Old 04-27-2013, 04:17 AM   #1
dmg44
Member#: 354408
2010 WRX
Default Weird hissing sound at 4k RPM
My car is a 2010 Wrx Sedan.
My only mods right now are a CBE and COBB Ap Stage 1 93.
Recently, I just started hearing a constant high pitch whistling/hissing sound coming from the engine bay when I am WOT at 4k. Sounds like an air leak. I've had my data logs reviewed by a tuner friend and he said there is no obvious boost leak and that the car appears to be running healthy.
Here is a video of the actual sound of me doing WOT in 2nd at 3k rpm and the hissing kicks in around 4k until I left off the gas, and then continues while I'm WOT in 4th.
Any idea what is wrong?
dmg44 is offline   Reply With Quote
Old 04-27-2013, 04:51 AM   #2
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
The hiss of your turbo? Sounds pretty normal
Coreycarlile911 is offline   Reply With Quote
Old 04-27-2013, 01:03 PM   #3
dmg44
Member#: 354408
2010 WRX
well it didn't have that sound a few months ago. And I don't hear it on other WRX pull videos.
Old 04-27-2013, 01:56 PM   #4
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Have you checked you intercooler clamps, i assume you took it off to get to the back bolt ehen you installed your dp. Details are in my reply to your other post on this issue.
Cathexis is offline   Reply With Quote
Old 04-27-2013, 03:33 PM   #5
dmg44
Member#: 354408
2010 WRX
I haven't installed the dp yet. I've never touched the intercooler on this car.
Old 04-27-2013, 07:01 PM   #6
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Well with stage one and catback you are running bit more boost and the aftermarket cat back is a tad less restricted. Idk just sounds like the turbo doing its job to me. How long have you been on the stage1 map?
Old 04-28-2013, 02:19 AM   #7
dmg44
Member#: 354408
2010 WRX
about a month now
I checked all the clamps and hoses and everything seems to be snug.
Now I think about it, I first heard the noise right after installing my turbo XS CBE. My mechanic friend noticed the noise too and said that turbo is louder because its more free flowing. I am just bothered because I don't hear it on other WRX's with stage 1 and 3" CBE.
Old 04-28-2013, 06:50 AM   #8
Cathexis
Member#: 335445
2012 WRX - BLK STIG
If you didnt replace the dp you likely wouldnt hear anything from the turbo because of the restrictive cat. I had issues getting my dp on so i drove around for awhile with a cbe. Once i got the catted dp on, i only just could hear some turbo whine, no hiss. The only hiss i get is from the cold air intake. Have you checked the mating of your cbe to stock dp for a possible leak. Will be really easy to spot if you've been hearing it for a month, it will have black carbon streaks where its leaking. I ditched the spring bolts for a more traditional, tight fitting, nut and bolt.
If thats not it, do a log. Log a third gear pull, and do a short cruise log. Post it on google drive or better google docs, make it public, and let's take a look at your fuel trims.
Old 04-28-2013, 10:07 AM   #9
C3hutson
Member#: 347969
04 STi
JBP
I'm pretty sure I hear more turbo just from adding the nameless muffled axleback. A new noise has started since the install at full boost... Kind of a low pitch hiss...
C3hutson is offline   Reply With Quote
Old 04-28-2013, 06:59 PM   #10
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Yea that's most likely what your hearing. You could do a log and make sure boost and everything is up to par but from the video it doesn't sound like you have anything bad going on.
Old 04-28-2013, 07:39 PM   #11
bootystank
Member#: 354475
2011 WRX Hatch
Satin white pearl
if your that worried do a smoke test. But when im on the highway i hear my turbo hiss/whine from 2500 to 4500 rpms and i Can make it louder of quieter just with my foot
bootystank is offline   Reply With Quote
Old 04-28-2013, 09:03 PM   #12
cond
Member#: 339416
2015 STI
Yea I also recently started noticing a hiss after stage one map and namless axleback. Think its fine as long as your not over boosting or anything
cond is offline   Reply With Quote
Old 04-28-2013, 09:38 PM   #13
dmg44
Member#: 354408
2010 WRX
I just had my car on the lift today while we were installing my dp and I noticed an exhaust leak from the stock dp to turbo xs cbe. After going stage 2 today and fixing the leak, I don't think I hear it as much. But I wasn't paying attention because I was too distracted by how awesome stage 2 is and the new sound of my catless downpipe. But I'll post my log in a few days.
Old 04-28-2013, 10:07 PM   #14
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Awesome!!!
Old 04-29-2013, 06:32 PM   #15
dmg44
Member#: 354408
2010 WRX
Thanks for all your help!
