Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC > RMIC Vendor Classifieds
Old 05-06-2013, 01:31 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Vendor Sales Rating: (95)
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Default TEIN Street Flex Coilovers now Available for 2008+ STi! In stock at RallySportDirect
We are proud to introduce the new Tein Street Flex coilover!
Affordable and high quality coilover that cant be matched in its price range!
The Street Flex damper is the evolution of their popular Type Flex coilover. Developed to provide the ultimate balance of comfort and performance for both street driving and circuit use, along with wide-range damping force adjustment using their new Advance Needle technology and new damper valving specs, giving the driver a much more noticeable feel in damping force change and controllability. The shortened shell case design provides optimum damper stroke at lower than standard vehicle ride height. Full-length adjustability offers separate spring preload and ride height adjustment. Updated internal components and external coatings increase durability and product life. Includes Pillowball Upper Mounts (camber adjustable for strut type applications) and is compatible with the EDFC and EDFC Active systems.
Tein Street Flex on our Albino Rhino shop BRZ
Click on any image for more information and pricing listed on our site!
• Steel Construction
• Twin Tube Internal Construction
• Full-Length Adjustable via Threaded Body and Spring Seat/Seat Locks
• 16-Way Damping Adjustable (simultaneous compression and rebound)
• New Damper Valving Specifications for Improved Street Comfort
• Incorporated Advance Needle Design (nearly 200% improvement over predecessor)
• Pillowball Upper Mounts for increased steering feedback
• Camber Adjustable for Strut Type Front Suspensions
• Larger Piston Diameter (22mm O.D.) for Strut Type
• EDFC (Electronic Damping Force Controller)/EDFC Active Compatible
• Powdercoated Brackets and ZT Coated Shellcase for Outstanding Rust Prevention
One Year Warranty Against Manufacturer's Defects
  • Damping Adjust Type : 16 way
  • Damper Type : Twin Tube
  • Drop Height Front : 1.4in
  • Drop Height Rear : 1.2in
  • Drop Height Front Metric : 35mm
  • Drop Height Rear Metric : 30mm
  • Height Adjustable: Yes
  • Independent Height Adjustable : Yes
  • Spring Rate Front : 504lbs/in
  • Spring Rate Rear : 392lbs/in
  • Spring Rate Front Metric : 9Kg/mm
  • Spring Rate Rear Metric : 7Kg/mm
RallySport Direct is offline   Reply With Quote
