Notices
Old 04-24-2013, 11:38 PM   #26
neo277
Member#: 131432
2004 WRX on Ignite E
Gtx3076 - 07 6mt
Originally Posted by Concillian View Post
Well, the correct solution is a surge tank, but who wants to use trunk space for a second fuel tank?.. Not to mention how much more it costs.
There's something to be said for simple cheap solutions. Call it a band-aid if you will, but it's essentially what Subaru has done for the 08+ pump hangar.
I agree with you on this Concillian, And I have to say I don't have much much to loose with trying Shane's slosh mod. O except for $13 bucks lol. I'm not too concerned about the trunk space tbh, currently I have my meth setup taking up the trunk area. I mounted the main tank on the left side and it gravity feeds to a surge tank that is mounted in the spare tire area and the meth pump is right next to the surge tank.
neo277 is offline   Reply With Quote
Old 04-25-2013, 12:00 AM   #27
neo277
Member#: 131432
Gtx3076 - 07 6mt
Originally Posted by amroof View Post
You can always install an sti fuel pump assembly minus the pump as you have an upgraded one. The sti has a small slosh tank built into the pump assembly were the wrx or any other turbo model doesnt. I have this same issue at 1/4 tank or lower in my 207 swapped fxt with an aeromotive 340. I have tried to lower it further into the tank and that helped a little, But a surge tank would work awesome.
I have a sti assembly sitting in my box at work and just havent had time to try it out. If I get a chance to install it I will let you know if it works out.
I thought about this as well, but I would guess Shane's slosh mod provides the same effect, since i already ordered the tank to do this mod i am going with that route 1st to see how it pans out.
Please do let me know If u get around to installing and Testing out the Sti pump assembly method.
Thanks for your feedback
Z
Old 04-25-2013, 01:00 AM   #28
wrx1392
Member#: 342331
2003 wrx
blue
some good info here ...so is there another sock and pump on the left side saddle tank ? or does return fuel move gas from the left side to right.i think there is a cover on the left side of trunck to access this side of the tank?wish i had a service manual to ck this out .
wrx1392 is offline   Reply With Quote
Old 04-25-2013, 09:20 AM   #29
neo277
Member#: 131432
Gtx3076 - 07 6mt
Im not sure if there is another acutall pump or what it looks like, ill be taking it apart in a day or so. Ill Post up some pictures though of the other side and a pictures of the diy surge tank.
thanks
Z
Old 04-25-2013, 10:54 AM   #30
penderperson
Member#: 172370
2006 STI
There is a jet/motive/venturi pump which is only fuel moving fuel. It looks like a pickup though.
penderperson is offline   Reply With Quote
Old 04-25-2013, 11:14 AM   #31
neo277
Member#: 131432
Gtx3076 - 07 6mt
Gotcha, thank you again sir, ill be checking the return line and making sure there are no clogs along with doing the Shane's slosh mod, which funny enough is pretty dam close to what the sti pump assembly has.
So im sure if the sti came with this feature that the engineers did it for a Particular reason.
Old 04-30-2013, 11:44 PM   #32
neo277
Member#: 131432
Gtx3076 - 07 6mt
Update:
So I removed my fuel pump assembly and in process of installing the "Shane's surge tank mod"
Also I removed the pickup assembly on the other side of the tank,
I checked the return lines, the pickup, and the return jet pump on the primary fuel pump assembly. All seems well, no blockages and all line connections are secure.
Here's a pic of the pickup on the left side of the tank
Once I finalize the surge tank ill
Post up pics as well and test results.
Fingers crossed.
Old 05-01-2013, 10:38 AM   #33
DamnDodgeRams
Member#: 355139
2003 WRX wagon VF28
Check the computer
DamnDodgeRams is offline   Reply With Quote
Old 05-01-2013, 12:18 PM   #34
neo277
Member#: 131432
Gtx3076 - 07 6mt
Originally Posted by DamnDodgeRams View Post
Check the computer
Please Clarify.
Old 05-01-2013, 03:48 PM   #35
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
Check the computer
die!
Mr.Chow is offline   Reply With Quote
Old 05-01-2013, 04:43 PM   #36
neo277
Member#: 131432
Gtx3076 - 07 6mt
Originally Posted by Mr.Chow View Post
die!
HAHAHA. i laughed as well. i was like, did you read my thread.
Old 05-30-2013, 10:13 AM   #37
neo277
Member#: 131432
Gtx3076 - 07 6mt
Update:
Sorry for the long delay, been tied up with house and wife stuff lol.
So installed the surge tank seen here:
After the install i went out to test the system and instantly noticed the car was running about .5 -.7 leaner about 4k and above, so instead of 11.1-2 i was at 11.6-.9. after that i removed the surge tank and my a/f's went back to normal. So at this point im at a loss, i think ill be going with a full surge tank settup as that seems to be the best solution.
