Old 05-08-2013, 09:20 PM   #1
cannondalemtb
Member#: 267715
'05 FXT-Built-6spd
04 HD softail deuce
Default BrenTuning Blouch 1.5xt-r 2.5l 423/400
Vehicle: 2006 WRX
Where: PSI Racing (Auburn, Ma)
Date: April 27, 2013
Dyno: DYNAPACK
Tuner: BrenTuning
ECU: OpenSource
Fuel: 93oct
Psi: 23
WHP: 423
WTQ: 400
Engine/Performance:
CP pistons
Blouch 1.5xt-r 10cm
83mm KSTech sri
GMS turbo inlet
TurboXS fmic (DEI reflect-a-gold)
STI intake manifold
TGV deletes
Grimmspeed 8mm phenolic spacers
Grimmspeed Air/Oil seperator
Grimmspeed Ebcs
Walbro 255 fuel pump
Perrin v1 fuel rails
Deatschwerks 850cc injectors
KillerB oil pickup
KSTech air pump delete
Exhaust:
UEL header (wrapped with DEI titanium)
Invidia uppipe
Invidia divorced catless downpipe
FMS catback
cannondalemtb is offline   Reply With Quote
Old 05-08-2013, 10:50 PM   #2
KingPest
Member#: 194894
2013 BRZ
2005 STi
Nice results. Pretty much what I would expect from this turbo at 23 psi.
KingPest is offline   Reply With Quote
Old 05-13-2013, 01:00 PM   #3
BrandonHtwo0
Member#: 348212
2013 STI Limited Sdn
Nice!
BrandonHtwo0 is offline   Reply With Quote
Old 05-13-2013, 01:12 PM   #4
BrenTuning
Member#: 287454
For parts/tuning bundles!
Well thought out car, one of the strongest DOM1.5's we've tuned to date.
https://www.youtube.com/watch?v=qnUz6-FmdsM
BrenTuning is offline   Reply With Quote
Old 07-25-2013, 02:19 PM   #5
KingPest
Member#: 194894
2013 BRZ
2005 STi
Back from the dead.
Are you running 23 PSI all the way to redline? What kind of timing are you running at redline? Any issues with false knock in the upper rev range? I found that my car would consistently register -1.0 once I hit a certain power level running the Dom 1.5 as well.
Mike
Old 07-25-2013, 03:21 PM   #6
Wicked Performance
Member#: 265606
Just saw this for the first time. Nice results. Blouch should be giving new england tuners a kickback for giving the turbo some publicity.
Wicked Performance is offline   Reply With Quote
Old 07-31-2013, 02:04 AM   #7
hippystinx
Member#: 204368
07 wrx wagon
black
i have a 1.5xtr on a perrrin top mount with all supporting mods...only thing holding me back is the stock wrx 5 speed, i am seeing 354whp at 5400 and 350wtq at 4500. it is a perfect street turbo pulls super hard all the way to about 90mph then it starts to top out for me at least
hippystinx is offline   Reply With Quote
Old 08-05-2013, 05:14 PM   #8
cannondalemtb
Member#: 267715
'05 FXT-Built-6spd
04 HD softail deuce
What size got side? 2.5l?
Old 08-06-2013, 04:28 PM   #9
morse9443
Member#: 325412
2012 WRX
OBP Stg 2
OP, any idea how much quicker you'd spool with the 8cm instead of the 10cm? Torn between the two..
Noticeable lag over the stock turbo setup with the 10cm?
morse9443 is offline   Reply With Quote
Old 08-06-2013, 07:27 PM   #10
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
great setup, just installed my 1.5xtr but i have the small 8cm hotside and stock inlet. great street turbo for the 2.5 and a DD. My motor is all stock so we werent going too crazy w boost/timing. looks like it would be a black to drive!
BONFIRE074 is offline   Reply With Quote
Old 08-06-2013, 08:34 PM   #11
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
I want this turbo so bad. Seeing amazing results. Looks like an awesome street car. Congrats
freddy121389 is offline   Reply With Quote
Old 08-06-2013, 09:22 PM   #12
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
8cm does better in gears 1-3. More explosive. Above that the 10cm rocks it all day.
BlazeRex is offline   Reply With Quote
Old 08-07-2013, 09:37 PM   #13
JW07WRX
Member#: 364288
2007 WRX stage 3
Originally Posted by cannondalemtb View Post
Vehicle: 2006 WRX
Dyno: DYNAPACK
Tuner: BrenTuning
ECU: OpenSource
Fuel: 93oct
Psi: 23
WHP: 423
WTQ: 400
Engine/Performance:
CP pistons
Blouch 1.5xt-r 10cm
83mm KSTech sri
GMS turbo inlet
STI intake manifold
TGV deletes
Grimmspeed Ebcs
KillerB oil pickup
Exhaust:
Invidia uppipe
FMS catback
Nice number we have the same turbo lik different set up I'm from Leominster mass but I'm in WA stationed at Ft Lewis right now... Nice to see another clean wrx!!!! Also I'm 362whp on a mustang Dyno I'm sure if I was on same Dyno we who have similar whp
JW07WRX is offline   Reply With Quote
Old 08-07-2013, 09:38 PM   #14
JW07WRX
Member#: 364288
2007 WRX stage 3
Lil different set up*
Old 08-08-2013, 10:07 AM   #15
BrenTuning
Member#: 287454
Agreed
Absolutely great street turbo.
We've found near identical spool up times between the two with the 10cm continuing to pull to redline. We recommend going with the 10cm version.
