Old 09-19-2014, 07:01 PM   #1
Nastypants
Member#: 312942
Default Vf52 in 08 wrx
I just bought a vf52 turbo for my 08 wrx. Any suggestions for running it on every thing else stock besides exhaust intake and accessport?
Sent from my iPhone using NASIOC
Nastypants is offline   Reply With Quote
Old 09-19-2014, 07:04 PM   #2
Trustkevin13
Member#: 259184
2008 Subaru WRX
bigger tmic, ebcs, and fuel pump. oh and some suspension parts. GLHFGG
Trustkevin13 is offline   Reply With Quote
Old 09-19-2014, 07:23 PM   #3
Fender137
Member#: 340626
2004 Impreza Wrx STi
World Rally Blue
A real Protune / E-Tune should be Priority one and +1 what Kevin Suggested, But Best to finalize things with your tuner.
Fender137 is online now   Reply With Quote
Old 09-19-2014, 07:32 PM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
I'd research before buying a turbo as to what you need. Or now, since you've wasted money, go find and talk to a tuner.
Old 09-20-2014, 06:01 PM   #5
carfan771
Member#: 315743
2008 WRX TPStage3.52
Grey
A VF-52 is the most logical upgrade for a stock 2008 WRX. There are a ton of options for additional mods but the most important thing is that you will need to tune for that turbo. Going to a local tuner is good advice, however if you want to keep costs down and still be able to enjoy your purchase I suggest you check out torqued performance on the web. I have used several e-tunes from Eric Minehart and could not be more pleased. There you will find a list of the mods you need for his maps and he is the only one I know that e-tunes a 2008 WRX with a vf-52.
carfan771 is offline   Reply With Quote
Old 09-20-2014, 09:59 PM   #6
Nastypants
Member#: 312942
Thanks a ton guys
I mean my stock turbo was smoked.
I've done some reading on the vf52 and to what I've read it was my best option for what I had. Now pretty much I have an 09 without a tune.
For an etune what about running a Cobb preset map for an 09 until I make it to a tuner. To my knowledge there are none for a good 80 miles in any direction. So I need something to not blow my car up. Haha.
So bigger tmic, fuel pump, 650cc injectors, any other ideas on mods?
Old 09-20-2014, 10:22 PM   #7
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
I'd call said tuner to see what they have to say about it.
They can best help you, as well as possibly getting a safer baseline map to get you more safely to the tuner.
colin1234567 is offline   Reply With Quote
Old 09-20-2014, 10:34 PM   #8
subezero
Member#: 207614
2008 WRX Hatch VF52d
SSM
Originally Posted by Nastypants View Post
Thanks a ton guys
Not sure why you have two threads going at once for the same topic, but DO NOT try and flash an 09 map onto your 08 ECU. They have different parameters and you are going to either brick your ECU or destroy your engine. Your safest bet is to flash the 2.52 ROM, run some logs and send them back to Eric for adjustments, asuming you are using the stock fuel pump, injectors, and TMIC.
subezero is offline   Reply With Quote
Old 09-20-2014, 10:36 PM   #9
Nastypants
Member#: 312942
My bad on the two threads. Thought the other didnt post but. Yeah trackin on the not flashing 09 map. Jumped on torqued performance and got the stage 2.52 map. Any other help you can offer im all ears.
Old 09-20-2014, 10:37 PM   #10
Nastypants
Member#: 312942
Yeah everything is stock other than exhaust and intake at the moment but that will change within the month.
Old 09-21-2014, 07:58 PM   #11
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
make sure you read the install notes. you have to have cobb accesstuner race software. you need to copy and paste the map into ap manager from the emailed map link.
http://www.torquedperformance.com/20...P08WRXVF52.htm
Old 09-21-2014, 08:04 PM   #12
Nastypants
Member#: 312942
Yeah I learned that last night which was aweful news for me due to the fact that I run a mac. But what I did was downloaded ap manager accesstuner had all the info on my comp emailed to myself opened it on a friend's windows puter opened the map with the access tuner saved it to desktop uploaded it through ap manager and here I am
