Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 05-06-2013, 02:38 AM   #1
skimpreza06
Member#: 304086
Default need help!
hey guys i have an 02 wrx i just bought a jdm sti v7 engine, im going to eventually get the sti tranny buy for the moment i will be using the 5mt. I will be changing the clutch on it during the swap and i wanted to know what kind of clutch should i go with?
thanks
skimpreza06 is offline   Reply With Quote
Old 05-06-2013, 08:15 AM   #2
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
Generally you will need a 5MT clutch to fit inside your 5MT. An uprated 5MT clutch can be used in your eventual 6MT or you can switch to a 6MT clutch and flywheel when you do the 6MT swap.
As for the clutch recommendation request, you are going to get varied opinions that may/may not match up to what you really need. I suggest reading the Clutch FAQs. Also read some reviews of clutches that seem to meet your engine's torque output, your driving style, and how you plan to use the car.
**Some have gound out the bellhousing on a 5MT to fit a 6MT clutch inside. I'm not suggesting that method but it is an option you can contemplate.**
JarHarms is offline   Reply With Quote
Old 05-06-2013, 08:44 AM   #3
mhoerath
Member#: 131379
2003 354 ftlb@3k rpm
justablue hatch
i used my 5 spd clutch and flywheel when the 6mt was installed, reason is I had just replaced the clutch. when it went installed the 6 spd flywheel and a 6mt clutch.
i've heard* the 6 spd flywheel can be used in a 5 spd with some milling on the ribs in the 5 mt casing.
*one post on nasioc...interweb caution.
mhoerath is offline   Reply With Quote
Old 05-07-2013, 09:25 AM   #4
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
6MT flywheel is not going to work with a 5MT clutch though. As noted, the 6MT flywheel and 6MT clutch can be used in a 5MT but it needs a decent amount of grinding inside the bell housing. More than I would be willing to do.
Just put in a 5MT clutch to get you by for now then swap out for the 6MT parts once you swap the trans in. OR buy an uprated 5MT clutch and use that with the 5MT then the 6MT. When it wears out then switch to the 6MT parts. you have a 2002 WRX so at lease you are already a pull-type clutch design. Best of luck.
