Old 04-25-2013, 01:41 AM   #1
pchoi425
Member#: 334013
2011 Wrx
another clean swp
Default 2011 WRX wg flutter or leak
Hey guys, I searched around the forums, but I couldn't find any videos with a noise exactly like mine.
http://www.youtube.com/watch?v=4-4xp...ature=youtu.be
The noise comes up around 0:05.
It happens at WOT;sometimes on 3rd gear and always at 4th and 5th gear.
I have already removed the endcaps on the TB to IC hose and have already replaced the bpv. has anyone else experienced this sound?
Any help is appreciated, thanks!
Mod List:
invidia catless tbe
cobb sf intake
forge bpv
Torqued Performance stage 2
pchoi425 is offline   Reply With Quote
Old 04-25-2013, 02:21 AM   #2
stevejones19
Member#: 275250
2006 WRX
Normal. Its very normal.
stevejones19 is offline   Reply With Quote
Old 04-25-2013, 02:38 AM   #3
pchoi425
Member#: 334013
2011 Wrx
another clean swp
It's kind of hard to hear in this video. You heard that flutter/ or boost leak at 5 seconds?
Old 04-25-2013, 04:14 AM   #4
maizer89
Member#: 326861
2015 STI
definitely normal on 2009+ cars, a good amount of people swear by pnp the vf52 will actually help lower the flutter noise that you're hearing
maizer89 is offline   Reply With Quote
Old 04-25-2013, 06:56 AM   #5
jpatt006
Member#: 289470
2010 Forester XT
This has been brought up a lot recently. It is completely normal.
It is the sound of your wastegate opening and closing to regulate boost.
jpatt006 is offline   Reply With Quote
Old 04-25-2013, 06:59 AM   #6
jpatt006
Member#: 289470
2010 Forester XT
This is incorrect as it is not the turbo causing the flutter, it is the wastegate. The boost solenoid sends a signal to open and close the wastegate in order to regulate boost. This is what causes the fluttering sound.
The only "fix" (not really a fix since it isnt a problem to begin with) is to go MBC.
Old 04-25-2013, 08:38 AM   #7
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Did you mean porting the IWG? PnP is when you smooth out the bends on both the hotside and coldside.
Mr Wrex is offline   Reply With Quote
