Old 04-26-2013, 01:01 AM   #1
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Default What should I do while I'm having my pistons replaced?
Unfortunately for me, my '10 FXT has lost compression in at least 2 of it's cylinders. My tuner is going to replace the pistons with JE EJ257 pistons and KS Tech air pump delete plates.
My question is this: While the tuner has the engine torn down, what else do you think I should have done? Short of using thinner gaskets to increase compression, I don't have any experience with this kind of thing.
Any thoughts are appreciated!
eugeneutopia is offline   Reply With Quote
Old 04-26-2013, 02:45 AM   #2
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
Internal or external? I would at least do some Grimmspeed phenolic spacers, motor mounts, and pitchstop. Sti crank. Perhaps a new inlet. What else can you afford? Forged rods? Cams and valvetrain upgrades? Port and polish? Killer bee oil pickup? Light weight fly wheel? Better clutch? More cowbell? More importantly, what does your tuner suggest? 50 pushups?
isotopesope is offline   Reply With Quote
Old 04-26-2013, 08:22 AM   #3
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
See..... exactly why I love this kind of community/resource.
Thanks Isotopsope! All great questions. I already have a considerable amount external stuff done, and I hadn't even thought about adding to the external bits, but I'm sure there is more to be done.
I'm mostly thinking of internal bit, since the motor will be torn down anyway, and it's not often a 40K motor needs to be, so might as well take advantage, right?
Here is what is already done:
Invidia Catless downpipe/bellmouth
Invidia Q300 exhaust
Blouch 380XT turbo with ported wastegate (to resolve previous boost creep)
2 stage colder plugs
DW255 fuel pump
AEM EBCS
ID 725 injectors
Cobb CAI with box
Process West TMIC
Custom tune
I might be missing something...
I can' tthink of anything external (which is why I'm here - N00B) other than maybe a header and uppipe? What else externally would you suggest?
Internal is what my main concern was. I've thought about a different crank, but that's all I really know about. I'm eager to research your suggestions.
I can afford what the normal guy with a wife will allow him . Seriously though, I'm willing to spend a reasonable amount to get a reasonable gain. I'd like to not go over $5K, since I've already got $7ish in it (more than my original budget, but I had unrealistic expectations back then).
[quote=isotopesope;39678423] Light weight fly wheel? Better clutch? quote]
I haven't converted it to a manual tranny yet. That is a project that I am both looking forward to and dreading at the same time.
KCCO!
The tuner just let me know about the bad news yesterday, and I asked him via email for suggestions. I'm always very interested in what he has to say.
As for the push-ups, that was my GF's suggestion.
Thanks! Really helpful, and I appreciate it!
Old 04-26-2013, 08:33 AM   #4
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
Why would you want to increase the compression?
If you are doing pistons, do the rods and bearings as well.
There is no need for a different crank if the oem one is in good working order.
Dr. octagon is offline   Reply With Quote
Old 04-26-2013, 08:44 AM   #5
sultan81
Member#: 309943
2012 STi
I would definitely do Inlet, TGV Deletes, Phenolic spacers, header, ewg.
sultan81 is offline   Reply With Quote
Old 04-26-2013, 09:35 AM   #6
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Add a ptp lava blanket and some dei reflect a gold to your already nice mod list!
HeroCrank is offline   Reply With Quote
Old 04-26-2013, 10:44 AM   #7
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
It's been my experience that increasing compression will also increase power, which is always good. I know that was helpful with the motorcycles I've been around, but I'm new to the car thing. I assumed it would be a viable option.
Old 04-26-2013, 10:58 AM   #8
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
I would talk it over with the guy building your block to see what he has to say about compression and the fuel/boost you'd be running on it. Don't want you blowing anything up now, do we?
Personally, I wouldn't even touch my compression unless you were running e85.
Mr Wrex is offline   Reply With Quote
Old 04-26-2013, 11:06 AM   #9
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
increasing compression is beneficial in n/a applications.
stroke it to 2.7! hahaha i had a built n/a motor in my last impreza that i had stroked out to a 2.7 with hi comp pistons, forged rods, cams, p&p, blah blah blah. it was killer.
if you're already breaching budget, perhaps leave the auto tranny alone? ipd is selling rallitek, so they are blowing stuff out for cheap... you could at least pick up one of their tranny mounts:
http://www.rallitek.com/RalliTEK-4EA...-Insert/p-4634
Old 04-26-2013, 11:42 AM   #10
Shayhan27
Member#: 205906
05 WRX
CGM
I was faced with this same dilemma a few years back.
I would do the things that are difficult to do with the engine in.
It looks like you are already going with a set of forged pistons. Depending on final power numbers your rods and crank will be fine. It does not sound like you are doing a full tear down but if you were I would deffinately say good bearings.
In the OP you speak of raising the Compression ratio I would not reccomend this. Instead do some cams. Thats the item I chose in the cosworth 272's and I love them. Get more air and fule in there and exhaust out faster. I spool my turbo faster now and hold more power to redline.
Shayhan27 is offline   Reply With Quote
Old 04-26-2013, 01:13 PM   #11
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Thanks everyone! I'm very grateful!
Yea, this is my first turbo, and it shows. Thanks for the schooling!
Calling Tuner Guy now (Dom)!
Old 04-26-2013, 02:48 PM   #12
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Ok, talked to the tuner and this is what they are going to do:
Composite TVG deletes which effectively do the job of the Phenolic spacers
Unequal length header
Uppipe
Inlet
Swap Blouch 380XT for Blouch 440XT
It's an addiction!
Old 04-26-2013, 03:12 PM   #13
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Get the TGV coated if you have the monies for it. You might as well do a 3mm spacer while you have the intake mani off. Other than that, looks like a good list. Good luck satisfying your mod bug... mine is still biting $12k later and I plan on dumping another $8k by the end of the summer
Old 04-26-2013, 03:57 PM   #14
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
I shall ask them about the coated. They were totally out of Cowbell though
Old 04-26-2013, 04:42 PM   #15
StackSmasher
Member#: 316928
2012 STI limited
Ummmm.. I dont think you can coat composite tgvs. They are plastic so I would imagine that baking them would destroy them
StackSmasher is offline   Reply With Quote
Old 04-26-2013, 05:44 PM   #16
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Good point! If I didn't feel so out of the loop about car stuff I might have caught that myself.
Old 04-26-2013, 06:11 PM   #17
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Whoopsies! That's what I get for speed reading at work
Old 04-27-2013, 11:18 AM   #18
Cinic
Member#: 349945
2015 WRX
GBP
I can afford what the normal guy with a wife will allow him....
Interesting.
Cinic is offline   Reply With Quote
Old 04-29-2013, 01:33 AM   #19
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Originally Posted by Cinic View Post
Interesting.
Yeah, I have a GF who controls my money as if she were married (Read: having a wife) to me, thereby allowing me only to afford what a normal guy with a wife can afford.
I often refer to her as my partner as well, just to make people wonder. Especially people who like to judge before knowing the story.
I find those people to sometimes be
Interesting.
but more often, ignorant.
Old 04-30-2013, 03:57 PM   #20
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
A bit off topic but this is a 10MY with 40K that quit? It's just out of warranty... Talk about bad timing..
SlimJim8804 is offline   Reply With Quote
Old 04-30-2013, 04:06 PM   #21
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Actually, is still in warranty, 5yr, 60000 mile powertrain warranty, but I'm sure they wouldn't honor it with the other mods that have been done
Old 04-30-2013, 10:08 PM   #22
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Gotcha. Not worth a try?
Old 04-30-2013, 10:23 PM   #23
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
It would be, but I've been advised that the dealership will look at how often the ECU has been flashed, and it would take 8-9 hours to return the car to stock (I'd have to pay the tuner to do that, since I don't have the tools/space/skill), then pay to put it all back on. Just too much of a risk.
If I had the time etc, I'd sure try though!
