Old 04-28-2013, 02:31 AM   #1
renblock
Member#: 347310
Default 2006jdm wrx avcs heads max rpm ?
currently running old skool fp red on forged 207 block. wanna know if my stock 2006 ej205 heads can safely rev to 8000rpm ?? anyone has anytakes or advice on this az ive heard the head in the jdm avcs wrx 2006 and later supposed to be same or az good az jdm ej207 heads...
renblock is offline   Reply With Quote
Old 05-01-2013, 10:29 AM   #2
renblock
Member#: 347310
i am currently swinging 7800 rev limit so i think im gonna go back to 8000. my mechanic vouged that the head is capable of this as he himself opened it up before during the build. the ports and cams seem the same as the ej207. if anyone have any thing to share plz feel free !
Old 05-01-2013, 03:14 PM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Dunno if the springs are the same though. ports and cams won't dictate safe redline, just how it breathes.
What you need to know is:
1) are they shimless buckets (if so, you're good)
2) are the springs the same (if so, you're good, if not, you should probably keep the redline lower.)
Concillian is offline   Reply With Quote
Old 05-02-2013, 09:36 PM   #4
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
If shimless you are good till 800), but depending on boost you may or may not get valve float, all I know is that stock 207 v8 heads with +1mm valves don't like 9500-10000 for to long
seanathanq83 is offline   Reply With Quote
Old 05-04-2013, 09:34 PM   #5
renblock
Member#: 347310
thanks guys im gonna drop it back to like 7800 it seems im not making power beyond 7100 or 7200 so when i dyno i will post results ! thanks guys !
Old 05-04-2013, 10:00 PM   #6
jura11
Member#: 255146
2001 2002 WRX Wagon
WR BLUE
As above 7800RPM limit is on JDM WRX,JDM STi has have limit at 8250RPM
Jura
jura11 is offline   Reply With Quote
