Old 04-28-2013, 06:15 PM   #1
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
Default Ripping through oil
Burning about a quart of oil every 800-1000 miles. Just had compression test and I have 130psi in 2 and 127/128 in the other 2. Just put conventional oil in for a cycle as someone suggested it might be a ring land just not seated properly. I am noticing a patch of black specs under each tailpipe after running for a bit. Looks like carbon and water maybe oil? No smoke from tailpipe at all. 2011 WRX turbo back exhaust. High flow cats 39000 miles plus tune. Any ideas?
Avoegeli is offline   Reply With Quote
Old 04-28-2013, 06:23 PM   #2
ringlander
Member#: 336100
2011 sti
Rings not seated at 30xxx miles. Stop listening to that person. Do a leak down test. That will give you your answer.
ringlander is offline   Reply With Quote
Old 04-28-2013, 06:24 PM   #3
SpongeBobSquarePants
Member#: 296048
2011 STI
Blurple
A leakdown test is in order
SpongeBobSquarePants is offline   Reply With Quote
Old 04-28-2013, 06:30 PM   #4
ringlander
Member#: 336100
2011 sti
You should also research similar threads. Tons of test information. If you knew enough to run a compression test you should know what other tests are valid at this point. Start with the worst compression test then leak down test if it is OK (prob not) then you need to start taking things apart inter cooler (check for oil) down pipe same inspect turbo ect ect
Old 04-30-2013, 09:33 AM   #5
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
So I took my car back to Subaru for a leak down test. They are telling me it's a waste of time without an oil consumption test. They are telling me If they follow these steps and evaluate the oil burn they will fix it under warranty if its severe consumption. They are also saying SOA says a quart per 800-1000 miles is normal. Now they know I put on exhaust and tuned the car how can that be a warranty job?? No oil in the inter cooler either.
Old 04-30-2013, 09:34 AM   #6
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
I'm asking them to check my turbo seal and down pipe for oil.
Old 04-30-2013, 09:45 AM   #7
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
That much isn't normal.
A-man07 is offline   Reply With Quote
Old 04-30-2013, 09:48 AM   #8
ringlander
Member#: 336100
2011 sti
1qt per 1k is such a bad spec that is terrible. And it seems you know how much oil you are burning. Its going somewhere
Old 04-30-2013, 09:58 AM   #9
Saevus
Member#: 284152
2003 WRX
The spec on Subaru's oil consumption sheet is greater than 1qt every 1200 miles would be excessive. If you didn't tell them about the tune, they may not know or they may not care.
Saevus is offline   Reply With Quote
Old 04-30-2013, 12:20 PM   #10
GrumpyPitbull
Member#: 313311
I believe that Subaru gives the generous oil use spec due to their love of 5w30 oil.
Years ago, the Mazdaspeed 3 had issues with oil burning. It turned out that the recommended 5w30 oil would shear down and seep past the turbo seal. This caused smoking and massive oil consumption. Guess what Mazda's fix was ... 5w40 oil.
I tell this story to anyone who has a new turbo car which is using oil. Switch to 5w40 and see what happens ... Might be an easy fix for you, and the 40wt oil is far better for a turbo application anyhow.
GrumpyPitbull is offline   Reply With Quote
Old 04-30-2013, 01:00 PM   #11
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Yea next oil change hit walmart and pick up rotella T6 5w 40 its pretty cheap and is a good oil. Like the other guy said 5w 30 is just to thin even tho that's what is recommended. if you are useing mobil 1 like most people think they should use your oil consumption should go down by switching to T6.
Coreycarlile911 is offline   Reply With Quote
Old 05-14-2013, 11:21 PM   #12
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
Ok, consumption test done. I was told by Subaru to drive 1000 miles on the new oil change and they would drain oil and measure it to see how much I'm going through. After 550 miles I checked the oil and I had maybe a 1/4 inch on the bottom of the dipstick. At 700 miles I had no oil on the dipstick. Subaru asked me to bring in car immediately and not drive the suggested 1K. Anyway I took it in this morning and drove off in my loaner. I am curious to see what they say and what they will and will not cover under warranty.
I also am not sure what to do next. If its my rings I'd rather have AndrewTech build me a motor. What do I do with the block should Subaru offer to fix it? If Subaru fixes it does it affect my tune via accessport? What do I do next? If its requiring a rebuild should I just refuse the warranty work and drop performance pistons in and forged rods? Dilemma. Although If Subaru says they won't warranty it because of tune and slight mods I just have AndrewTech rebuild it.
Old 05-14-2013, 11:36 PM   #13
meebs
Member#: 3251
2009 WRX Hatch
There is no dilemma. If you left your access port map on there and they see it, you are likely SOL on a warranty... I don't understand why people do not get this. You have taken the vehicle beyond stock. They don't write warranties to protect people who want to live outside of the control set.
meebs is offline   Reply With Quote
Old 05-15-2013, 01:00 AM   #14
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
Well if they don't warranty it what have I lost. By bringing it to them? I didn't expect them to fix it anyway. If you read the thread I took it to them for a compression test that I paid for. I asked them to do a leak down test which I was gonna pay for. They recommended the consumption test and warranty route knowing I tuned the car. If they tell me I need new pistons ill take it to have a build done. Probably have them install PPG'S also while they have it at AndrewTech. I just need to know where the oil is going before I make the drive to Maryland.
Old 05-15-2013, 09:31 PM   #15
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
Default warranty work complete
So I picked my car up from Subaru this afternoon. They confirmed the oil loss and it was 2 quarts over 700 miles. Insanity!!!! They gave me a brand new Turbo saying i had a hairline fracture in the waste gate and there was some residual oil in the down pipe and intercooler hose. they filled me up with oil and asked me to drive another 1000 miles. Process of elimination? i guess. Seems odd to me that i could lose 2 quarts of oil from my turbo and not see smoke from my exhaust. could the cats be hiding the smoke?
Anyway, to those who say you can't walk into a dealer where you bought your car and have warranty work done after you modified it, I say yes you can. I left my car with Subaru for only 2 days and this is the service i got. To be honest i don't think this if gonna resolve the issue with oil consumption. Where the heck is my oil going?
Old 05-15-2013, 11:46 PM   #16
tjmazz13
Member#: 291681
2004 Pearl White STi
IAG Stage 4, S363SXE
I'm kinda in the same boat as you. Burning about the same amount of oil as you. 130-140psi across all 4 cylinders. No leaks anywhere. Changed the pcv valve. Haven't checked turbo for shaft play or downpipe for oil but there is oil coming out of my blow off valve.
tjmazz13 is offline   Reply With Quote
Old 05-16-2013, 09:22 AM   #17
Dr. octagon
Member#: 171127
2015 Subaru
The following amazes me:
1. You are still driving the car knowing that it is "ripping through oil"
2. You have a warrenty, why is the car not sleeping with the dealership. Do you really believe that the dudes in the service area have any idea of what they are talking about.
3. Dealerships oil consumption test : Fill'er up and come back........oils gone......filler'up and come back....oils gone.........okay heres a brand new turbo..........fill'er up and come back.........motors blown up.
4. Take the car to the dealer with the accessport hooked up
5. When the car is blown up, you trust these dudes to "rebuild" the motor/warrenty the motor..........knowing that they know the ecu has been tuned?
6. Would a leak down test and additional compression test (hot) not put an end to the guess work?
Dr. octagon is offline   Reply With Quote
Old 05-17-2013, 11:46 PM   #18
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
[IMG]gropen://0/Subaru%20invoice.%20.pdf?cc=1[/IMG]
Old 05-18-2013, 01:46 PM   #19
Sypher
Member#: 106366
2006 WRX
a hair line fracture in the wastegate is NOT going to cause oil consumption issues, HOnestly if you had blown turbo seals your car would be smoking its ass off. Try this, goto a hill on an incline park your car (could be a driveway too), let it sit for about an hour so it cools off, then start it, if it puffs out blew smoke then its not your turbo its rings or valve seals.
Sypher is offline   Reply With Quote
Old 05-19-2013, 03:34 AM   #20
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Did I miss the results of the leakdown test?
SlimJim8804 is offline   Reply With Quote
Old 05-19-2013, 09:17 AM   #21
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
No you haven't missed anything. Subaru didn't want to perform a leak down test. They instead gave me a new Turbo and oil change and sent me on my way. Aske me to come back in a 1000 miles. They are just wasting my time. Within a 100 miles of turbo change I've developed a vaccuum leak. I think the bov to manifold hose popped off. They want to pull my manifold to fix it and charge me $500 in labor. And they suggest I get rid of my Perrin inlet hose. Bogus man.
Old 05-19-2013, 10:20 AM   #22
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
I just watched the perrin inlet hose install on youtube and they claim to get it done in 30 minutes without pulling the manifold. Subaru wants to pull my manifold and charge me $500 labor and $170 for a stock intake hose. Why don't they just remove the TMIC which takes all of 2 minutes and work on it from the back side where the leak is?
I guess here in lies the problem with going to dealer mechanics modified. I'm not looking for warranty work i just want to find a qualified mechanic and if i can't find one at Subaru i guess i need to go to a shop and pay out the ass. Living in NYC we are kind of screwed with labor costs and distance to shops.
Any super qualified mechanics out there who want to help me out?
Old 05-19-2013, 10:35 AM   #23
Avoegeli
Member#: 266911
2011 Impreza WRX
Dark gray metallic
couldn't agree more
Old 05-19-2013, 04:59 PM   #24
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Dude go some were else or just fix it yourself that hose has nothing to do with your inlet anyway. It fell off the back of your intake manifold just reach under your tmic and feel around you will be able to get it back on I have done it before. Also that perrin unit is 100x better then the stock unit I personally run it after my stock unit tore and it is a quality piece. It sounds like a leak down is in order if your turbo was eating that much oil you would be leaving james bond size smoke screen behind you.
nate_fisher is offline   Reply With Quote
Old 05-19-2013, 05:25 PM   #25
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
+1 on the leakdown test.
Head out to long island, there's a ton of good shops out there that work on/build/tune subes and evos that i'm sure would do 1000x better job helping you+ advising you, for cheaper too.
