Old 05-05-2013, 03:57 PM   #1
bryanh1234
Member#: 348192
2013 WRX Sedan
World Rally Blue
Default 2013 WRX Stock turbo silencer ring
Can you remove it? If so, how do you?
bryanh1234 is offline   Reply With Quote
Old 05-05-2013, 04:02 PM   #2
XERO287
Member#: 253541
2011 WRX 5DR Premium
uhhh...???
XERO287 is offline   Reply With Quote
Old 05-05-2013, 04:03 PM   #3
jimbosv650
Member#: 261307
04 wrx wagon
Like a diesel truck?
jimbosv650 is offline   Reply With Quote
Old 05-05-2013, 04:04 PM   #4
bryanh1234
Member#: 348192
2013 WRX Sedan
World Rally Blue
Yes. I'm not sure I have the proper name, but I want to hear the turbo spool more, without installing an intake. I know on the older subies it was called a snorkel delete.
Old 05-05-2013, 04:09 PM   #5
jimbosv650
Member#: 261307
04 wrx wagon
On diesel trucks, there's an actual metal ring on the turbo itself which quiets it. Older turbo subarus had a snorkus, or series of plastic ducts and chambers, which accomplished the same.
For more sound, an intake, turbo inlet pipe, and downpipe will do the trick pretty well.
Old 05-05-2013, 04:13 PM   #6
bryanh1234
Member#: 348192
2013 WRX Sedan
World Rally Blue
Originally Posted by jimbosv650 View Post
On diesel trucks, there's an actual metal ring in the turbo itself which quiets it. Older turbo subarus had a snorkus, or series of plastic ducts and chambers, which accomplished the same.
Okay so do the new wrx's have these snorkels?
Old 05-05-2013, 04:21 PM   #7
jimbosv650
Member#: 261307
04 wrx wagon
No they don't
Old 05-05-2013, 05:05 PM   #8
Nukem
Member#: 303705
Correct me if I'm wrong but 11-12s don't have the snorkus. I know my 12 doesn't.
Nukem is offline   Reply With Quote
Old 05-05-2013, 07:40 PM   #9
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
GE/GH Impreza has snorkus (an empty "bottle" resonator attached to bottom of airbox), GE/GH/GR/GV WRX model does not. STI GR/GV models does have the snorkus/resonator.
On a WRX you can cut out the solid hole where the bottle would go(or get an STI/Impreza stock airbox with the hole for the bottle in it), and enjoy a little more turbo noise. But you also get an intake drone under some throttle/RPM conditions. Some people don't care about that. For me, I did this long ago in my 09 WRX and reversed it, there is a reason they tune out the drone in the stock intake, its annoying.
Power6 is offline   Reply With Quote
Old 07-01-2013, 01:11 PM   #10
rosedaleny806
Member#: 202070
2012 WRX GR LSB/Gold
2002 WRX GDB PSM
STI GR/GV model does not have the "snorkus" as you say, theyre intake is exactly like the WRX GR/GV model. no snorkel at all
rosedaleny806 is offline   Reply With Quote
Old 07-01-2013, 02:32 PM   #11
arani rey
Member#: 346176
I believe he's talking about one of these? AFAIK Subaru doesn't use them.
arani rey is offline   Reply With Quote
Old 07-01-2013, 02:36 PM   #12
thescreensavers
Member#: 333820
2013 WRX Limited
My friend which is into trucks told me to do the same thing with my 2013, but yea no such thing. On the Subbie
thescreensavers is offline   Reply With Quote
Old 07-01-2013, 04:24 PM   #13
Barnold
Member#: 318142
2012 WRX
The 11+ STI DOES have the giant white jug under the intake in the fender. The 11+ WRX DOES NOT have the jug, as previously stated.
Barnold is offline   Reply With Quote
Old 07-01-2013, 08:38 PM   #14
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
FWIW, I am 99.99% sure this is correct. Last time I was under the hood, looking in that area, I do recall seeing it.
Ziggyrama is offline   Reply With Quote
Old 07-01-2013, 08:59 PM   #15
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
08+ STI does have the resonator "jug" under the airbox, WRX does not. They are not "exactly the same"
That applies to back to 08+ the STI has jug, WRX does not. To be complete, the non-turbo models also have the jug.
Yeah it's not immediately obvious you'd have to remove the airbox to notice it anyways. Don't think it makes a difference either way, the cool air comes through the top, the jug is just there to add volume to tune resonance. It is interesting how they didn't need to use it on the WRX, all the similar models like STI and the turbo Legacies generally have it.
Old 07-01-2013, 09:13 PM   #16
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
Hmm... So the jug adds volume? Has anyone tried to put the STI intake into the WRX...? Is the jug the only difference...?
nightdown fox is offline   Reply With Quote
