Old 08-19-2013, 10:00 PM   #51
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Originally Posted by mxturboracer86 View Post
Why don't you guys stop fighting over inflated dyno numbers and take it to the track, if its really making that power and torque it should go 12.2 or faster...
Hmmmm.
eugeneutopia is offline   Reply With Quote
Old 08-20-2013, 12:20 AM   #52
ckbeep
Member#: 350233
2006 WRX
I am not fighting over it. I am going to the drag strip sometime in the next few weeks. Can't wait to see what runs.
ckbeep is offline   Reply With Quote
Old 08-20-2013, 07:47 AM   #53
bjohnson_55
Member#: 216580
Bad guesstimate... Why are you looking for et too?
bjohnson_55 is offline   Reply With Quote
Old 08-20-2013, 03:17 PM   #54
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
A 12.2 with 270whp falling on its face after 5k rpms? That's not going to happen because he can't take advantage of his gearing. If it was making 270whp at or close to redline I'd say a lower 12 sec pass may be doable. As it sits if you can get anywhere in the 12's you're making some decent power for that little turbo. Not to mention ET usually demonstrates driving ability where trap speed indicates how much power you're making given the weight of the vehicle.
And OP don't feel so inclined to show NASIOC know-it-alls your car is making power at the dragstrip. You're going to really regret it if you blow your trans on the launch and you're certainly making enough torque to do that.
Steve.804 is offline   Reply With Quote
Old 08-24-2013, 02:57 PM   #55
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Well Gents... I emailed the fine folks at Pacific Raceways to get more info on their "Test & Tune" events and it JUST SO HAPPENS that yesterday was the last day this year that they were holding the event to the public.
BIG props to Ed Garfield, the drag strip manager, who not only gave me all the info I was looking for, but SUPER quickly. I emailed him yesterday at 11:46am and he replied at 12:03pm. Crazy good customer service.
I really enjoyed myself, but I was disappointed in my times. I couldn't get a good 60' or even 330' time... just didn't have the low end to pull while the turbo spun up. Once it did.. super happy.
I tried a mixture of launch set ups to see what worked best:
Full auto with t/c on and off (quickly learned that TC has to stay off; something that Dom noticed on the dyno as well)
Sport mode with t/c off
Manual shift with t/c on and off
The best seemed to be in sport mode with t/c off. I staged, held the brake pedal down and rev'd as high as it would go without moving forward (about 2200 rpm).
I wish the Forester has a stall converter or the Access Port has launch control as an option like the WRX/STI.
My best run was:
R/T .344
60' 2.515
330 6.313
1/8 9.304
MPH 81.59
1000 11.901
1/4 14.084
MPH 103.72
I'm OK with the end speed, but I REALLY wish I could launch better. I think I could easily be in the low 13's or better if that were possible...
I seriously doubt that I could be in the 12.75 or lower range w/o E85 or a manual tranny
Last edited by eugeneutopia; 08-24-2013 at 02:59 PM. Reason: Made the time easier to read
Old 08-24-2013, 03:46 PM   #56
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
BTW, interesting calculator online... post #2
http://www.turbo-mopar.com/forums/sh...ile-calculator
I don't know if my math is accurate here. I am relying on Google to do the math. Comparing it to the #'s on the thread above, it checks out.
Based on it, my breakdown is (3700)*(.4541155866900175)^3 which according to Google is 346.498173488 WHP... which is .998173488 HP off Dom's dyno. Less than 1 HP off.
Clarification: I'm not supporting/advocating my dyno results, just stating what I believe to be the most accurate method of calculating the WHP based on what I can find online.
That being said, I've seen 350 HP cars run low 12's, so I still have my doubts, not to mention I couldn't launch for s**t.
Old 08-24-2013, 06:26 PM   #57
Airboy
Member#: 72829
2006 WRX
2015 WRX
Pretty sure the HP calculators are estimating engine power, not WHP
Airboy is offline   Reply With Quote
Old 08-24-2013, 07:25 PM   #58
DentMagnet
Member#: 352689
2004 Impreza
dark green but looks blak
Aren't these dynos traceable to the NIST?
DentMagnet is offline   Reply With Quote
Old 08-24-2013, 08:15 PM   #59
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Actually, if you look at his breakdown, he says 606WHP (his numbers)
Old 08-24-2013, 08:38 PM   #60
Airboy
Member#: 72829
2006 WRX
2015 WRX
So this stock 09WRX would be >300whp?
http://forums.nasioc.com/forums/show....php?t=1852966
Old 08-24-2013, 08:44 PM   #61
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Again, it's not my calculator. YMMV, it might be totally wrong, just pointing it out.
Old 08-27-2013, 11:25 AM   #62
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
with the tq that car produces you should be able to short shift and stay in the powerband to get down the track faster.
at 292/292 on my 04 STi on PIA's Mustang Dyno when I dyno'd my car after running a 12.29, so I would imagine if the #'s are correct and with a car that weighs 100+ lbs less than that STi did, a 12.2 would be a very possible outcome.
mxturboracer86 is offline   Reply With Quote
Old 10-27-2013, 08:53 PM   #63
eugeneutopia
Member#: 322957
2010 FXT
OBP - Black
Back to the dyno discrepancy... it's not as much as I had thought it'd be, but it IS there.
More progress. Had a ton done, including a 4EAT to '11 STI 6-speed swap. Bigger injectors and re-tune on a more conservative dyno (PIA's Mustang).
PIA dyno base (RUN 2) (no additional mods) = netted 326 AWHP / 379 AWTQ
MPS dyno base (same mods as the PIA dyno base) = 346 AWHP / 414 AWTQ
NEW PIA dyno (RUN 1) (injectors + 6-speed) = 360 AWHP / 358 AWTQ @ 21psi.
Next up = E85 tune. I'll get it in a week or so. I'm hoping to move into the 400AWHP club, but it's going to be close!
