Old 04-30-2013, 03:21 PM   #1
dirtysteez
Member#: 229614
2004 WRX
Java Black Pearl
Default Sub box slides in trunk
Hey guys! So I read through offset's car audio manifesto and didn't find any info on guys who had subwoofer boxes in their trunks and how to secure them. I have a fairly large (close to 2 cubic feet) and heavy subwoofer box in my trunk and it slides around a lot in my trunk when I take tighter corners. Has anybody found a practical way to secure them in the trunk? I thought about using velcro but I'm pretty sure that would just slide the carpet along with it.
dirtysteez is offline   Reply With Quote
Old 04-30-2013, 03:44 PM   #2
Paidfor
Member#: 267815
Be in awe
dont hate .)
I used 2 small L brackets screwed to the sides of my single box.....and pop riveted to the trunck floor.....works like a charm and you aint gettin em out easily lol
Paidfor is offline   Reply With Quote
Old 04-30-2013, 03:45 PM   #3
Not-EWRX
Member#: 158043
2013 Wrx Hatch
I velcro'ed mine then used zipties to secure the carpet. No sliding since.
Not-EWRX is online now   Reply With Quote
Old 04-30-2013, 04:08 PM   #4
Beau M
Member#: 345079
13 Wrx sedan
Lots of ways to do this, it all depends on your box and where it is, and if you want to irreversably modify the car or not (drill holes). Got pics?
Beau M is offline   Reply With Quote
Old 04-30-2013, 05:23 PM   #5
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
Velcro that sucker up. Heavy-duty "industrial" velcro REALLY sticks hard. I bought a 4 foot by 2 inch strip of it from Home Depot for $10 the other day.
evilspoons is offline   Reply With Quote
Old 04-30-2013, 05:57 PM   #6
2.5ReallySexy
Member#: 167943
I have done velcro. L brackets with screws and a ratchet strap.
2.5ReallySexy is offline   Reply With Quote
Old 04-30-2013, 08:28 PM   #7
dirtysteez
Member#: 229614
2004 WRX
Java Black Pearl
Thanks for the responses! Yea I was looking for a way not to screw it to the trunk floor just incase I got a flat tire so it wouldn't take as long to remove the box but its ok, it looks like one of the better options for me. Again, thanks for the feedback
Old 04-30-2013, 11:44 PM   #8
Powderhunter
Member#: 338131
2003 wrx wagon
black
If you have a wagon you can use eye hooks in the box and then some sort of cordage to tie it to where the seat backs snap on. I haven't had a sedan so I'm not sure if there is anything back there to tie them to. I did it when I had my subs in the back and it would have worked better if I used better knots or cordage cause it slipped a couple inches but when it was just tied worked great and came out without you ever realizes it was in
Powderhunter is offline   Reply With Quote
Old 05-07-2013, 02:36 PM   #9
WalkerB
Member#: 354985
2002 Impreza WRX
I used a ratchet strap and it works completely fine.
WalkerB is offline   Reply With Quote
Old 05-11-2013, 07:02 PM   #10
ShadowBoxer
Member#: 355583
1998 Impreza Coupe
Green
I had a similar issue with my sub (and will when its reinstalled). The more un-pro way to do it is to get some bungee cables and just tie the sucker down at enough anchor points to keep it from moving. You might wind up with a lightweight spider web of bungee cord, but at least you'll have a stable sub.
That is only speaking from previous experience. I might try out velcro, but I'm confident that a combination of the two will work effectively and reversibly. For theft prevention - bolt it down. You could also get a stealth fit subwoofer and anchor it in a nice little place where you'd never need to move it. But that's not practical for your large box existing right now.
2 cents, spent.
ShadowBoxer is offline   Reply With Quote
Old 05-13-2013, 04:42 PM   #11
tlatoani
Member#: 49828
2005 Grey STi
I use a ratchet strap. I had to screw it to the sub box because it kept moving around on the box and wore the carpet.
tlatoani is offline   Reply With Quote
Old 05-13-2013, 05:11 PM   #12
rdowner22
Member#: 329284
02 WRX Sport Wagon
I would use velcro, but I have that giant rubber weather trunk mat in my wagon so it obviously wont velcro to that. You could always try and use one of those grippy pads you know for like phones and stuff to sit on your dash and not slide. Apply like 2 with glue to the bottom of the sub then it has friction against the rubber mat. Mine only moves back towards the trunk when I go WOT though.
rdowner22 is offline   Reply With Quote
Old 05-22-2013, 07:07 PM   #13
sc00ter
Member#: 117767
2015 WRX (CWP)
3" TBE | DT Flex Fuel
I did this in my last car with the sub box and it worked extremely well. The box never slid after that.
sc00ter is offline   Reply With Quote
Old 05-23-2013, 02:32 PM   #14
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
Cargo blocks for a VW (Get them on ebay)
FTW
Mike 01Hawk is offline   Reply With Quote
Old 05-28-2013, 08:30 AM   #15
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
I installed a rear strut bar in my 05, put two "eye" hooks in the box, zipties around the strut bar through the hooks. done.
VTSubieRS is offline   Reply With Quote
Old 06-01-2013, 03:25 PM   #16
T-macks
Member#: 350238
2008 WRX Hatch
Spark Silver Metallic
My plan is to make a cutout in my trunk with 1/4'' MDF, and cut out a door with hinges to get to my spare. Then I'm gonna screw my sub box down to the board with some brackets so everything's more solid.
T-macks is offline   Reply With Quote
Old 06-01-2013, 08:50 PM   #17
skierbum97
Member#: 269314
2006 Wrx STI
i have a pretty big box and just have it ratchet strapped down for now. Keeps it from going anywhere when driving hard and easy enough to take out when i dont want the extra weight
skierbum97 is offline   Reply With Quote
Old 06-02-2013, 09:34 PM   #18
subyrules04
Member#: 73366
04 WRX /Cobb Stg2+
4EAT Platinum Silver
I took out my back seat and put a couple screws through the 2 bars that run vertically behind the seat. I also built a floor around the base of the speakers, with a removable panel to get to the spare.
http://forums.nasioc.com/forums/show....php?t=2505567
subyrules04 is offline   Reply With Quote
Old 06-02-2013, 10:54 PM   #19
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Here's what I did a couple months ago
1. replace flimsy factory spare tire cover with 3/4" plywood that fits tight between the strut towers and bolt it to the two 90 brackets on the rear-most wall of trunk to stop it from sliding around
2. staple carpet to plywood
3. position sub box where you want it
4. screw through two corners of the sub box into the plywood floor
5. enjoy driving your car without subs moving around?
brett192 is offline   Reply With Quote
