Old 04-30-2013, 12:46 PM   #1
spaceywilly
Member#: 174268
Default The new 911 turbo is a rich kid's wet dream
http://www.roadandtrack.com/go/futur...sche-911-turbo
  1. It has active aero. A rubber tube similar to a bicycle tire runs along the underside of the front spoiler. In Sport Plus mode, it fills with air, extending downward as a spoiler to swap the 911’s inherent front-end lift for slight downforce. Top speed is limited to 196 mph on the Turbo S because it’s all the tires can handle—otherwise the new rocket would be capable of 207.
  2. The optional ceramic brake discs measure 16.1 inches in front, 15.4 in the rear. In other words, they're enormous.
  3. In the past, Turbo models used the Carrera 4’s wide body. This time, the Turbo is even wider. C4 models are 1.7 inches wider than the base 911; add another 1.1 inches for the Turbo!
  4. Angry mobs, grab your pitchforks. There's no more manual—PDK is the only transmission now. The center differential is now a computer-controlled, water-cooled Haldex unit that can send 13 percent more power up front.
  5. Additional boost (up to 17.4 psi) and additional revs (up to 7200) means additional power: the Turbo makes 520 hp and 479 lb-ft. The Turbo S makes 560 hp and 516 lb-ft. Each motor gets an overboost function, producing another 37 lb-ft for up to ten seconds.
  6. Like the GT3, the 911 Turbo uses rear active steering for more maneuverability at low speeds and more stability at high speeds.
  7. The Turbo’s roof can be painted, made of glass, or made of carbon fiber, a la the GT3 Cup car.
  8. Not that anyone cares, but the Turbo uses some 13% less fuel than the last one. Partial thanks go to the virtual-gear programming in the PDK that uses clutch slippage to “fake” an appropriate gear ratio. It aims to keeps revs near 1000 rpm under low-speed, low-load conditions. Start/stop is standard, and now turns the engine off under 4 mph.
  9. The last Turbo and Turbo S flew around the Nürburgring in 7:39 and 7:37, respectively. The new car does it in under 7:30, meaning it could match the Carrera GT’s 7:25. Look for a 0-60 time of around 3 seconds flat.
  10. The seats are made out of $100 bills
spaceywilly is offline   Reply With Quote
Old 04-30-2013, 12:50 PM   #2
The Duke
Member#: 264877
What's with the trend of the Overboost function?
The Duke is offline   Reply With Quote
Old 04-30-2013, 12:58 PM   #3
E. Nick
Member#: 8489
1978 Plymouth Volare
Maroon / White Vinyl
Very cold here in hell.
E. Nick is offline   Reply With Quote
Old 04-30-2013, 01:38 PM   #4
pauli133
Member#: 233261
2005 Outback XT
because gamers.
pauli133 is offline   Reply With Quote
Old 04-30-2013, 01:49 PM   #5
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Originally Posted by pauli133 View Post
because gamers magazine racers.
Fixed.
With overboost you can claim a higher HP than would be typically found on a dyno after repeated runs due to heat soak.
My MCS has an overboost function.. the Focus ST has one.. most people driving these cars couldn't tell you in normal driving whether or not the car is in 'overboost' unless looking right at a boost gauge.
Old 04-30-2013, 02:36 PM   #6
Integra96
Member#: 64196
2010 Family Sedan
Integra96 is online now   Reply With Quote
Old 04-30-2013, 03:31 PM   #7
WRXHillClimb
Member#: 206907
2014 EvoX GSR
That thing is a ****ing sexy beast. The front air damn is a cool idea. Now time for a rear spoiler that is not only active, but really wide and uses wing warping technology a la wright flyer to help gear the wing for turns as well.
WRXHillClimb is offline   Reply With Quote
Old 04-30-2013, 03:48 PM   #8
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
It is good to see Porsche exercising some frugality with the tires only being able to handle 197 mpg, I guess purchasing tires to handle 10 more mph would just make it a bit too pricey. Lord knows how Porsche is so sensitive to their pricetags.
OH no, it has Haldex, such faux wheel drive on a 911 Turbo.. Enjoy your understeer loser!
:P
SCRAPPYDO is online now   Reply With Quote
Old 04-30-2013, 06:38 PM   #9
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
:P
Active rear diff FTW.
Spenk is offline   Reply With Quote
Old 04-30-2013, 08:35 PM   #10
JustyWRC
Member#: 153088
2005 Baja Turbo
06 Forester 04 Forester
:P
Did you mean active rear steering?
Old 04-30-2013, 10:49 PM   #11
delongedoug
Member#: 124113
and beyond!
It's no 930.
delongedoug is offline   Reply With Quote
Old 04-30-2013, 10:57 PM   #12
elirentz
Member#: 70082
2016 SS, 02 s2k
06 Cayman S, 80cc shifter
:P
Since the Porsche has the drive-train going the "wrong way" wouldn't it have perpetual oversteer?
elirentz is online now   Reply With Quote
Old 05-01-2013, 02:35 AM   #13
CryderSpeed
Member#: 88816
TO TWERK
They ran out of numbers for all the possible error codes so they now display Nazi Thule runes.
CryderSpeed is offline   Reply With Quote
Old 05-01-2013, 11:08 AM   #14
HipToBeSquare
Member#: 119958
1992 SVX LS-L
:P
Correction, it has backwards Haldex.
Adding front wheel traction assist to a properly rear-drive car is an entirely different prospect than having a contrary-to-weight-transfer front-wheel-drive car, and adding meager efforts to drive the rear wheels under circumstances when the front has already lost traction.
In front-assist cases, usually it is to quell oversteer from over-powering the rear tires on low traction surfaces, or to apply more power through more tire contact patch than just the rear tires can handle.
HipToBeSquare is offline   Reply With Quote
Old 05-01-2013, 11:13 AM   #15
Calamity Jesus
Member#: 44501
1984 That's *Sir*
I hope this replaces the Garage Door Seal DIY lips.. I'd like to see all of the civics/WRXs/etc with a cycle tube glued to the bottom of the front bumper and 12V compressors in the passenger footwell.
Old 05-01-2013, 11:35 AM   #16
spaceywilly
Member#: 174268
Yeap. Unfortunately it still adds weight and detracts from handling, but turbo buyers will never care about that just like they don't care about manual transmissions or the fact that the rear wheels are attached to a pivot and steered by a computer. They just want to buy the most expensive and fastest 911 there is to impress their neighbors.
Old 05-01-2013, 11:38 AM   #17
HipToBeSquare
Member#: 119958
1992 SVX LS-L
If you want handling...
Boxster/Cayman are inherently better anyway, and GT3 is the 911-based handling car.
Turbo is not primarily focused on handling.
It is focused on getting more than 500 horsepower to the ground without spinning the car around and killing the occupants inside.
GT2-RS without the AWD isn't even as concerned about that last bit. It may actually try to kill you.
Old 05-01-2013, 06:26 PM   #18
White out
Member#: 46277
** LP640
Viper GTS
The tire claim is BS. If they keep Turbo under 200mph they can mark up GT2 prices when the car crests 200mph.
Anyways, sweet car.
White out is offline   Reply With Quote
Old 05-01-2013, 07:05 PM   #19
high boost
Member#: 200410
2009 wrx
Still not a 959 Porsche too many computers ruin the fun of driving cars nice car though
high boost is offline   Reply With Quote
Old 05-01-2013, 09:02 PM   #20
Integra96
Member#: 64196
2010 Family Sedan
Old 05-01-2013, 11:15 PM   #21
Velvet_Kevorkian
Member#: 274908
2001 Legacy wagon :D
WM
Originally Posted by White out View Post
...If they keep Turbo under 200mph they can mark up GT2 prices when the car crests 200mph.
This.
Velvet_Kevorkian is offline   Reply With Quote
Old 05-02-2013, 06:05 PM   #22
Spenk
Member#: 7164
2000 Miata LS
Originally Posted by Integra96 View Post
Strictly speaking, he's not incorrect.
Old 05-03-2013, 11:56 AM   #23
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Doesn't this seem like it will continue to lose to the GT-R in lap time pissing matches? As in, I was actually expecting more HP and more technology with this iteration.
Frank A is offline   Reply With Quote
Old 05-03-2013, 12:13 PM   #24
alphaomega0
Member#: 147678
07 wrx
obsidien black
this, why not make it 650hp and be done with it, this way they dont have to keep playing catchup to jap's Godzilla , its not like they cant afford/ able to do it.
alphaomega0 is offline   Reply With Quote
Old 05-03-2013, 12:51 PM   #25
spaceywilly
Member#: 174268
Why not put a real engine in the Cayman for that matter? Because Porsche.
