Old 04-30-2013, 10:43 PM   #1
PhotoREX
Member#: 180193
04 Forester XT
Default MBC issues
When I had my car rebuilt the builder said it was running a manual boost controller which I didn't know about because I just had bought the car used.
I found some torn vacuum lines and split oil breather lines. I replaced them and now the car is staying at just below .05 bar boost.
Im running cobb stage 1 and it sits right at .1 bar but dropped down and stays right at .04-.05 bar after I replaces those hoses. Doesn't make sense?
I have no clue where the mbc is an if that's what causing. Any help would be really appreciated. Thanks!
PhotoREX is offline   Reply With Quote
Old 04-30-2013, 11:11 PM   #2
lazybone
Member#: 297833
2002 Impreza Wrx
blaze yellow
Did u put the hoses in the correct??
lazybone is offline   Reply With Quote
Old 04-30-2013, 11:49 PM   #3
PhotoREX
Member#: 180193
04 Forester XT
Yeah it was just the tiny lines running from the wastegate actuator (tdo4) to a T that then split and runs to the intake and then one to a lil box the size of a roll or quarters right next to the stock airbox
Old 04-30-2013, 11:53 PM   #4
Heedlessone
Member#: 254130
1993 LS1 RX7
You need to locate the MBC and adjust it, sounds like you fixed a boost leak. Follow the lines back to something that looks like this:
The top is a MBC and the bottom is an EBCS. What do you have?
Heedlessone is offline   Reply With Quote
Old 05-01-2013, 07:11 AM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
If you are using the stock boost gauge the reading is in MPa and not BAR.
Old 05-01-2013, 09:42 AM   #6
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
sounds like its not hooked right, the mbc should be inbetween the wastegate actuator and boost source (nipple on compressor cover). No T's are needed.
It could be in hybrid configuration with the mbc and ebc but can't tell without pics.
fastnoypi is offline   Reply With Quote
Old 05-01-2013, 10:24 AM   #7
PhotoREX
Member#: 180193
04 Forester XT
Ill take pics and see what you guys think.
Old 05-01-2013, 10:48 AM   #8
PhotoREX
Member#: 180193
04 Forester XT
Oh yeah. It is MPa isn't it and not bar haha my bad
Old 05-03-2013, 02:02 AM   #9
PhotoREX
Member#: 180193
04 Forester XT
Ok so here's some pics of the setup. Your help is appreciated! Lets diagnose this thing!
The line you see running from the T in the first pic is then running thru my fingers in pic 2 and into the lil blue box in pic 3 along with another vaccum line
Old 05-03-2013, 02:24 AM   #10
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
That is a stock EBCS, not a MBC.
jebjkey is offline   Reply With Quote
Old 05-03-2013, 06:51 AM   #11
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
stock ebcs, either the inner diameter of your new hoses are slightly big or you forgot to put back in the restrictor pill that was in one of the stock hoses
Old 05-03-2013, 07:44 AM   #12
PhotoREX
Member#: 180193
04 Forester XT
Ok I don't remember the pill. And I thought the hoes were the same. Ill have to check. Dang. Thanks!
Old 05-04-2013, 07:20 AM   #13
PhotoREX
Member#: 180193
04 Forester XT
Just checked. Pill is still there. You really think the hose size could do it? It's the same size
Old 05-04-2013, 07:53 AM   #14
jebjkey
Member#: 73884
16 HyperBlue STi
The hose size -could- make a difference but not with the very small difference that might exist between the installed hoses and the stock hoses, especially if the correct pill is installed.
Is the pill in the correct location?
Old 05-04-2013, 01:34 PM   #15
PhotoREX
Member#: 180193
04 Forester XT
I never changed the pill location. Only replaced the 2-3" inch long ones right there by the wastegate actuator and the nipple on the cold side of the turbo
Old 05-10-2013, 07:39 PM   #16
PhotoREX
Member#: 180193
04 Forester XT
Ok so I just put on new, smaller diameter hoses and it's still not boosting about the 7.2-7.8 pound mark on the MPa scale. So any other ideas? Could my stage one Cobb tune have gone south and is limiting it at that level? Should I reflash?
Old 05-11-2013, 09:11 AM   #17
PhotoREX
Member#: 180193
04 Forester XT
Discovered that the pill is missing and this is why it's screwed up. I didn't realize it was within one of the hoses
Old 05-11-2013, 09:42 AM   #18
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
I didnt know that with a mbc u still used the pill? R u sure
Shortpersonbk is offline   Reply With Quote
Old 05-11-2013, 12:43 PM   #19
quazimoto
Member#: 70395
The pill is not required with an MBC
quazimoto is offline   Reply With Quote
Old 05-11-2013, 02:24 PM   #20
Groundup
Member#: 294682
02 wrx
Sedona Red
He's not using a MBC. The picture he posted was the stock controller.
Groundup is offline   Reply With Quote
Old 05-30-2013, 12:02 PM   #21
PhotoREX
Member#: 180193
04 Forester XT
I got it solved. The pill was accidentally thrown out when we did the lines. I didn't realize where/what it was and I thought it was in a different location.
