Old 05-03-2013, 03:41 AM   #1
mattesonb
Member#: 139607
2011 WRX
DGM Wrapped Satin Black
Default 08+ wrx/sti any way to have the HVAC knobs stay lit when key is on
i recently painted the silver rings on my HVAC knobs black to match my interior and unfortunately it has made it difficult to determine where the small red indicator is located during the day.
would anyone know how to wire it so i can have it on when the key is in the ignition
mattesonb is offline   Reply With Quote
Old 05-03-2013, 10:49 AM   #2
jordanc15
Member#: 276118
2011 WRX
I had plans to paint mine as well. I was going to take a small piece of red vinyl and cut it to shape and stick it on. I guess it might not light up at night then though...
jordanc15 is offline   Reply With Quote
Old 05-03-2013, 02:30 PM   #3
mattesonb
Member#: 139607
2011 WRX
when you take the ring's off you can pop the red portion off. it ended up coming out perfectly as far as looks and the red plastic is still visible. the problem is the black ring with the dark red plastic indicator is hard to see at a glance in the day with sunglasses on
Old 05-07-2013, 09:32 AM   #4
FerdSimao
Member#: 280691
2012 WRX Ice Silver Sedan
i'm thinking about doing the same thing. can you post up some pics?
FerdSimao is offline   Reply With Quote
Old 05-09-2013, 02:10 PM   #5
mattesonb
Member#: 139607
2011 WRX
i'll post pics today
Old 05-10-2013, 12:17 PM   #6
FerdSimao
Member#: 280691
pics!!! please!!hahah
Old 05-10-2013, 03:07 PM   #7
mattesonb
Member#: 139607
2011 WRX
Old 05-10-2013, 11:10 PM   #8
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
The climate controls will have an illumination input, you can just cut that and run your own from IGN power. Check FSM for the wires/pins.
The problem I see if you do that, is the CC illumination won't be on the circuit that is dimmed with the dash light dimmer, might be annoying at night and look funny. You'd have to get fancy to devise a circuit that would switch between your 12v feed when lights are off, and then over to the stock illumination when the lights are on. You could do that with one SPDT relay.
Power6 is offline   Reply With Quote
Old 05-13-2013, 08:26 AM   #9
FerdSimao
Member#: 280691
oh I like that!! ill definitely be doing it... that's the last silver piece in my interior!!
