Closed Thread
Old 04-25-2013, 12:53 AM   #1
jadawgis732
Member#: 208409
2012 WRX Sedan
Default Do I Have a Tire Pressure Sensor Monitor
How do I tell if I have the tire pressure sensor monitor installed? It's a 2012 WRX Limited with stock wheels (and tires, I assume) that I purchased with 15,200 miles on it.
jadawgis732 is offline
Old 04-25-2013, 12:55 AM   #2
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
All 2012s have TPMS...? There would be a dash light on if you didnt, it would flash on ignition if there was a malfunction..
nightdown fox is offline
Old 04-25-2013, 01:07 AM   #3
jadawgis732
Member#: 208409
2012 WRX Sedan
Thank you very much.
Old 04-25-2013, 01:17 AM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
All vehicles after 2008 are required by federal law to have a TPMS installed.
kpluiten is offline
Old 04-25-2013, 01:33 AM   #5
NJ_wrx
Member#: 268855
2009 WRX
red
It's a retarded feature that the government has regulated on cars for whatever reason. It's a hinderance to my winter/summer tire setup. I hate that light and refuse to pay $100 for the light to go away.
NJ_wrx is offline
Old 04-25-2013, 02:27 AM   #6
jadawgis732
Member#: 208409
2012 WRX Sedan
Oh man! So if I switch rims (as I was planning to do) does that mean I have to get a new OEM TPMS? Or if I get new tires, do I also have to do that?
Old 04-25-2013, 02:58 AM   #7
aod12
Member#: 282701
2008 FXT
If you get new wheels and want the light to stay off then you'll need to get tpms sensors installed in those wheels. Everytime you want to switch wheels you'll need to go to a dealership to reprogram the tpms.
An alternative is to get a set of programmable tpms and program the set with the same codes as what you have now. Hardest part is finding a shop that has the right tool for this scenario...nothing a bunch of calls won't fix.
Last alternative is to just ignore that light
aod12 is offline
Old 04-25-2013, 08:40 AM   #8
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
Pay $100 once and get an Ateq Quickset. When I switch from winters to summers and vice versa, I just plug the Quickset into the OBD and push a button. No light.
Just new sensors for all four when you get new rims. If you get a rim/tire combo from Tire Rack, for instance, you can order the sensors installed already in the combo. If you just get tires with the stock rims you already have, no sensor change necessary (unless the installer messes up the sensor). Word of warning, if you buy a Tirerack combo, they do not turn the sensors on (to conserve batteries). So when you put the wheels on, a tire store or mechanic has to walk around the car with an activator.
If you're getting seperate winter and summer rims, get the Ateq Quickset as mentioned above to switch between codes yourself when you switch wheels.
Old 04-25-2013, 04:54 PM   #9
fistv
Member#: 350063
2013 Impreza sport
Oh man, it just never ends, the sensors have batteries ?, wonderful, something else that needs to be replaced. Gotta love the feds. Wonder who of our elected clowns made out on that piece of legislation.
fistv is offline
Old 04-25-2013, 04:57 PM   #10
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
Yep, sensors have batteries in them, when the batteries die the entire sensor has to be replaced. Supposed to last around 100k miles though.
Old 04-25-2013, 06:28 PM   #11
aod12
Member#: 282701
2008 FXT
You can blame the Bush era of administration if you really want to point fingers. But its unfortunately a legit concern if no one, generally speaking, wants to go out of their way to make sure their cars are safe to operate on the road.
aod12 is offline
Closed Thread
