Old 04-24-2013, 10:25 PM   #1
hardhitter_alert
Member#: 293841
2007 STi
Default 07 Sti burning 1 quart of oil every 1500 miles
I am not sure where the oil is going but it is burning 1 quart of Rotella T6 5w40 every 1500 miles. What the easiest way to check if it is the turbo or engine? I have a FMIC.
hardhitter_alert is offline   Reply With Quote
Old 04-25-2013, 01:32 AM   #2
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Get a compression/leakdown test to make sure the engine is in good shape. Also have you noticed any type of smoke out the exhaust? You can also look at the intercooler hoses for excessive oil in there. A light film of oil on the hoses is normal but alot is not. Also depending on how you drive you may not have a problem. These cars seem to have the disappearing oil effect. Also what other mods besides the fmic, and is everything properly tuned for? You can also start up the car and take the oil filler cap off and check for smoke coming out of that.
Coreycarlile911 is offline   Reply With Quote
Old 04-25-2013, 07:59 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
with the engine at operating temp and running...take the oil filler cap off
do you have raw exhaust blowing out of the filler???
then ya gonna have to rebuild it
Old 04-25-2013, 09:25 AM   #4
kleedzine
Member#: 273531
02 frankenSTI
white
I have similar issue, I have checked compression/leak down(they are ok), no sign of leak in engine bay, and turbo hot side. I checked oil filler, no blowing out exhaust gas, or smoke, it actually sucked the cap, when I put the cap on filler. I have 06STI stage2 (downpipe, turbo inlet, EMU) custom forged built motor. I have TMIC crawford v2 aos, routed as per their instruction. I still get oil puddle in IC, Y pipe. I have used Motul 5W40, Redline 10W40 with 1 quart of 20W50, Rotella T6 5W40. Currently, Brad Penn 15W40. Still burns oil. Where else should I look at?
kleedzine is offline   Reply With Quote
Old 04-25-2013, 10:15 PM   #5
dlapham
Member#: 350332
2004 Bone Stock* STi
*with supporting mods
I am new here, but thought I would chime in. I just purchased an 04 sti knowing that it used a quart per 1k miles. No smoke, just a film in IC hoses, replaced cracked PCV hoses, but it continued to use oil. Turbo had some shaft play, but not bad. Got a tactrix and logged with romraider. With the help of endrswd, discovered that it was over boosting due to vf43 and no restrictor pill. Long story longer, we did a leak down test and cyl 4 failed (dont remember exact numbers). Figured broken ring land, so we are rebuilding with cosworth pistons. Any how now that it is apart, the pistons look fine, but the oil rings are stuck. I am still not sure why number 4 failed leak down, but we are doing a proper build (not drop in). The original hone markes are still on the walls after 120k plus miles.
Not sure if this will help anyone, but hopefully it will.
-David
dlapham is offline   Reply With Quote
Old 04-26-2013, 12:31 AM   #6
daseca07
Member#: 277630
2007 WRX TR
my 07 wrx burns about a quart every 2k miles. like already mentioned get a compression/leakdown test
daseca07 is offline   Reply With Quote
Old 04-26-2013, 01:52 AM   #7
hardhitter_alert
Member#: 293841
2007 STi
No there is no smoke from the exhaust at all. I will check the intercooler hoses. It is boosted to about 20 psi but not too often since it's a daily driver and yes it has been tuned. It has a big turbo, TGV delete, ported manifold, hybrid boost control, ect.
I will check on this but how do you know if it's raw exhaust and not just some air?
Old 04-26-2013, 03:00 AM   #8
esteve
Member#: 28716
2006 STI
-David
Just wondering, can you find out what the leakdown % was for #4? If everything looked fine then maybe it was borderline, like 15-20%.
esteve is offline   Reply With Quote
Old 04-26-2013, 06:15 AM   #9
dlapham
Member#: 350332
It was 50% I think. I will get the paperwork later today and post the results. My mechanic said that there was a lot of gap in the compression rings, but I do not have figures. I know that some high performance cars run a lot of ring gap OEM.
Old 04-26-2013, 10:57 AM   #10
kleedzine
Member#: 273531
02 frankenSTI
white
anybody has answer for this?
Old 04-26-2013, 11:50 AM   #11
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
It sounds like you could be leaking oil from the turbo compressor side if leakdown is good and you are still getting oil in your intercooler. Also check that your valve cover breather lines to your AOS are clear. If they are clogged, you could be pressurizing your crankcase under boost, creating a restriction to proper oil drainage from the turbo.
guroove is offline   Reply With Quote
Old 04-26-2013, 04:25 PM   #12
Kingnothing616
Member#: 277507
I have never tried it on a Subaru yet, but early 2000's 1zz Toyota engines and late model 5.3 gm's have terrible oil consumption problems. Compression restore from BG is designed to clean and free the rings and I have fixed about four so far at my shop that were about to be tore down at other shops in town. The worst one was an 01 corolla using 1qt every 400 miles, now it is down to 1qt every 3,000. A few manufacturer classes I have taken said most of them are switching to a low strength ring to reduce friction to meet CAFE scores. I've tried tons of top engine cleaners as a tech and all the other gimmicky crap and the 109 is only product that seems to work.
Kingnothing616 is offline   Reply With Quote
Old 04-26-2013, 04:58 PM   #13
dlapham
Member#: 350332
I wish I would have known about and tried this before my rebuild. I was convinced by this forum that it was a cracked ringland. Now it seems it was stuck oil rings..
Old 04-26-2013, 06:35 PM   #14
Kingnothing616
Member#: 277507
That stinks man, most people that aren't in the industry haven't seen these sort of issues. Carbon issues due to ethanol blended fuels and low quality oils with good advertising are at fault.
Old 04-26-2013, 08:25 PM   #15
hardhitter_alert
Member#: 293841
2007 STi
I removed the oil cap and it was blowing out some and when I sniffed it kind of smelled good like a mix of oil and fuel a little bit. I assume exhaust would smell really bad? Should I try that BG? I used to have a Corolla 1zz-fe and it would drink oil like crazy.
Old 04-27-2013, 01:13 AM   #16
Kingnothing616
Member#: 277507
I would, if it is a sticky ring issue it will take care of it. Just have to find a distributor in your area.
Old 04-30-2013, 08:41 PM   #17
hardhitter_alert
Member#: 293841
2007 STi
I added the BG 109 today and followed the instructions and dumped the oil. Should I look into a catch can? I am running about 20psi.
Old 05-01-2013, 08:57 AM   #18
kleedzine
Member#: 273531
02 frankenSTI
white
I am curious about the result of BG109 on our boxer engine.
Old 05-01-2013, 09:44 AM   #19
guroove
Member#: 129833
2005 Forester XT
If it smelled like fuel, and it was blowing out, that sounds like something is getting past the rings. If you put your hand on it, and the overall result of the puffs in and out equal to close zero pressure, then you are good. If it farts out around your hand, your motor is busted.
Old 05-01-2013, 08:41 PM   #20
hardhitter_alert
Member#: 293841
2007 STi
How hard should I press my hand down? I refilled the oil today and drove a little bit and I had to check engine codes: P0031 and P0456
Old 05-01-2013, 10:47 PM   #21
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
looks like all that burned oil killed your front o2 sensor. Yaa, you prob will need a eng rebuild
BlackFighter is offline   Reply With Quote
Old 05-01-2013, 11:04 PM   #22
ryansx
Member#: 324527
2013 wrx
white
Bg has good products but the compression restorer never worked on the GM 5.3 when I was in the dealer. I was still replacing pistons in 2 engines a week and the ones that tried the bg looked identical to the ones that didnt. But in the subies it could be a different story, it's worth a shot, what's a couple $ if you may have to do a rebuild anyways.
ryansx is offline   Reply With Quote
Old 05-02-2013, 01:40 PM   #23
Kingnothing616
Member#: 277507
I'm no expert on catch cans, probably not a bad idea. On the 5.3s I usually let it idle for 45 minutes and then put the MOA in the the new oil and have had good results. Most cars are just a case by case basis. Did it to a 96 Dakota V6 that the customer had been chasing a misfire for months, he had replaced everything ignition related and the injector for #5. Came in hammering on that cylinder looking at the data steam. Compression was 100-105 psi on 1,2,3,4,6 and 5 psi on #5! I was ready to tear the engine down and decided to try 109 first. 1,2,3,4,6 were all around 120 and #5 shot up to 100 and the misfire was gone. I was always skeptical till that day.
I've also seen major horsepower and torque gains on the dyno doing it on diesels, in person.
