Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 04-26-2013, 09:00 AM   #1
ewrx05
Member#: 71158
Question Help with knock issue - 07 WRX VF-48
I'm looking for some opinions on my knock issues at lower loads and lower RPMs. Please see linked data-log. Wondering if this could just be false knock or something i should work to get rid of. I've logged up to -2.8* before, typically when getting on the throttle, but this log has a random event during 60% throttle.
https://docs.google.com/file/d/0B6nG...it?usp=sharing
Car is a 2007 wrx with the following mods:
VF-48
08 STi TMIC w/ 07 STi splitter
Cobb catted turbo-back exhaust
Fuel pump
Hybrid boost control (GM BCS w/ grimmspeed MBC)
Defi Gauges (boost, egt, oil pressure)
PLX A/F gauge
I've had been tweaking the cobb stage 2 tune via accesstuner race when the car was stage 2 from 15k-100k miles, and previously had the same issue. Just recently put on the VF-48 and supporting mods and have been bringing the tune along. I haven't had any issues whatsoever above 3200 rpm, but the tune isn't finished as I'm slowing upping the boost a little at a time.
The linked datalog was done with the handheld cobb unit, but i do have a A/F gauge and can datalog that with my computer.
My tip-in values are higher than stock but i see it briefly go lean on the gauge when i stab the throttle, but haven't captured anything in a datalog yet. My CL/OL delay is currently set at 0. I've thought about raising to 100 as some others have suggested.
Before this log, i removed the heat shield and zip-tied a few things that i thought could be rattling around, but still log knock. There are some marks on the hard vac line on the TMIC, like its hitting the hood or splitter, but i haven't confirmed that they are in fact coming into contact. Could have been marked up before the install.
Any help is greatly appreciated!! Maybe further logging with my A/F gauge is in order.
Thanks!
ewrx05 is offline   Reply With Quote
Old 05-07-2013, 05:35 PM   #2
sc00ter
Member#: 117767
2011 STI Sedan
Hard to read. Can you post the log as a spreadsheet in Google docs like this?...
https://docs.google.com/spreadsheet/...0E&usp=sharing
sc00ter is offline   Reply With Quote
Old 05-07-2013, 06:27 PM   #3
ewrx05
Member#: 71158
Old 05-09-2013, 06:53 AM   #4
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
So are you running stage 2 tune or stage 3?
Black94Snake is offline   Reply With Quote
Old 05-09-2013, 07:42 AM   #5
ewrx05
Member#: 71158
i would consider it a stage 3 tune. Started off orginally with the cobb stage 2 ots map, map many changes over the years (zerod some of the timing compensation tables, changes for my hyrbid boost control), then when i put the VF48 and fuel pump in, i copied over some VF39 timing and fueling maps published on romraider. I did look at the cobb VF39 OTS maps, but timing and fuel tables didn't seem scaled out far enough, but overall comparable values to the tables im using now.
For the logs posted, i still think i have some maf scaling to be done (was logging 5% leaner than the map). Maybe that is contributing.
Just looking for some feedback on real knock vs. false knock, and the part throttle knock stuck out as something i should look into (random event at 60% throttle).
Overall, i think i need to get more data while logging AFR.
Old 05-09-2013, 07:53 AM   #6
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
it's too bad that you're still using that AccessPORT, I would have offered to take a look at your tune for you. my 07 is running a 43 right now. so would have been a good comparison.
Old 05-09-2013, 04:45 PM   #7
sc00ter
Member#: 117767
2011 STI Sedan
Wish I could be more help.
Unfortunately, I'm in a similar boat with my high boost (19psi) map. My tuner is positive it's just false knock but I've still been avoiding using it on a daily basis. Instead I stick with my 17psi map (log in 2nd post).
https://docs.google.com/spreadsheet/...EE&usp=sharing
