Old 04-29-2013, 03:26 PM   #1
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
Default 2005 sti Idle, Stall problems and Acceleration
Hey guy's this is my first post on here. Just have almost a full month with my STi and i Love it its the best car ever and plan on keeping mine for the longest possible.
So onto the problem
Just today on my way to school, I left my house perfectly fine, then when on the highway in 6th gear I was going to pass a slower car and the acceleration on it felt weird, like if something was holding the car back. i downshifted to 5th still kind of did it then when i was in 4th the power was normal. and I was not using my AC.
Then when arriving to my school, I stopped at a crosswalk to let people walk and my car idle fell to 0 and bounced up to normal then came down and car turned off. I then turned it back on and it started up back normal. then when i parked I stayed inside for a min and the idle kept bouncing and the car turned off again.
Has anyone had this issue before?
Mods on the car are: TurboX/s Bov, Aftermarket Catback, and CAI.
and No check engine lights, or blinking cruise control lights showed up.
can someone please help, and/or give me some idea's/thoughts to what you think might be the problem.
Thanks
Frank19 is offline   Reply With Quote
Old 04-29-2013, 03:29 PM   #2
alecb
Member#: 335146
2004 STi
Are you tuned for your mods?
alecb is offline   Reply With Quote
Old 04-29-2013, 04:02 PM   #3
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
It wont stll because of a lack of tune, check the BOV, it bet its sticking open.
Cards2323 is offline   Reply With Quote
Old 04-29-2013, 05:57 PM   #4
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
no, im not tuned. but its been running 100% fine. Our mechanic checked it the first week i got it and he said i was fine. he just suggested the stock bpv and a carb legal intake for smog regulations to not have problems.
ill check the Bov forsure. And also what i got yesterday is a Chirp coming from the engine bay. Looked up here on the forums and said its from the AC. Could that belt needing to be tightened be part of the problem aswell?
Old 04-29-2013, 06:45 PM   #5
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
just got home finally and on way here cruise control light started flashing
Old 04-29-2013, 06:53 PM   #6
ImprezaWrx9
Member#: 86938
2003 Impreza Wrx
Get rid of the bov and cai unless you're getting a tune.
Could it be this?
http://forums.nasioc.com/forums/showthread.php?t=781242
ImprezaWrx9 is offline   Reply With Quote
Old 04-29-2013, 07:01 PM   #7
DansSpace
Member#: 157029
'13 Mazdaspeed3
Vacuum leak?
DansSpace is offline   Reply With Quote
Old 04-29-2013, 07:40 PM   #8
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
No vacuum leak. main thing i know forsure is my Bov causing the idle. and i think the Maf sensor is throwing the Cursie control to flash and CEL to turn on.
Old 04-29-2013, 08:13 PM   #9
Ruhh-Roh
Member#: 349889
2007 STi
Edit: wait, at what point did you start to have a CEL? At first you didn't and now ya do.
Ruhh-Roh is offline   Reply With Quote
Old 04-29-2013, 09:03 PM   #10
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
yess. at first it their was nothing going to my college. estimated 25 miles away highway driving. 3/4 way back the cruise control light started flashing. with the CEL. Idle is really bad now. is prbbly at 50 not even 100 and boggles/jitters and slowly pull to about 5-600.
Old 04-29-2013, 09:08 PM   #11
rdowner22
Member#: 329284
02 WRX Sport Wagon
idk why no one has torn you a new one yet.... you need a tune for your cai. read Unabombers Manifesto. Clean your MAF as well.
rdowner22 is offline   Reply With Quote
Old 04-29-2013, 10:43 PM   #12
Brent22
Member#: 350169
2013 WRX Hatch
I think we're getting fatigued.
Brent22 is offline   Reply With Quote
Old 04-30-2013, 03:56 AM   #13
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
Will be replacing the intake with stock, aswell as the bov with a stock bpv. Maf was checked and it was fine. Also was checked for vacuum leaks and nothing. their was somthing electrical going on according to my mechanic. its running fine now how it used to be. but forsure taking the cai. the 1st owner put it just to put it. and Ive read in the forums that the stock airbox is good till 400hp.
Old 04-30-2013, 03:57 AM   #14
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
thanks to everyone for the inputs.
Old 04-30-2013, 06:17 AM   #15
chapstien
Member#: 68284
1988 Corolla SR5
0-points
Did you get the code pulled?
chapstien is offline   Reply With Quote
Old 04-30-2013, 01:36 PM   #16
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
Not yet, but im not driving it for safety, dont want to cause any damage to it. not risking it. it should be getting checked today at a shop.
Old 04-30-2013, 01:45 PM   #17
Scanyland
Member#: 282593
1996 Subaru Legacy
props to you for doing this, I can't tell you how many people ive seen continue to drive the car with an unknown problem that ends up making things worse.
Scanyland is offline   Reply With Quote
Old 04-30-2013, 01:47 PM   #18
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
First let me just say that you are on the right path by not choosing to drive it until it is fixed, swapping to an intake that you are actually tuned for, and getting rid of the turboxs bov. The turboxs valves are notorious for leaking, and a cold air intake without a tune can cause alot of issues if it flows more than the ecu can correct.
With that said...
Originally Posted by DansSpace View Post
Vacuum leak?
...if your valve is leaking and you aren't in boost, what does that then become?
...just trying to get you to think about what you said for a second...
amalgrover is offline   Reply With Quote
Old 04-30-2013, 02:18 PM   #19
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
Thanks guys. and yea i rather wait a week to find the problem and then fix it. then to drive it the rest of the week and blow it up.
Old 04-30-2013, 02:21 PM   #20
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
With that said...
Hmm... true... idk really. i just took it to my mechanics house yesterday and he tried his scanner but it didnt pick up anything. so today at the shop where he works he was going to try it their. just need to take him the car. Im being patient because he's busy doing other things but he told me alrrady that if he calls me i can take it he'll use the scanner, pull of the code. and then go from their. but yea he already told me to get rid of the cai. that one being first. and stock bpv after.
Old 04-30-2013, 02:24 PM   #21
berge56
Member#: 56754
2004 Hybrid 2.5XTR
RIP [email protected]
When you checked the maf did you clean it with MAF cleaner? A lot of times they look fine but are really dirty.
Props for not driving the car with the issue.
berge56 is offline   Reply With Quote
Old 04-30-2013, 02:25 PM   #22
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
My mechanic also checked for a vacuum leak with if i remmbr intake cleaner?( am i right) it was some type of spray and he told me i didnt have one. he just believes its the cai because of more airflow throwing off the ecu, and the iddle problem from the bov.
Old 04-30-2013, 02:27 PM   #23
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
No i did not. im not a mechanic. and the car is just here at home. And to me i rather be patient and have a professional do everything. i dont like to take small risks of me doing somthing stupid and then even having to replace the MAF after. i have no problem in waiting.
but i will tell my mechanic to do that. thanks.
Old 04-30-2013, 03:08 PM   #24
Frank19
Member#: 354950
2005 Subaru wrx STi
Wrb
hey guys, even if the Bov is 50/50. its the hybrid turbo Xs. can that still be causing the iddle problem? or only fully atomspheric bov cause that.
Old 04-30-2013, 04:30 PM   #25
Anubis80
Member#: 341903
2016 STi
Hyperblue
yeah QFT right there
Anubis80 is offline   Reply With Quote
