Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 05-02-2013, 10:28 AM   #1
16gsuby
Member#: 150696
2005 WRX
white
Default correct fuel pressure??
so looks like someone messed around with fuel pressure regulator when doing my clutch job,because it was at 20 lbs @ idle and running like crap.i cant localize my tuner,but i'm pretty sure he had the fuel pressure in the 40's almost to 50 area.i moved it up to 45 psi @ idle,car runs and feels great since i moved it.I'm running 650cc injectors,255 walbro and a big 16g with meth injection. Car made 330whp/330trq.
what should my fuel pressure be at? thanks nasioc
16gsuby is offline   Reply With Quote
Old 05-02-2013, 12:53 PM   #2
neo277
Member#: 131432
2004 WRX on Ignite E
Gtx3076 - 07 6mt
Base pressure on a stock system is 43psi with oem fpr, you should be fine at 45, as thats not too much of a jump.
neo277 is offline   Reply With Quote
Old 05-02-2013, 02:25 PM   #3
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Do you know how to set base fuel pressure? Base is 43 psi but you won't read 43 at idle. If you do you set it wrong.
Old 05-02-2013, 03:41 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Fuel pressure is referenced to the intake manifold. Idle fuel pressure will be much closer to 35 psi than 45psi.
The best way to set an aftermarket FPR is to pull the reference line from the intake manifold and adjust until it's ~43psi (or your desired fuel pressure)... then put the reference line back.
If your tuner tuned with a different fuel pressure than stock, you need to find out what fuel pressure that was. Like now.
Concillian is offline   Reply With Quote
Old 05-02-2013, 04:53 PM   #5
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Originally Posted by Concillian View Post
The CORRECT way to set an aftermarket FPR is to pull the reference line from the intake manifold and adjust until it's ~43psi (or your desired fuel pressure)... then put the reference line back.
Fixed'd
Old 05-02-2013, 08:29 PM   #6
greenplates
Member#: 239162
stock fuel pump kinda sucks
greenplates is offline   Reply With Quote
Old 05-03-2013, 01:38 PM   #7
16gsuby
Member#: 150696
2005 WRX
white
ok,gonna try to find out then,but if i cant then what should i set it to??
Old 05-03-2013, 02:29 PM   #8
kellygnsd
Member#: 32669
LINK G4 hybrid STi
43 psi is the default base fuel pressure.
Old 05-03-2013, 06:47 PM   #9
car_freak85
Member#: 13530
EA63 , EA81T, EG33,
EJ205
Not only that, but it is the standard fuel pressure in the automotive industry for fuel injected vehicles, outside of diesels and direct injected engines.
car_freak85 is online now   Reply With Quote
