Vancouver Impreza Club
Old 05-07-2013, 05:10 PM   #1
coupe-a-loop
Member#: 336028
1995 v2 sti type ra
Glacier White
Default v2 brake issues
Hey guys, after noticing strange uneven wear on my rotors in finally got around to checking out my brakes. I have a v2 so it has the 2 pot front 1 pot rear with vented rotors. I got new pads all around and 2 new front rotors. When removing the front caliper I checked my caliper and on both sides 1 piston is coming out slower than the other. I swapped out and oem used caliper off a turbo legacy and tried it out, same thing. So I'm thinking this is either a master cylinder problem, or that all 3 calipers are messed up and this is a normal occurence for these with age. Any thoughts? I don't really feel like fixing more then is needed at this point. Thanks.
coupe-a-loop is offline   Reply With Quote
Old 05-07-2013, 06:00 PM   #2
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
i think that is actually normal operation for a 2 piston caliper... Either way, I have a pair you can try out if you want from an RS.
How are your caliper brackets? If the pins are stiff to move than that is a problem. They should be nice and smooth.
Zefy is online now   Reply With Quote
