Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 09-16-2013, 12:10 PM   #1
rushdylan
Member#: 337170
2003 wrx
well my ECU died somehow and I replaced it with another one. for some reason I keep getting 'programming voltage too low' I ran a 12V wire to the flash block. the battery is over 12 volts, and the ECU power supply is also 12 volts. I have no clue where else could have low voltage? I've tried this on TWO separate ecu's. any input? I've tried different USB cables, and reinstalled ECUflash. I'm stumped!
rushdylan is offline   Reply With Quote
Old 09-16-2013, 01:38 PM   #2
rushdylan
Member#: 337170
2003 wrx
just re-pinned and soldered the reflash connector and tried to flash the ECU with a charger on the battery and no luck. this ECU last worked on a 2002 USDM wrx. I have a 2003 USDM
Old 09-16-2013, 10:07 PM   #3
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
According to this http://www.scoobypedia.co.uk/index.p...ctingToYourECU
the 02 and 03 ecu's use different flash blocks. Did you try both pin configurations?
Old 09-17-2013, 04:43 PM   #4
rushdylan
Member#: 337170
2003 wrx
I got it to take two ROMs last night but no luck today. it makes scaling injectors or MAF a nightmare!!!!!
Old 09-19-2013, 11:57 PM   #5
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
I had this same issue. Turned out to be a Tactrix software issue. What version of their software are you using? I thought they solved it with an update last year. I started a thread on this issue a while back.
Soarer is offline   Reply With Quote
Old 09-20-2013, 09:53 AM   #6
rushdylan
Member#: 337170
2003 wrx
actually, I found a bad ground on my engine wire harness and it's all good now!
