Old 04-29-2013, 09:29 PM   #1
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
I'm building my car after blowing up the stock engine. My goal is over 300awhp on a vf series turbo.
What I have:
Ej205 in the process of being rebuilt
ACL bearings
Balanced lightened and knife edged crank
Re-seated valves and port and polished head (stock valves, cams, etc.)
My plans:
Vf series turbo (because they are cheap enough and I plan on having a anti-lag tune for autoX)
850cc injectors
Water/meth injection
DW 300 fuel pump
EWG 38mm tial
Invidia 3in catless downpipe
Phatbotti tune for 93 octane
Bigger tmic (not sure what brand yet)
What I need to know:
What pistons should I run? (Higher compression, etc?)
Is my goal possible with this setup?
What else should I invest in? This is my daily too
Thanks in advance
dburgoon is offline   Reply With Quote
Old 04-29-2013, 09:34 PM   #2
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
With meth it might be possible, i made 289whp with my vf43 straight 93. Get some forged pistons with stock or slighty higher compression should be fine.
Str8Gone is offline   Reply With Quote
Old 04-29-2013, 09:35 PM   #3
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
proven power section......search..........your answers are within. Seriously that is where i would be looking for vf series high output.
And on what dyno would this 320awhp be found?
Dr. octagon is offline   Reply With Quote
Old 04-29-2013, 09:38 PM   #4
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
forget the Meth and get a Blouch 16g-xt-r and 850cc injectors
At 21psi I was 310whp/301tq with 565cc injectors ( 98% duty )and a Process West TMIC all on 93 pump gas. Spooled up like a stock TD04
dangerousatom is online now   Reply With Quote
Old 04-29-2013, 09:42 PM   #5
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
I tried, the answer was not clear because no one had the raw numbers from the dyno, they were all adjusted and that's not very trustworthy to me. And they are all against meth it seems to me.
Whichever dyno import image uses I guess, I'm going to get my tuning done there
Old 04-29-2013, 09:43 PM   #6
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
I have heard the spool on 16g is slower, also they are a bit much for me if I want to run an anti-lag system.
EDIT: I guess if I didn't run the ALS and without meth the 16g would be about the same cost and it would last longer than a vf
Old 04-29-2013, 10:16 PM   #7
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
on a mustang dyno no. on a dynojet prob about 70% chance. hp is relative not absolute so it shouldnt even be discussed any furthur.
WhiteBgeye02 is offline   Reply With Quote
Old 04-29-2013, 10:26 PM   #8
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Makes sense, I got the answer I wanted. Just curious as to if I should just stick with stock pistons or go with something with a little higher compression?
Old 04-29-2013, 11:18 PM   #9
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
considering you're already rebuilding the 205 you might as well go with better pistons instead of buttoning it up and having something go wrong b/c you're pushing stock cast pistons to their limits and having to tear the block apart all over again. As for which pistons to get you need to contact mikey and go over your plans with him. He'll guide you in the right direction.
brew02wrx is offline   Reply With Quote
Old 04-30-2013, 01:08 AM   #10
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Having gone through 5x different turbo swaps on my ej205, i would say it's very unlikely you'll hit 320whp with any VF turbos on the ej205, especially the cheap and plentiful kind.
Here's my setup with the vf39 along with the tomei 7760 for reference.
http://forums.nasioc.com/forums/show...ighlight=tomei
You don't want to run higher compression than stock. You will make less power on pump, because of knock.
Fierysun is offline   Reply With Quote
Old 04-30-2013, 08:59 AM   #11
wrxlaunch
Member#: 181298
What I have:
ACL bearings
My plans:
850cc injectors
DW 300 fuel pump
EWG 38mm tial
Thanks in advance
320whp not likey with a vf on a 2.0 using 93oct. Why waste money building a 2.0 instead of a hybrid swap? Way more trq to have fun with
wrxlaunch is offline   Reply With Quote
Old 04-30-2013, 11:45 AM   #12
quazimoto
Member#: 70395
2.1 stroker.......
quazimoto is offline   Reply With Quote
Old 04-30-2013, 12:09 PM   #13
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Because I wasn't given a ej25, I had someone give me a ej20
Old 04-30-2013, 12:22 PM   #14
wrxlaunch
Member#: 181298
Stock trans?
Old 04-30-2013, 12:25 PM   #15
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
Originally Posted by quazimoto View Post
2.1 stroker.......
This hopefully
Old 04-30-2013, 12:27 PM   #16
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Stock trans?
For now. I have 6 speed plans in the future
Old 04-30-2013, 12:29 PM   #17
RIBahler
Member#: 326537
2005 WRX STi Wagon
Crystal Grey Metallic
It is possible to get 320awhp on a VF43 with a 2.0. Here is proof on my project for your reference.
http://forums.nasioc.com/forums/show....php?t=2413383
RIBahler is offline   Reply With Quote
Old 04-30-2013, 12:38 PM   #18
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Awesome! Thanks, how's the tranny holding up?
Old 04-30-2013, 01:06 PM   #19
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
My ej205, headers, full exhaust, VF34 iwg, ebcs, aps tmic, and id 750's made 295whp on Cobb Plano's Mustang dyno. I would think with E85 or meth, 320 wouldn't be a problem. But I don't know correction factors blah blah blah... it was using. It's on their dyno database if you are intrested.
2gnt2wrx is offline   Reply With Quote
Old 04-30-2013, 01:11 PM   #20
RIBahler
Member#: 326537
2005 WRX STi Wagon
Look here for the answer.
http://forums.nasioc.com/forums/show....php?t=2489333
Old 04-30-2013, 01:23 PM   #21
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Sweet! Maybe mine will pop too so I can justify and sti swap
Old 04-30-2013, 01:43 PM   #22
quazimoto
Member#: 70395
Does everyone understand dyno variances and the variables involved with WHP numbers?
OP........stop being fixated on peak whp numbers. You obviously are very naive as far as WHP and the variables involved go considering your posts/responses. The before/after power curve is where it is at,not the peak numbers.
Old 04-30-2013, 01:58 PM   #23
RIBahler
Member#: 326537
2005 WRX STi Wagon
Of course and I agree!
Old 04-30-2013, 02:33 PM   #24
BoboTheMonkey
Member#: 224615
2004 WRX
San Remo Red
I made nowhere near that, but it was a mustang dyno on 91. With 93 and meth, I would think you could get over 300 on a non mustang dyno fairly easy. Just a question though... Why are you running 850cc injectors with meth? 565's are typically plenty for a vf series turbo and with meth, you need even less headroom.
BoboTheMonkey is offline   Reply With Quote
Old 04-30-2013, 03:41 PM   #25
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
I could care less about peak numbers, I'm more concerned about where I make the power. I know the variables on dyno differences, I build miatas for a living and the numbers we put down on our dyno vary greatly from that of any other dyno, but we still build the fastest specs in the region.
I was just curious as to what numbers I could expect and/or shoot for with the set up I will be using.
I guess I should change my question too, "where will I see my power?" Is that better?
