Old 04-25-2013, 01:51 AM   #1
07pearlwht
Member#: 212576
2007 impreza wrx sti
pearl white
Default 07 STI | FP HTA76 Red | E85
Event: Road Dyno
Ambient Temp: 62*F
Elevation: 4660ft
Weather: Warm and clear
Track and Conditions: Dry roads
Tires: Goodyear Eagle F1 AS 225/45/17
Car: 2007 STI
Dyno Info: Virtual Dyno
Transmission: Stock 6 speed
Gear: 3rd
Peak HP at RPM: [email protected]
Peak Torque at RPM: [email protected]
Target Boost: 24.5
Target AFR: 11.7
Fuel: E85
ENGINE
-Brand new case halves
-2011 STI nitrided crank
-Cosworth bearings
-Wiesco 99.5mm 9.0/1 pistons
-Manley Turbo Tuff I-beam rods
-Stock gasket kit
-GSC stage 1 266/268 AVCS cams
-3 angle valve job with new stock valves
-BC titanium valve springs + retainers
-Grimmspeed UP with Tial 38mm MVS EWG
-ACT 6-puck with HD PP
-Dual Perrin catch cans
AIR
-Forced Performance HTA76 Red
-FP 84mm inlet
-KSTech 73mm CAI
-2011 STI TMIC
-TGV deletes with phenolic spacers
-Airpump delete
FUEL
-Five-O Black Ops 1400cc topfeed injectors
-Aeromotive 340 stealth pump
-Aeromotive FPR
-Stock lines
ENGINE MANAGEMENT
-COBB AP V2 with hybrid speed dinsity and AT race
-Hybrid boost control with Grimmspeed EBCS and manual BC
- STRI boost, oil pressure, oil temperature, and AEM wideband
MISC
-BC BR coilovers
-24mm F+R swaybars
-Pioneer avic4500
-SPT short throw
Fuel pressure is dropping to 40psi up top, thinking it's the pump. A new Walbro460 is on it's way. We had to stop tuning because my throwout bearing came unclipped from the pressure plate . Driving with no clutch is fun
As soon as it's fixed, I'm looking for ~490whp.
07pearlwht is offline   Reply With Quote
Old 04-25-2013, 03:04 AM   #2
Evoeter04
Member#: 351451
04 STI
Huhuhuhuhuhuhuhuhuhuh
Evoeter04 is offline   Reply With Quote
Old 04-25-2013, 10:13 AM   #3
st205wrx
Member#: 193253
08 wrx 322/352
wrb
These are some nice numbers. Nice bold man
st205wrx is offline   Reply With Quote
Old 04-25-2013, 10:34 AM   #4
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Nice too see someone else using the GSC S1 cams. IMO too many people jump to the S2 and they arent near the power level they were designed for. Makes fore a laggy/not alot under the curve SOB compared to the S1 cams for they given power level/DD set up.
Just my OP
rexworx is offline   Reply With Quote
Old 04-25-2013, 12:16 PM   #5
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Good stuff Cody. Actually looks pretty good. Once you get some boost this thing is gonna be fast as ****!
renosubby is offline   Reply With Quote
Old 04-25-2013, 12:38 PM   #6
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Did I miss the graph?
Zee Biker is offline   Reply With Quote
Old 05-15-2013, 01:12 AM   #7
crazy_flip
Member#: 290253
2007 Sti atp gtx3076
Pearl white
Hi which injectors are these are they the denso or the black ops ones? If so how is the idle?
crazy_flip is offline   Reply With Quote
Old 05-15-2013, 10:56 AM   #8
fourmicah
Member#: 128760
2015 STI
Definitely need pictures, definitely.
fourmicah is offline   Reply With Quote
Old 05-15-2013, 09:13 PM   #9
07pearlwht
Member#: 212576
pearl white
I put up some pictures. It looks like the graph never showed up, I will find another one.
The goal was to appear stock/stage 2ish in the engine bay. Obviously a trained eye would spot the power but otherwise I think it looks pretty calm.
Those are the Black Ops injectors. They idle nicely.
I got the walbro in, I just need to finish tuning.
