Old 04-27-2013, 09:48 PM   #1
Theglovebox
Member#: 353701
Default Starter not getting power
My car decided it didn't want to start anymore so I replaced the starter and it still didnt start.
I've narrowed it down to the small wire on the starter solenoid not grtting power when the ignition is turned it does not get power I tested it with a test light. What do I do
Theglovebox is offline   Reply With Quote
Old 04-27-2013, 09:54 PM   #2
Aron_WRC
Member#: 337384
You checked your battery obviously.... right?
Aron_WRC is offline   Reply With Quote
Old 04-27-2013, 10:44 PM   #3
Theglovebox
Member#: 353701
Yea battery has full power
Old 04-28-2013, 12:09 AM   #4
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
Is your clutch switch working?, check that. Next I would check the starter interlock relay, what it is called on the wiring diagram. If neither of those it has to be a power issue before the ignition switch.
If an auto you have an inhibitor switch, which I would assume is by the gear selector, that is in place of the clutch switch. There is also no relay in this system.
If you have the subaru security system. There is an additional relay that is controlled by the security module. No idea where this is relay would be. Also if you have security system, could be the security module itself. This whole system can be easily overridden by shorting the correct pins together, this is how the system is if you dont have the OEM security system installed.
Would really help if you had a multimeter as a test light is not going to measure continuity of the clutch switch, it is a ground path. Can easily just short the switch if you can't measure it, just remember to not have the car in gear when trying to start.
Hopefully this is enough info, good luck.
Last edited by John__Gotti; 04-28-2013 at 12:11 AM. Reason: just wanted to add to my reply.
John__Gotti is offline   Reply With Quote
Old 04-28-2013, 01:35 AM   #5
Aron_WRC
Member#: 337384
Old 07-28-2013, 11:52 AM   #6
jdkeck8695
Member#: 361561
1995 impreza wagon
green
i am having the same issue, I found the starter relay I also have a relay mounted to the right of the driver, behind the radio, that clicks when i turn the ignition switch, i have the clutch switch jumped so i do not have to press the clutch, next i am going to try to test power, if i can, to the connectors, starter solinoid and the relay behind the radio, anyone have any other suggestions??
jdkeck8695 is offline   Reply With Quote
