Old 04-24-2013, 12:53 PM   #1
rothjl03
Member#: 353658
Default Erratic AFR at Idle??
I just got my 08 WRX about a month ago. It has STP exhaust and a Cobb DP and I have no idea if it has a good tune. I am thinking probably not.... First thing I bought was the Tactrix unit so I could do some datalogging. I also installed an AEM Uego. The car has been running fine since I bought it. However, yesterday at idle the AFR would randomly go from running very rich to very lean. As in, almost maxing out the gauge in each direction. When I would go to accelerate from idle, it would hesitate and run a bit rough until around 1500 rpms and then smooth right out. Also, driving parking lot speeds in say first gear when it showed the AFR to be very rich, there would be a backfire type noise coming out of the exhaust when I would get off the throttle. Any ideas as to where I should start my investigation would be much appreciated.
Today though, it has seemed to smooth out with the AFR readings.
Thanks,
Josh
rothjl03 is offline   Reply With Quote
Old 04-24-2013, 02:09 PM   #2
RoadKillDMD
Member#: 284792
2011 STI
Blurple
If your car isn't tuned for that downpipe, you need to get tuned ASAP. That should be your priority. I would recommend not even driving around without at least a stage 2 flash from Cobb.
The fluctuating AFRs at idle have to do with the fueling at cold idle, and the air pump blowing into the exhaust at startup. Worry less about AFRs at idle, and worry more about AFRs under load, boost, and WOT. STAY OUT OF BOOST UNTIL YOU GET TUNED.
RoadKillDMD is offline   Reply With Quote
Old 04-24-2013, 02:19 PM   #3
rothjl03
Member#: 353658
The car was fully warmed up when this started. I had been driving for maybe a half hour when it happened.
Can I load the Cobb stage 2 flash with EcuFlash?
Old 04-24-2013, 02:26 PM   #4
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Cobb maps can only be flashed from an Accessport AFAIK. Contact Eric at Torqued Performance. He only charges $85 for an open source stage 2 tune and offers tailored adjustments for your map on your particular car. http://torquedperformance.com/
Old 04-24-2013, 02:38 PM   #5
rothjl03
Member#: 353658
Thank you much, just downloaded the stage 2 map from them.
Old 04-25-2013, 12:30 AM   #6
dead_eye
Member#: 308265
2008 WRX
dead_eye is offline   Reply With Quote
Old 04-25-2013, 08:39 AM   #7
rothjl03
Member#: 353658
Originally Posted by dead_eye View Post
Anyone think a smoke test would be a good way to tell if this is a problem?
