Old 05-06-2013, 06:50 PM   #1
VTBlue
Member#: 251714
2002 WRX Wagon
2.35/6mt/PTE 5858
Default DCCD Controller w/ 6-speed swap
Alright I've got a bugeye with the STi mini swap (2007 6-speed with auto driveshaft= and STi stubshafts) and a Spiider DCCD controller. I'm not sure what model it is, it came with the on/off and dial switches and g sensor but only one set of "loose" wires (red/green/black/white/blue/brown). The picture on Spiider's website shows too looms coming out of the auto unit, so which one do I have? I'm assuming its an earlier version (2009) auto unit that only interfaces with the 6-speed. Jeff can you weigh in? happy to attach a pic. I would like to connect it and then wire it up to the dash light on an STi cluster, yet to be purchased. Should I use a 2004/2005 cluster or is there an advantage to using a later one? I understand that the later STi clusters aren't exactly plug and play into a bugeye but it is a 2007 transmission. Any help is greatly appreciated!
VTBlue is offline   Reply With Quote
Old 05-07-2013, 12:34 PM   #2
DCCDPro
Member#: 227549
Hi,
If an '09 then must be our older deluxe version.The best reference is the installation guide. You can download it at this link on our website:
http://dccdpro.com/main/wp-content/d...o%20Deluxe.pdf
In order to connect to STi cluster you need the interface. Seems that your unit does not have the option. We support 2004/2005 STi cluster.
Kind regards,
DCCDPro Team
DCCDPro is offline   Reply With Quote
Old 05-07-2013, 02:30 PM   #3
VTBlue
Member#: 251714
2002 WRX Wagon
2.35/6mt/PTE 5858
so just to clarify, I would have to buy the interface? or is my unit totally incompatible with the cluster...
Old 05-08-2013, 02:14 PM   #4
DCCDPro
Member#: 227549
Hi,
Yes, you can add the option.
Old 05-09-2013, 10:06 PM   #5
gearhead99
Member#: 356002
Default transfer case
ok i have a question/therory i would like to resolve would it be possible to control your transfer case through like a switch if you wanted to switch to rwd from awd and back? let me know if this is a stupid question or not im just curious if it is possible or not
gearhead99 is offline   Reply With Quote
