Old 05-08-2013, 05:12 PM   #1
yswizzy19
Member#: 341421
2008 wrx sedan
wr blue
Default 2008 wrx sedan daytime running lights
i have a 2008 wrx and as soon as i put the key in the ignition the lights go on. im trying to put HID's in and i dont want them to stay on all the time.I read in some other fourms that you can find the grey box under the air box and pull the wire on that but it doesnt work. does anyone have this issue? please help!!!
yswizzy19 is offline   Reply With Quote
Old 05-08-2013, 07:34 PM   #2
Gdspliff
Member#: 348014
2010 2.5i
Orange
If you put HID for your high beams that's where the DTRL are at the light won't turn on because the blast will not be getting enough power to enable the DTRL. I had HID for high beams and the DTRL never worked because not sufficient power to the blast to power the HID. Hope this helps if not I would say connect your HID and you'll see what I'm talking about..
Good Luck Dude
Gdspliff is offline   Reply With Quote
Old 05-08-2013, 11:28 PM   #3
tilegend
Member#: 295565
are you sure you unplugged the correct connector?
tilegend is offline   Reply With Quote
Old 05-09-2013, 01:15 AM   #4
aznboi0204
Member#: 266514
2011 OBP STi Sedan
Theres a DIY on how to properly disable the DTRL. Its somewhere in this section of the forum too. Just search. Its behind the glove box and its a yellow connector. You disconnect that and should be good to go from what I understand.
Edit:
Here's two links first one is to a '13
http://forums.nasioc.com/forums/show....php?t=2424247
Here's one to 06?
http://forums.nasioc.com/forums/show....php?t=1189213
Don't have 08 but one of these will work for you.
aznboi0204 is offline   Reply With Quote
