Vancouver Impreza Club
Old 05-01-2013, 01:23 AM   #1
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Default Clicking and Creaking Clutch in 08+ WRX
I know someone else was asking about a click or creak in thier clutch pedal on their 08+ WRX. I've been aware of the issue on my car for some time but it's been on and off until recently with the warmer afternoon weather it happens my whole drive home. It's driving me nuts and I will have to address it. In any case I found an interesting thread about this issue:
http://forums.nasioc.com/forums/show...t=clutch+click
There's a class action taking place on the problem:
http://www.subarufirewallclassaction.com/
Anyone else having this issue here?
2010 WRX Limited is offline   Reply With Quote
Old 05-01-2013, 03:32 AM   #2
DIGGYGV8
Member#: 313558
2011 STi Sedan
I'm more annoyed at the a-pillar cracking noise, and the rear deck (for the trunk in my sedan) rattling due to ****ty sound deadening... but I also have a really loud exhaust...
It also seems to affect the earlier years more, I will ask some of my buddy's who aren't on the boards.
DIGGYGV8 is offline   Reply With Quote
Old 05-01-2013, 10:29 AM   #3
Studebaker83
Member#: 169443
2008 WRX with VF-52
World Rally Blue
I don't have a solution about the clutch but as for Diggygv8 I found shoving a sock under the rear deck and it stopped the rattling there.
At Home Depot in the States (it isn't carried in Canada) in the roofing section you can buy stuff that looks/works and basically is dynamat but a lot cheaper. It drastically cut down the a-pillar rattle for me
Studebaker83 is offline   Reply With Quote
Old 05-01-2013, 04:27 PM   #4
DIGGYGV8
Member#: 313558
2011 STi Sedan
****... I have to try this sock trick... since I suck at pulling plastic panels off! (if anyone would like to assist, that'd be awesome)
thanks for the heads up!
Old 05-01-2013, 06:48 PM   #5
Batmar
Member#: 265613
2008 Subaru WRX STI
Spark Silver
I noticed the a pillar rattle at first when I bought the car but after I installed my strut bar it went away... I dunno if there's any connection but maybe less flex meant less creaking/rattle
Batmar is offline   Reply With Quote
Old 05-01-2013, 08:24 PM   #6
bender
Member#: 1839
yup. one of our regular customer has a 08 wrx. he complain of a clutch squeak about a year after having the car. I notice the support for the clutch pedal that was welded to the firewall had cracked. it was repaired under warranty
bender is offline   Reply With Quote
Old 05-02-2013, 01:56 AM   #7
cp2503
Member#: 292566
2011 WRX ltd GV WRB
damn it... The clicking sound happened today... I found out where it is but couldn't fix it.
there is a white nipple spring loaded it "clicks " everytime I push in the clutch.
cp2503 is offline   Reply With Quote
Old 05-02-2013, 02:10 AM   #8
jque11
Member#: 198912
2004 WRX
By any chance it's called peel and stick? Or something like it? If so it should be available here too. It's used against water penetration mostly at openings like window jambs and sills. Good idea though as I never even thought about using it as a dynamat replacement.
jque11 is offline   Reply With Quote
Old 05-02-2013, 04:15 AM   #9
DIGGYGV8
Member#: 313558
2011 STi Sedan
I was told to use sound deadener because that stuff lasts forever... On the other hand... Weighs a **** load...
Old 05-02-2013, 09:14 AM   #10
Studebaker83
Member#: 169443
2008 WRX with VF-52
World Rally Blue
This is the stuff.
http://www.homedepot.com/p/USeal-Ban...0#.UYJmT7WG0vk
When I went into a HD in Canada I could not find it in the store and was told it wasn't available in Canada....if you can find it here let me know.
Old 05-02-2013, 04:22 PM   #11
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Oh that's good to know. Do you know where he went for the warranty work? I have heard of people getting it fixed even out of warranty because it's a 'manufacturer defect' but it seems to be hit and miss from what I've read.
Old 05-02-2013, 04:41 PM   #12
Subiezilla
Member#: 280543
Dealer told me that if it was past 3 years/36k miles its up to the customer to take care of it, but they did say to shoot SOA a call to see about a "good will" repair....
Subiezilla is offline   Reply With Quote
Old 05-04-2013, 04:58 PM   #13
wrxgunr
Member#: 336361
2009 WRX 265
Fixed my clutch pedal today. No noise, feels way better under foot too!
I used this as a guide, but I used larger 5/16's grade 8 bolts and trimmed down some fender washers to get more grip.
http://www.wrxforums.com/forums/84-d...olt-style.html
I wasn't about to go to a dealer, or go on a lawyers list... Whole thing took me about an hour by myself, if you had an assistant it maybe quicker. Hope this helps other 08+ guys.
wrxgunr is offline   Reply With Quote
Old 05-05-2013, 02:12 AM   #14
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Wow that's awesome! I thought I was going to pull the whole dash off and weld the firewall!
Old 05-05-2013, 12:12 PM   #15
wrxgunr
Member#: 336361
2009 WRX 265
I first noticed mine after the first day of Thunderbird... been looking for a fix that didnt involve ripping out the interior since! This works great and really improves the feel of the clutch. I also drilled and bolted a third spot weld to the left of the two for the clutch quadrant to further stiffen the area.
Old 05-05-2013, 04:30 PM   #16
Rialb22
Member#: 352342
2000 2.5rs coupe
Blue Ridge Pearl
Exclamation
I have a tip for everyone. I had mentioned the creaking noise that was coming from the A-Pillar on our 2009 impreza, and there was a subaru warranty fix for it. They happily took it in and re-mounted the cover. The technician told me that all they do is wrap a piece of tape around the clips that hold the cover on and voilla. Fixed! I never heard it squeak again. If you don't feel like taking it in, I figure it would only take you 15 mins at home.
Rialb22 is online now   Reply With Quote
Old 05-10-2013, 02:21 PM   #17
bender
Member#: 1839
speak of the devil....
the customer with the 08WRX came back today complaining of a clutch squeak again.
you can see where it was welded the first time. looks like the other weld broke. this is right behind the wiper motor which I removed
Old 05-11-2013, 01:12 PM   #18
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Ya those spot welds are under-engineered for the stress of the clutch assembly and the flexing of the firewall. I think the flex is the real problem. If it's not braced, any fix has the danger of releasing over time. I am attempting the nut and bolt fix today, wish me luck
EDIT: I read the entire thread on WRXforums.com and now see that there are more spot welds under the windshield that are cracked, my car included. This is going to require removal of the whole dash and some form of firewall brace. I am going to contact Subaru Canada on Monday... It looks like a recall is in order. I think it's only a matter of time before more people have the problem and I wonder how wide ranging it will be. All 08+ models could be affected.
Old 05-11-2013, 05:44 PM   #19
bender
Member#: 1839
firewalls on Subarus have always been weak. even on my 00 RS, the brakes pedal felt soft because of the flex in the firewall, which is why some smart cookie invented the master cylinder brace for the cars.
I told him about the class action lawsuit in the US and he took the car back to Docksteaders. that's where he got his car, and where he got it repaired the first time. I also told him to contact SOC. I wonder if there is anything like the NHTSA here in Canada?
Old 05-11-2013, 08:12 PM   #20
Studebaker83
Member#: 169443
2008 WRX with VF-52
World Rally Blue
Let me know how this goes.
I haven't experience any creaking in my clutch..... (yet?)
Old 05-11-2013, 09:57 PM   #21
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Wow you're lucky! for you I've got my whole dash out and it's still hella hard to get the bolts through.
Old 05-12-2013, 05:35 AM   #22
Rialb22
Member#: 352342
2000 2.5rs coupe
Blue Ridge Pearl
Wow! Posted on the thread a few days ago on a side note and here I am in the same boat. Clutch pedal JUST started creaking today! Damn! I haven't taken anything apart yet but we'll see.
Old 05-13-2013, 12:52 AM   #23
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
It took me the better part of the weekend to do this project but I managed to fix the cracked spot welds. I drilled them out and bolted the areas together.
Here's the car with the dash torn out... it was like seeing a loved one go into surgery: You know everything should be okay but there's always a small chance it could go very wrong!
Here's the area that flexes and breaks apart:
One spot that broke completely:
It was a bitch of a job but I'm glad I didn't pay 10 hours of shop time to let someone else do it.
Old 05-13-2013, 08:43 AM   #24
ShiftGear
Member#: 130493
1999 v5 STi
Sick! If this is a common problem, I wonder when mine will act up
ShiftGear is offline   Reply With Quote
Old 05-13-2013, 11:29 AM   #25
Studebaker83
Member#: 169443
2008 WRX with VF-52
World Rally Blue
I hope Subaru issues a recall as that looks like a big PITA,
