Old 06-28-2013, 05:51 PM   #1
erikjon2010
Member#: 360029
2010 WRX STi
Default New Tires Causing Pull
Just bought new tires for my 2010 STI, Toyo Proxes 4 Plus All Season, and I am having pull issues. Thought the alignment might be off but it is dead on. First the new tires caused my car to pull left, then the tech drove it, rotated the tires, then it pulled right. He said he rotated them a couple times and then got my car to even out, but it still pulls to the right again. Talked to the sales rep where I bought the tires and he said I can have a certified Toyo dealer look at them and have them warrenty them out for new ones, or just order two new tires, then ship the other ones back.
All tire pressures are good, alignment is perfect, no loose suspension parts or anything.
Anybody on here ever have pull problems with new tires or certain types of tires?
Erik
erikjon2010 is offline   Reply With Quote
Old 06-28-2013, 06:01 PM   #2
Horuku
Member#: 309930
2013 STI Sedan
Plasma Blue Pearl
Some roads are sloped to allow water run off.
Horuku is offline   Reply With Quote
Old 06-28-2013, 06:12 PM   #3
ryansx
Member#: 324527
2013 wrx
white
It's possible to get a bad tire that has belts separated. Manufacturing and quality control aren't always 100%
ryansx is offline   Reply With Quote
Old 06-29-2013, 12:46 PM   #4
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
How long have the tires been on the car? Last set of tires I got took a few hundred miles to settle in. Just drive it around and see what happens later on.
Jackie leggs is offline   Reply With Quote
Old 06-29-2013, 01:36 PM   #5
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
no mention of if the wheels were rebalanced, have that checked out.
brew02wrx is offline   Reply With Quote
Old 06-29-2013, 03:47 PM   #6
stirunner06
Member#: 310027
06 STI
Have them roadforce balanced. It will show how much road force each tire is creating. Pulling issues that i have run into is mostly due to the tires. After roadforcing you can index the tire to the rim for optimum position but only on the balancers that have the option.
stirunner06 is offline   Reply With Quote
Old 07-01-2013, 03:52 AM   #7
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
your first problem is buying as tires for an sti....the second is buying toyos....
Old 07-01-2013, 02:14 PM   #8
Tire Rack Moderator
Member#: 1215
ext. 4362
Tires are manufactured by assembling components made of rubber, fabric cord and steel wire that are cured together in a mold. Under intense heat and pressure during the curing process, the rubber reaches a near liquid state before vulcanization takes place finalizing the tire's exact size, structure and shape.
If a tire's internal components are misaligned as it cures, it is possible that unequal internal forces may cause the vehicle to pull to the side, even when it is steered straight ahead. When this occurs with a brand new tire it is typically due to conicity, a manufacturing glitch where a tire's tread has cured slightly cone shaped rather than in the desirable uniform cylinder shape.
A tire that has conicity due to a manufacturing error will be apparent right after installation or immediately following the first time the tires are rotated. Because of this, tire manufacturers warranties only cover this condition early in the tire's life.
If tire pull first becomes noticeable after many miles of driving on a tire, it is typically due to driving conditions or vehicle misalignment that has caused the tire's tread to wear on an angle (with one side wearing faster than the other), or allowed the tire on the left side of the axle to wear faster than the tire on the right side of the same axle.
If a vehicle has a pulling problem, the alignment should be checked (including cross camber, cross caster and thrust angle settings). If the alignment is at the manufacturer's preferred settings or appropriately within the range, the following procedure can be used to confirm which tire is causing the pull.
The following steps must be used to isolate a pulling tire. Click here for a downloadable version of these instructions.
Step 1
Action to be Taken
Rotate the two front tires from side-to-side. Directional tires can be moved from side-to-side for testing purposes. The short time that they are on the vehicle backwards will not harm the tire.
Results
1. If the vehicle pulls in the opposite direction, the defective tire is one of the front tires. (GO TO STEP 2)
2. If the vehicle pulls in the same direction the problem is either with one of the rear tires or is not a tire-related problem. (GO TO STEP 3)
Step 2
Action to be Taken
Rotate the front tire on the side of the car that is in the direction of the pull, to the rear of the car.
Results
1. If the pull no longer exists or diminishes greatly, the tire that was moved to the rear of the car is the defective tire.
2. If the pulling does not change, the defective tire is isolated to the front tire that was not moved in Step 2.
Step 3
Action to be Taken
Rotate the two rear tires from side to side.
Results
1. If the vehicle pulls in the opposite direction, the defective tire is one of the rear tires. (GO TO STEP 4)
2. If the pulling tire does not change, the problem is not tire related. The car should be checked for possible misalignment or suspension wear.
Step 4
Action to be Taken
Rotate the rear tire on the side of the car that is in the direction of the pull to the front of the car.
Results
1. If the vehicle pull becomes more severe, the defective tire is isolated to the tire that was rotated to the front of the car.
2. If the pulling does not change, the defective tire is isolated to the rear tire that was not rotated.
A tire diagnosed as a pulling tire is a manufacturer's defect. The tire is covered under warranty only during the first 25% of tread wear. The defect is caused by the belts being incorrectly aligned during manufacture.
Luke@tirerack is offline   Reply With Quote
Old 07-04-2013, 01:25 PM   #9
erikjon2010
Member#: 360029
2010 WRX STi
--Uncle Scotty-- my bad, i dont live in Houston... i guess ive learned my lesson
--Luke@tirerack-- thanks for the info
my nearest tire tech did a lot of rotating to try to get the pulling neutralized, it is less severe than when they were first mounted and it was pulling to the left. i will decide quickly if i need the two new tires the tech thinks are the problem.
