Old 05-04-2013, 10:38 PM   #1
Half Crazed
Member#: 321842
2008 STi
Angry Competition stage 2 clutch / transmission violent rattle
So I'm definitely at or past the break in period and my clutch or transmission still rattles fairly violently. I replaced the clutch along with a new oem flywheel and bearings. Used a new act throw out bearing as well. Used spec torque on pressure plate.
It sounds like the car is about to fall apart in first gear (taking off) due to how bad it shakes. I can also hear clunking below the car in the front. Also, in reverse, it chatters so bad I feel the transmission slapping the bottom of the car... Or something... I have to slip in higher than usual rpms, like 2k so it doesn't chatter...
I have brand new group n motor mounts, pitch stop, and transmission mount. Also double checked everything was tightened down... So what feels like it's slapping the bottom of the car? And the chatter?
I'm so frustrated with this car....
Half Crazed is offline   Reply With Quote
Old 05-04-2013, 11:53 PM   #2
SIBzzz
Member#: 129888
Liquid Copper
throw out bearing might be shot...
SIBzzz is offline   Reply With Quote
Old 05-05-2013, 12:32 AM   #3
Half Crazed
Member#: 321842
2008 STi
Why would you say that? To me that doesn't make sense, it was brand new act.
Old 05-05-2013, 02:12 AM   #4
Half Crazed
Member#: 321842
2008 STi
Old 05-05-2013, 05:40 PM   #5
lillayzie2000
Member#: 255051
2004 WRX
Interested in this issue. I'm having the same issue. Same clutch company.
lillayzie2000 is offline   Reply With Quote
Old 05-05-2013, 05:42 PM   #6
Dakota D
Member#: 293894
2011 wrx sti
world rally blue
I would just give them a call they would give you an answer fairly quick
Dakota D is online now   Reply With Quote
Old 05-05-2013, 05:47 PM   #7
Luc r
Member#: 332784
11 flexed wrx
its clutch chatter...is it a puck clutch disc?
Luc r is offline   Reply With Quote
Old 05-05-2013, 07:40 PM   #8
Half Crazed
Member#: 321842
2008 STi
Hmm, interesting.. my oe did this too, but because previous owner got it too hot. I haven't gotten this clutch hot...
Good idea, going to give that a try some time this week
Full face sprung clutch. Frustrating!
Old 05-05-2013, 08:13 PM   #9
Supraru
Member#: 23313
99' 2.5Rs
black
Full face clutch what company? Is the only thing you have oem the flywheel? What pilot bearing did you use? Heads up, spec is garbage. If you used their pilot bearing they are the worst. They give you locktite to hold it in place which is the most ridiculous thing I've ever heard. My trans made a lot of noise till this garbage clutch couldn't handle maybe 400 ft lbs of tq when it was rated for 500.
I went through so many different clutch and flywheel set ups trying to get rid of a nasty decel noise. When the spec went out I said screw it and just went with the act flywheel and the 6 puck so it would hold. Coincidentally it went away with the stock pilot bearing. Then I sold the car.
Supraru is offline   Reply With Quote
Old 05-05-2013, 11:10 PM   #10
Half Crazed
Member#: 321842
2008 STi
"Competition" is the clutch company I believe. http://www.competitionclutch.com/pro...dex.php?id=400
Used OEM flywheel and pilot bearing - from what I hear, their pilot bearings are superb and are better to use than the pilot bearing that came with the clutch kit, so we used it.. I didn't see any loctite or anything on it, so I'm not sure - maybe you got a one-off?
Old 05-06-2013, 05:29 PM   #11
Supraru
Member#: 23313
99' 2.5Rs
black
No, it was a spelled pilot beating. The good one was the Oem bearing. Do you used an Oem flywheel, pilot bearing, act throw out bearing, spec pressure plate, and a competition clutch disc? Why not get a new pressure plate while you're in there?
Old 05-06-2013, 05:45 PM   #12
Half Crazed
Member#: 321842
2008 STi
I did!
Here's the parts list:
  • New OE Flywheel
  • New OE Pilot bearing
  • New Competition Clutch: Stage 2 Full-face sprung clutch
  • New Competition Clutch Pressure Plate - supposed to handle ~80% increase
  • New ACT Release (throw out) bearing
does this help?
Old 05-06-2013, 09:22 PM   #13
ryansx
Member#: 324527
2013 wrx
white
Could be improper install. I know a lot of people don't recommend using the throw out bearings that come in kits, I have always tossed them and used oe. Could always rev higher like you said you do. 2k isn't going to hurt it unless you sit there and slip a lot.
ryansx is offline   Reply With Quote
Old 05-07-2013, 12:32 PM   #14
henria86
Member#: 303849
2004 Forester Xt
Silver stg2
hi i recently installed a COMP stage 2 clutch along with there light weight fly wheel, an used the supplied throw out bearing
I broke it in 800 miles gently. its over 6k now theres no problem with it at all.
The clutch does its job n no complains from my wife n me .
henria86 is offline   Reply With Quote
Old 05-07-2013, 12:34 PM   #15
Half Crazed
Member#: 321842
2008 STi
how was the break-in period, pretty violent? how long do you think until you noticed the chatter had gone away?
I'm thinking mine is starting to go away, but when motor is at operating temp, the chatter comes back.. smooth as butter when cold though!
Old 05-08-2013, 01:17 PM   #16
henria86
Member#: 303849
2004 Forester Xt
Silver stg2
hello,
there was just a about 25% stiffer n it was very grabby in the break in process. No extra Noise or chatter.
I would call them up and ask for tech support.
During install did you use alot of grease or very little??
send me a pm if u need
Old 05-08-2013, 03:43 PM   #17
Half Crazed
Member#: 321842
2008 STi
hello,
grease? we didn't use grease on the clutch that I know of.
Old 05-08-2013, 10:31 PM   #18
wcjuggalo
Member#: 167772
03 wrx
white
check the rear subframe outrigger bushing. when they go metal to metal, they give a horrible clunking/chatter at take off.
wcjuggalo is offline   Reply With Quote
Old 05-15-2013, 10:39 AM   #19
besthaticouldo
Member#: 279660
i am in the exact same situation as you man.
had my clutch in for about 6k miles.
it's a comp stage 3 with their flywheel. it is horrible. an absolute nightmare to drive. violent shaking on take off and a ton of noise on deceleration. it's bad.
i'm not sure what to do.
besthaticouldo is offline   Reply With Quote
Old 05-15-2013, 10:42 AM   #20
Half Crazed
Member#: 321842
2008 STi
Dang, 6k miles! I'd call competition clutch company and talk to them, you should definitely be broken in unless you've burned up the flywheel during break-in.
I spun a bearing recently but I think mine was just starting to go smooth. Damn!
Old 05-15-2013, 11:01 AM   #21
Supraru
Member#: 23313
99' 2.5Rs
black
Dude he has a stage 3 clutch. The purpose of getting a better clutch is clamping force and being able to hold the power you're putting down. Once you start doing that all expectations of having a clutch that engages smoothly are gone. You children need to get that I. Your heads.
Old 05-15-2013, 11:28 AM   #22
Half Crazed
Member#: 321842
2008 STi
From what I saw, the stage 3 is still a sprung clutch, though about twice as strong as the stage 2.
Wouldn't the fact that this is full face and sprung it shouldn't chatter, or why would it?
My bad for misunderstanding..
Old 05-15-2013, 12:11 PM   #23
Supraru
Member#: 23313
99' 2.5Rs
black
So because it's a full face clutch it should drive like stock? Lol. It says it's capable it says it can hold 150% more then stock....how do you think they do that? You don't just make a clutch that can hold more tq without giving up something.
