Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 06-05-2013, 04:20 PM   #1
Jonlegacy98
Member#: 275412
1998 Legacy L
green
Have a Nice Day? ej 22 bog down
I have a98 subaru legacy 2.2
when i start it and hit the gas it bogs down. it says like this for about 10 minutes then seems good til i accelerate after a light.
FROM IDLE to GAS it bog down and i have to feather the pedal the get it out
tried cats, cam sens, maf, tps, knock sens, tranny fluid, sticky butterfly
Jonlegacy98 is offline   Reply With Quote
Old 06-08-2013, 07:02 PM   #2
LGT187
Member#: 330956
2005 legacy GT
Fuel treatment?
LGT187 is offline   Reply With Quote
Old 07-08-2013, 10:10 PM   #3
Jonlegacy98
Member#: 275412
1998 Legacy L
green
took a minute to get back on. I am running 93 premium and doing gumout once a month. i seafoamed it in march tbc in april. it bogs down bad especially in rain. dealershipped it finally and they took 5 hours to tell me it was cats and my wipers messing up aerodynamics.
a local shop says its my journals or a bad rear main.
Old 07-09-2013, 07:47 AM   #4
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
No, no, just no.
First off, shouldn't you be running 87 octane in this EJ22? Running a higher octane will do you nothing but be harder on your wallet and probably end up giving you poorer gas mileage than if you were just to run 87.
Journals or bad rear main? What? That might be the dumbest thing I've ever heard, only second to the wipers screwing up aerodynamics. None of which would cause your car to bog while taking off.
It is either spark or fuel related. Check the condition of your fuel filter, fuel pump, and the coil.
When was the last time you changed out plugs, wires, fuel filter, general maintenance crap? Any CELs? Seems like you wasted a bunch of time on random things for no reason whatsoever without investigating what could be the actual cause of the problem.
Jessekrs123 is offline   Reply With Quote
Old 07-15-2013, 02:58 AM   #5
SubieRSjustin
Member#: 262254
2000 00rs/99 legacy
silver/ tan
Aerodynamics of windshield wipers causing it to bog lol lol lol oh boy
SubieRSjustin is offline   Reply With Quote
Old 07-17-2013, 04:05 PM   #6
08legacy207
Member#: 362577
Your stealership mechanic needs an ear punch. Im not sure how you made it out the door without realizing he took you for a fool, but all I can say is WOW
08legacy207 is offline   Reply With Quote
Old 07-17-2013, 07:22 PM   #7
98legwag
Member#: 160325
09 Legacy 3.0R
I was going to say spark plugs, wires, coil, and fuel filter. All that has been said. My car bogged too. I changed all that over time and now it doesn't.
98legwag is offline   Reply With Quote
