-2013, 10:14 PM   #2
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Check around that cooler and the hosing on there. Cracks or tears in it. Spray some carb cleaner and get it really clean and watch it for a while.
Non running to see if it leaks
If not start the car after ya clean it and watch for some leaks
cosseywrx is offline   Reply With Quote
Old 05-27-2013, 11:14 PM   #3
02SportWagon
Member#: 224751
2002 WRX Wagon STG 2
Mine does that too...very slight weep. Not hardly enough to notice on the ground until you crawl underneath. I've been trying to locate the cause of this issue as well.
02SportWagon is offline   Reply With Quote
Old 05-27-2013, 11:46 PM   #4
H4-ftw
Member#: 336569
2002 Impreza Wrx
Mines the exact same and after research i found it was the oil cooler gasket/ o-ring. I havent replaced it yet but plan to. Apparantly its pretty common on these cars so Id say thats your best bet
H4-ftw is offline   Reply With Quote
Old 05-28-2013, 06:48 AM   #5
pebelz
Member#: 268632
2015 XV
Replaced mine. I read somewhere it was possible to get that gasket out without removing any hoses. I tried this and even made a pic from a bicycle spoke to get it out. There was only like an inch of play, and I could feel the gasket with a finger and pic, but it was in good. While wrangling the oil cooler it popped off one of the hoses. Luckily I had a couple sharpies for this, plugged the hole, and easily removed the gasket. When you put everything back together be very careful to make sure the new gasket seats right. It will pop out of the groove easy.
pebelz is offline   Reply With Quote
Old 05-28-2013, 09:34 AM   #6
aaronbo
Member#: 320733
02 wrx
MBP
My 02 leaked in the same spot. I did replace my gasket and it wasn't too bad. I did pull off one of the coolant lines and got a bucket to catch the coolant. one thing to try before you replace the gasket is pulling off your oil filter and tighten up the bolt that is in the middle of the cooler.
aaronbo is offline   Reply With Quote
Old 05-28-2013, 01:41 PM   #7
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Great info, thanks guys!
Old 05-29-2013, 12:23 AM   #8
wrx1392
Member#: 342331
2003 wrx
blue
yep the orange o-ring between the block and oil cooler ..this happens a lot . easy to fix if you have the right size sockets ,and you'll have to drain you coolant .should replace those coolant hoses while you are there.
wrx1392 is offline   Reply With Quote
Old 05-30-2013, 12:29 AM   #9
02SportWagon
Member#: 224751
Thanks for the info! Looks like I'm gonna be doing that at my oil change!
