Old 04-28-2013, 01:19 AM   #1
DKdekes
Member#: 343785
2013 WRX
Default single exit exhaust inquiry
I got the invidia n1, which is a single exit exhaust, and was looking under the car the other day and realized that there is a gigantic cavity from the absence of the muffler of the stock exhaust (hatchback). This looks like it would have an effect on the car in some way. So has anyone noticed any problems (eg gas mileage, handling problems arising from turbulent air) from this cavity?
DKdekes is offline   Reply With Quote
Old 04-28-2013, 01:41 AM   #2
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
OMGHi2U
Never thought about this but makes sense there might be some consequence to this change...interested in hearing what others have to say...
garzdos is offline   Reply With Quote
Old 04-28-2013, 02:42 AM   #3
Thunderpaw
Member#: 242205
2009 wrx
blue
A strong wind would affect your mpg more
Thunderpaw is offline   Reply With Quote
Old 04-28-2013, 08:22 AM   #4
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
...........Are you one of those guys who think a fart would make a car "unstable"?
FWIW, it's an exhaust... get it wind tunnel tested of you're worried. -_-
Navendra94 is offline   Reply With Quote
Old 04-28-2013, 09:29 AM   #5
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
OMGHi2U
In a way it is comparing apples to oranges, but I know from personal experience that when I had a pick up truck there was a noticable difference when it came to strong winds or increased speeds if the back of the truck was empty or not and if the tail gate was up or down. I mention this because, while smaller on the bottom of theSubie, both are a "pocket" of empty space and I can see how aerodynamics might change (however slight or minimal this might be).
I don't have the answer but it just seems the OP's question/concern is not unreasonable.
Old 04-28-2013, 10:58 AM   #6
S1CkWrx
Member#: 325249
2012 wrx
dgm
who cares just drive the car
S1CkWrx is offline   Reply With Quote
Old 04-28-2013, 11:17 AM   #7
some dude
Member#: 100300
06 WRX
CGM
No, I think you should care and not drive the car.
some dude is offline   Reply With Quote
Old 04-28-2013, 11:55 AM   #8
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
I think you'd have to take pictures of the bottom to judge? I can't picture the cavity. If it is a smooth entrance and exit to the pocket no worries. If it bleeds off to hit the inside of the bumper it could cause you to lose some mpg's. <shrug>
Need more information to judge I guess.
Napalm3nema is offline   Reply With Quote
Old 04-28-2013, 01:13 PM   #9
borderguy
Member#: 333855
1999 Forester S
2011 Forester X
This is ****ing retarded.
borderguy is offline   Reply With Quote
Old 04-28-2013, 01:25 PM   #10
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Empty cavities tend to have similar properties to ones that are filled. similar to a pickup truck with the bed closed, a vortex forms and creates a cusion othat new air flows smoothly over. Same thing happens in a liquid. You needn't worry.
Cathexis is offline   Reply With Quote
Old 04-28-2013, 07:56 PM   #11
urabuster
Member#: 266578
2003 WRX Sportwagon
Look up why a golf ball is dimpled.
urabuster is offline   Reply With Quote
Old 04-28-2013, 08:12 PM   #12
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
OP, are you driving the car in a race track?
Doing a top speed run at Bonneville??
Over active imagination?
Seriously, you're over thinking things. It's a Subaru, not a Ferrari.
Loyale93 is offline   Reply With Quote
Old 04-28-2013, 08:59 PM   #13
Knale
Member#: 311886
2012 WRX
Lighting Red
Unless you are tracking this car, I would be more concerned with the aesthetic's of that big gapping hole that was left behind. I wonder if there are any aftermarket remedies for this
Knale is offline   Reply With Quote
Old 04-28-2013, 09:33 PM   #14
MorganJ
Member#: 203823
2009 WRX STI
2001 V7 JDM STI
I bet it would start to affect the car in speeds above 150mph
MorganJ is offline   Reply With Quote
Old 04-28-2013, 09:33 PM   #15
Screaming_Emu
Member#: 137003
2002 WRX Sedan
I like tacos.
Screaming_Emu is offline   Reply With Quote
Old 04-28-2013, 10:17 PM   #16
lwszabo
Member#: 351492
2013 Impreza
satin white pearl
Originally Posted by Screaming_Emu View Post
I like tacos.
Have you tried the cool ranch one yet?
lwszabo is offline   Reply With Quote
Old 04-29-2013, 01:25 AM   #17
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
Yes, it will certainly have an effect and small aerodynamic changes can have huge effects on stability even at speeds as low as 70-80mph.
I can tell a massive difference in the handling at highway speeds when I remove the undertray for example.
It would be pretty simple to solve your problem by building a makeshift diffuser out of ABS or another material.
p951951951t is offline   Reply With Quote
Old 04-29-2013, 09:34 AM   #18
08wrbrex
Member#: 293186
2006 WRX
Nacho cheese is still better
08wrbrex is offline   Reply With Quote
Old 04-29-2013, 11:11 AM   #19
11wrx_dude
Member#: 311747
2011 wrx
white
No way cool ranch ftw.
11wrx_dude is offline   Reply With Quote
Old 04-29-2013, 02:49 PM   #20
ber2z
Member#: 330636
2009 WRX
Most likely a recirculation region will form in that pocket. There should be minimal effect. Worst case scenario is that it causes the flow to separate increasing drag. The whole golf ball dimple thing is a little different. The dimples trip the boundary layer to go turbulent which will stay attached longer.
ber2z is offline   Reply With Quote
Old 04-29-2013, 11:08 PM   #21
DKdekes
Member#: 343785
2013 WRX
sorry about not watching the thread. il take some pictures tomorow to show you. And for those who are being stupid and/or saying if i dont track my car it doesnt matter, the reason they make the shape it is is to keep it as aerodynamic as possible, (with the exception of tmic on our cars i guess). il also post a few drawings right now possibly to diagram the situation a bit. Those of you talking about a turbulent air cushion have me listening
Old 04-29-2013, 11:30 PM   #22
LUMBERZACK
Member#: 340009
2007 STi
48W
LUMBERZACK is offline   Reply With Quote
Old 04-30-2013, 10:03 AM   #23
borderguy
Member#: 333855
1999 Forester S
2011 Forester X
Happy Taco Tuesday everyone!
Old 04-30-2013, 10:25 AM   #24
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
I saw a silver STI hatch with flaps and a flat-black N1 on NASIOC a while back and it looked wicked. So nice. I decided to stay with my stock exhaust for volume reasons, but if I were to go with a CBE, I'd have no reservations about dropping the quadtip for a flat-black N1.
blehhh is offline   Reply With Quote
Old 04-30-2013, 10:53 AM   #25
greenplates
Member#: 239162
Weight differences will not be noticeable
Horsepower gains will not be noticeable
Sound may be different
Appearance will be different
Which allows greater flow of exhaust? A more direct path to exit OR a multi routed exit?
[open headers ftw]
greenplates is offline   Reply With Quote
