Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 05-06-2013, 10:24 AM   #1
INDY_06_STI
Member#: 116409
2006 Steel Gray STi
2001 Dodge Viper GTS
Default Can you electrically test the OCV?
Am having problems with P0011 and P0021 codes. Have pulled the turbo oil filter, and OCVs. No sludge or issues found. Have cleaned up the OCVs. Is there any way to actuate the OCV off the car to check for obvious sticking or malfunction?
INDY_06_STI is offline   Reply With Quote
Old 05-22-2013, 12:40 PM   #2
pippen
Member#: 171290
2008 STi
Any luck on this? Having the same issue..
pippen is offline   Reply With Quote
Old 05-22-2013, 12:46 PM   #3
Scooby-ohses
Member#: 187707
06 Impreza wrx
obsidian black
when I searched these codes there was a guy that said he removed them and hooked them up to a 9v to actuate then a he cleaned them, I also hsve this issue mines an 06 wrx
Scooby-ohses is offline   Reply With Quote
Old 05-22-2013, 12:49 PM   #4
Scooby-ohses
Member#: 187707
06 Impreza wrx
obsidian black
oh and I think mach v sells the ocv valves if u need to replace them. I also want to call and talk with them to see what kinds of things go haywire when they are bad out not working. im just curious a they mention it in their product description
Old 05-22-2013, 08:13 PM   #5
INDY_06_STI
Member#: 116409
2006 Steel Gray STi
I have not gone through the circuit diagrams to figure this out. Even if I manage to actuate the part with a given voltage, I still won't really know if the part actuall works. Instead, I am going to start a thorough analysis this week. First off, I am going to monitor the oil pressure real-time, and use a Tactrix cable to monitor the AVCS. Based upon the results, I'll figure out the next steps.
Old 05-23-2013, 12:06 AM   #6
pippen
Member#: 171290
2008 STi
My engine builder told me to use a 9v too.. I haven't tried it yet because I think I found the solution. The guy who put the motor together left the bolts loose on the cam gear which was apparently causing all sorts of ruckus.. Will be back If the cel pops up again.. Maybe you can check that?
