Old 04-30-2013, 04:01 PM   #1
jaredej20t
Member#: 306757
02 wrx
blue midnight pearl
Default motor mounts won't go into place
Anyone have any tips on getting these to go into place? I've lowered the sub frame, tranny mounts. Everything.. I need the usual 1 inch untill the will go in. What am I doing wrong?
jaredej20t is offline   Reply With Quote
Old 04-30-2013, 04:09 PM   #2
robsuerto
Member#: 331899
2012 WRX
John Shafer tuned
I don't know for your car but I'm sure it's the same issue. I had to lift my block A little. Have someone else look up top so u don't crush any hoses/lines.
robsuerto is offline   Reply With Quote
Old 04-30-2013, 04:12 PM   #3
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
More details... did you remove the pitch stop? Usual way is to raise the engine, not lower the other mounts.
wobbletop is offline   Reply With Quote
Old 04-30-2013, 04:14 PM   #4
SoyKraut
Member#: 263740
2002 WRX Sedan
MBP
Did you remove the pitch stop mount? If so, try running a set of ratchet straps from part of your frame around the motor mounts to get a little extra leverage. Just don't go overboard.
SoyKraut is offline   Reply With Quote
Old 04-30-2013, 04:21 PM   #5
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
I'd hope OP removed the pitch stop... I know someone who broke their's from lifting the engine. What brand mounts are you using or are they OEM? What are you using to jack up the engine? When I did mine, I had to wiggle everything around until both were partially in, then I bolted them down until they moved into place completely.
Mr Wrex is offline   Reply With Quote
Old 04-30-2013, 04:28 PM   #6
jaredej20t
Member#: 306757
02 wrx
blue midnight pearl
I have the pitch mount unbolted. And yes they are oem mounts.
Old 04-30-2013, 04:30 PM   #7
jaredej20t
Member#: 306757
02 wrx
blue midnight pearl
I'm using an engine hoist. I just finished assembling the built engine. Everything went great but now this..
Old 04-30-2013, 04:33 PM   #8
jaredej20t
Member#: 306757
02 wrx
blue midnight pearl
And yes its still a 205 block. And the motor mounts aren't on backwards.
