Welcome to the North American Subaru Impreza Owners Club Saturday September 20, 2014
Old 04-30-2013, 01:59 AM   #1
Leo05suby
Member#: 307286
05' EJ25 - Stock
Metallic Gray
Default my 2005 STI reached 104000+ mile
I've been meaning to post this for quite sometime. My STI reached 100000+ miles. So far the car runs great and had no problem with it whatsoever. Bought the car brand new and NEVER went back to the dealearship after that nor had any engine repairs done at any car shop. I did all the maintainance by myself. I never trusted the dealership or any local shops to do it.
I used to drag race quite a few times when it was still below 30000 miles. after that, its mostly spirit driving and some highway pulls. The fastest I went with the car was 148mph...Today, the car still pulls like a beast to 100+.
Some history with the car:
Car got broken into twice and the ignition console was ripped out but the car thief was unable to drive the the car far enough (maybe beacuse of the auto kill switch installed, maybe?). Insurance took care of it, and it was all fine and dandy.
You guys might hate me for this but...I had been using the same K&N typhoon filter since it was at 18000 miles, just cleaning and washing it occasionally... and never had a problem with it. I promise I will change it sometime this year.
I have yet to change my transmission fluid since I bought the car and its still shifting smoothly. Again, I will also change it sometime this year.
Same clutch.
same rotors
I just recently change the spark plugs a week ago with NGK LFR6aIX-11 (first time)
Brake pads changed twice ( i switched to ceramic brake pads. (less dust).
Bled the brake once.
Rear diff oil changed once at 50000 miles (Valvoline 75w-90 systhetic).
Oil change every 5000 miles with Mobile-1 5w-30 super systhetic.
AC and Alternator belt changed once at 70000 miles (OEM)
That covered up about everything. I will take any type of advice and criticism as I really wanna hold on to this car for as long as it runs. I really love my car and this is the only car that lasted with me this long and I'm hoping that it will keep going for another 100000+ miles more.
Thanks
Leo05suby is offline   Reply With Quote
Old 04-30-2013, 02:13 AM   #2
cartwheels4amile
Member#: 190405
2002 Impreza WRX
lol mobil1... you should don the flame suit immediately.
But in all seriousness, congrats on the longevity! It would behoove you to switch to a better oil (Rotella T6 Synthetic 5w-40 or something similar) before you spin a bearing with that Mobil stuff. It has a reputation for ruining Subies.
cartwheels4amile is offline   Reply With Quote
Old 04-30-2013, 02:13 AM   #3
cartwheels4amile
Member#: 190405
2002 Impreza WRX
Double post... drat. Double drat. I'll use it to remind you that the timing belt is due at 105k.
Old 04-30-2013, 02:13 AM   #4
DARTH MAGNUS
Member#: 285248
2014 PBP GR WRX
2006 STi - SOLD :(
Threads like this really raise my confidence in my STi. I bought it in December with 95k and its a beast. I'm about to do the water pump/timming change. Congrats on your long life with your car!
DARTH MAGNUS is offline   Reply With Quote
Old 04-30-2013, 02:18 AM   #5
Leo05suby
Member#: 307286
05' EJ25 - Stock
Metallic Gray
Thanks. Would any 5w-40 ok to use? synthetic?
Old 04-30-2013, 02:18 AM   #6
pkluong
Member#: 341113
2013 WRX
Dark Grey Metallic
Mobil 1 blah blah blah. I believe it, but it worked for the guy. Bravo!
pkluong is offline   Reply With Quote
Old 04-30-2013, 02:31 AM   #7
Zach Thomas
Member#: 278763
2004 WRX
That's good to hear, I know way too many people that are convinced they won't hold up. I bought my nearly 300whp WRX with 98k miles on it, it's at 119k now and it's been modded since 60k miles or so. Runs like a champ, only had to do timing belt and clutch
Zach Thomas is offline   Reply With Quote
Old 04-30-2013, 02:37 AM   #8
Nate_1990
Member#: 234485
2004 STI
Rally Blue
121k with my 04 STi same timing belt and headgasket haha
Nate_1990 is offline   Reply With Quote
Old 04-30-2013, 06:12 AM   #9
nhmtns
Member#: 94283
'05 OBXT Stage 2
Min bil är svart
If you don't do what NASIOC tells you to do for maintenance, your car will explode and you will die! Either that or nothing bad will happen and your car will run fine.
nhmtns is offline   Reply With Quote
Old 04-30-2013, 10:29 AM   #10
mejifair
Member#: 11356
2012 WRX STi Hatch
Haha - NASIOC is truth.
mejifair is online now   Reply With Quote
Old 04-30-2013, 10:33 AM   #11
Leo05suby
Member#: 307286
05' EJ25 - Stock
Metallic Gray
Always have, always will. Everyone here are very helpful when it comes to maintainance, tuning advice and information.
When there's a problem, Nasioc is always there to the rescue!!!.....and youtube. haha. But in all seriousness, thank you all!
Anyway, Just ordered my New K&N air intake filter replacement, and gates timing belt kit!!! Just waiting for a perfect day to spend time in my garage. I also found that my Walmart sells Rotella T6 5w-40 for $21.95 woohoo!
Old 04-30-2013, 10:41 AM   #12
LUMBERZACK
Member#: 340009
2007 STi
48W
My 07 just hit 112k. Same clutch, Changed all fluids, plugs, timing belt, pullies, water pump, just regular maintenance really. Been stage 2 for about 20k miles with all grimmspeed gaskets, Invidia turbo back, K&N, EWG and loving it! When my turbo goes I have a VF48 Sitting on the workbench for me. Not an upgrade, but still new.
LUMBERZACK is offline   Reply With Quote
Old 04-30-2013, 11:04 AM   #13
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
I would follow Subaru's guidelines on changing fluids, however to go that long on trans and diff fluid is something. Make sure when you do change them to run a magnet through each fluid to look for metal.
Old 04-30-2013, 11:24 AM   #14
JustyWRC
Member#: 153088
2005 Baja Turbo
09 WRX
Same clutch.
same rotors
Thanks
Dang. Good job. I burned through my clutch in my 04 at 35K(first ever powerful car and lots of drag racing at the track). Brakes were done a little before that. According to a poster in another thread, you must be a master mechanic because that is the only way these cars will last 100K.
Subaru says 5w30. Mobile 1 has worked for you. Stick with it and continue doing what you do. Up until SOA started selling their own synthetic, all I had in mine was Mobile 1. NO PROBLEMS what-so-ever. If it was going to cause a problem like they are saying, probably would have shown signs by now.
Old 04-30-2013, 02:26 PM   #15
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Agree 100%. Don't change what you're doing, except maybe to decrease the length between fluid changes in the diffs/tranny. Glad to hear your car is running strong, post 100K miles.
Gallo2011 is offline   Reply With Quote
Old 04-30-2013, 02:43 PM   #16
07wrxstage2
Member#: 262366
2006 OBP STI
2000 BRP IMPREZA 2.5RS
+1. I've been using the same mobil 1 synthetic oil at 2,500 mile intervals and i'v had no issues. Congrats on the longevity. If mine turns out the same way I still have atleast 8 yrs to go...lol. By that time rust will probably be my #1 issue since I have no garage and live in the maic area.
07wrxstage2 is offline   Reply With Quote
Old 04-30-2013, 02:47 PM   #17
TropicalReefer
Member#: 321634
2005 Wrx 2.0
The plugs with -11 at the end aren't set the right gap. I bought a set on accident and they were all gapped at .040" when they should be .028". Hope you gapped them before installing.
TropicalReefer is online now   Reply With Quote
Old 04-30-2013, 03:11 PM   #18
sultan81
Member#: 309943
2012 STi
I really want to see you run the transmission fluid through a coffee filter when you finally change it.
sultan81 is offline   Reply With Quote
Old 04-30-2013, 03:29 PM   #19
jiGGypiGGy
Member#: 271097
2014 Evo Gsr
wicked white
don't all boutique synthetic oils use the same base from 3m or basf or whatever then just use there own adds.
anyways just use whatever is working.
jiGGypiGGy is offline   Reply With Quote
Old 05-02-2013, 01:03 AM   #20
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
im quite surprised it hasnt blowed up
Old 05-02-2013, 08:55 AM   #21
bluemk3
Member#: 263694
World Rally Blue
Like^^^^
bluemk3 is offline   Reply With Quote
Old 05-04-2013, 04:29 PM   #22
Leo05suby
Member#: 307286
05' EJ25 - Stock
Metallic Gray
Yeah I have to adjust the gap. It wasn't too bad. The wiring gapper came with the spark plug adjuster on it. Definitely worth the money.
Old 05-04-2013, 05:40 PM   #23
lone_wolf
Member#: 193206
2004 WRX Wagon
Red
Make sure you check and adjust the valves clearance, I just did it on my 04 WRX Wagon with 110K miles.
lone_wolf is offline   Reply With Quote
Old 05-04-2013, 07:59 PM   #24
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
Mobil 1 is fine if you don't drive the car hard. Once you get into higher rpm and with more heat it begins to shear. Since most people drive their car hard as most people on this forum. Mobil 1 is no bueno.
WaitTheresMore is offline   Reply With Quote
Old 05-04-2013, 08:20 PM   #25
sc00by4life
Member#: 97135
Or if you live in a hot area like the south....
Rule of thumb, don't buy m1.
