Old 05-09-2013, 04:01 PM   #1
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
Default I'd like to play a game.. Guess my horsepower before I hit the dyno Saturday!
Ok I am going to the dyno Saturday. What do you guys think I will put down? I have an idea but would like to hear your opinions.
Dyno: Dyno Tech's mustang Dynamometer
Tuner: Jay Perry of Perry Tuned
Car: 2002 Subaru WRX Wagon MBP
Mod List:
Power:
-30k Stock EJ20 Long Block
-IHI VF-22 Turbo
-DW 750cc Injectors
-Walboro 255LPH Fuel Pump
-Perrin Fuel Rails
-Perrin Turbo Inlet
-Perrin After-MAF
-K&N Drop In Filter
-STI Spec-C Long Runner Intake Manifold (no tgvs)
-3mm Phenolic Intake Spacers
-Maddad UEL Header
-Maddad Cattless Up Pipe
-Stromung 3" Divorced Short Down Pipe (custom cattless lower section)
-Stromung 3" Catback
-Turbo-XS TMIC
-Forge BOV
-Hallman MBCS
-NGK 1 Step Colder Plugs
-Defi Control Unit
-Defi Link (oil pressure, water temp, EGT and MPH)
-Defi Boost Gauge
Suspension/Drivetrain:
-Tein Basic Coilovers (Soon to be swapped out for ISC N1 Streets)
-Whiteline Front and Rear Swaybars
-Whiteline End Links
-SPT Front Strut Tower Brace
-Tein Rear Shock Tower Brace
-Group-N Front 4-Pot Brake Kit
-Group-N Rear 2-Pot Brake Kit
-DBA-5000 Slotted Rotors (F&R)
-Goodrige SS/Teflon Brake Lines
-Kartboy Short Shifter
-ACT HD Clutch
-ACT Street Light Flywheel
-Mishimoto Aluminum Radiator
-Samco Hoses
-Cryo Treated JDM Gear Set
-BBS VZ Wheels (White)
-NEXEN 3000 225/45/17
I think that is about it.
Also do you guys think it would be beneficial to use a K&N Typhoon short ram intake with "heat shield" or just keep the stock box with K&N drop in and Perrin after MAF?? I have both.
naCAnItihS is offline   Reply With Quote
Old 05-09-2013, 04:04 PM   #2
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
stab in the dark? low 300s. maybe 325 +- 15...thats is based off absolutely nothing. i didnt even read your mod list. i stopped after Vf22 and 750ccs
07VTRex is offline   Reply With Quote
Old 05-09-2013, 04:10 PM   #3
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
^^ haha thanks
Well its already been street tuned and is pushing 23psi tapering to 18psi.. Jay says there is a good amount left to go but I do not have a wide band yet so we are going to fine tune it saturday on the dyno.
Old 05-09-2013, 04:32 PM   #4
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Im going to say 290whp and I would go k&n intake since you will be getting a retune anyway I personally love the sound of intakes on turbo vehicles!!
nate_fisher is offline   Reply With Quote
Old 05-09-2013, 05:41 PM   #5
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
What kind of fuel will you be using?
Mike
GrimmSpeed is offline   Reply With Quote
Old 05-09-2013, 05:57 PM   #6
toph
Member#: 78640
14 KTM SuperDuke
15 STi CWP | 02 STi Wagon
Mike
Good question.
93 octane I'd say 275WHP, E85 I'd say maybe 310-330WHP, although I'd assume 93 octane based off injectors.
I would use the stock intake personally because I like the safety. At those power levels it's probably not too much of a choking point.
toph is offline   Reply With Quote
Old 05-09-2013, 06:45 PM   #7
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Slimsti is offline   Reply With Quote
Old 05-09-2013, 07:48 PM   #8
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
I will be using pump 93 octane. I generally fill up at Mobil.
Im also going to put out there that it feels much faster than my buddies LGT (EJ25) w/ a vf 52 and turbo back that made 265 AWHP (dont recall torque) on the same dyno. But we will have to see..
Old 05-09-2013, 07:57 PM   #9
Raulboy
Member#: 202412
2011 5-door STi
Arctic Blue
270-280... I got my balls crushed on MZM's mustang in Austin with an AVO450 2.4 stroker
Raulboy is offline   Reply With Quote
Old 05-09-2013, 08:56 PM   #10
OBP WRX
Member#: 330185
(Jumping up and down) $1
OBP WRX is offline   Reply With Quote
Old 05-10-2013, 12:00 AM   #11
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
what is this the price is right?!? hahah
Old 05-10-2013, 10:01 AM   #12
What v8
Member#: 254718
If this is the price is right he^^ is the dick!
What v8 is offline   Reply With Quote
Old 05-10-2013, 10:57 AM   #13
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Mike
Old 05-10-2013, 11:01 AM   #14
missmysubie
Member#: 313857
07 STI LTD
(Mustang) 306/346 VF48
277/265...good luck....I had a similar setup but only ran 17psi
missmysubie is offline   Reply With Quote
Old 05-10-2013, 11:43 AM   #15
Lukas_vee23
Member#: 342863
I made 281 at 18 psi. I have 117k miles so kept it conservative. You have headers and tgv deletes and 1 or 2 more mods so i say 300 to 305
Lukas_vee23 is offline   Reply With Quote
Old 05-10-2013, 11:44 AM   #16
Lukas_vee23
Member#: 342863
Also depends on how much boost too
Old 05-10-2013, 03:22 PM   #17
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
This^
On my setup which was very similar I did 275/265 on the mustang virtual dyno setting. I only did 21 psi on the turbo and it tapered to about 18 psi or so by redline.
Subian is offline   Reply With Quote
Old 05-10-2013, 03:44 PM   #18
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Wow vf-22? Been a while since I've seen one of these in action. I'd venture to guess 288whp at 21psi on 93oct. You also need to take account for the white on black combo which I do like...I'll grant you 10whp. 298whp!
Steve.804 is offline   Reply With Quote
Old 05-10-2013, 08:54 PM   #19
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Like I said in your other thread 265/265
BlazeRex is offline   Reply With Quote
Old 05-10-2013, 09:34 PM   #20
ByeBye4g63t
Member#: 290896
2004 STi, FOR SALE
ByeBye4g63t is offline   Reply With Quote
Old 05-10-2013, 09:44 PM   #21
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Right in there with the others, I'd say 280/270.
Dave D. is offline   Reply With Quote
Old 05-12-2013, 09:12 AM   #22
ipkyss
Member#: 353600
2004 Wrx 2.5 35R
Its Sunday. What was the results?
ipkyss is offline   Reply With Quote
Old 05-12-2013, 10:00 AM   #23
02h20
Member#: 130079
2006 STI [email protected]
[email protected]
What's the results
02h20 is offline   Reply With Quote
Old 05-12-2013, 11:11 AM   #24
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
Nothing to really talk about. It seemed to be going well. Ran into a few boost leaks. Fixed most of them, however I still have a pretty good one. The BOV is leaking pretty good at higher boost levels. We ran a boost leak test and I could feel air coming out of it around 20 psi and far more at 25psi. ( i didnt really check it at anything under 20).
We kept turning up the boost controller to see if it would help at all. No dice. Torque would increase but it would still taper down to 15-16 psi by redline.. On the last run I turned the controller down by 3 full turns. HP stayed the exact same but lost 20 ft lbs because the peak boost was lower. The torque peak in this session was 284ftlbs. but turned it down to 264ftlbs.
This turbo should hold 23 easy and only taper to about 20 by redline but I am seeing high peak but boost levels drop quick to around 15... even with this ***** boost leak the car put an end result of 259awhp and 264awtq. Once I square this leak away I will go back and turn it back up a bit. should be in the 280 neighborhood which is what I was expecting.
Also keep in mind the humidity was quite high since it was raining on and off and sometimes down pouring.. Def not power making conditions.
This dual piston design of the Forge BOV confuses me. They offer different spring rates for the large spring (it has the blue one rated for 23-30psi in there) but the one that seems to have the problem is the smaller one. There is a chamfer type seal (good seal/weak spring) for the small piston and then just a thin walled cylinder mating to a flat surface for the larger piston (terrible seal/good spring).. WTF Forge.. The small piston is so easy to push up, once that moves it relies on a very thin wall pushing down on a flat surface to seal which is not an adequate sealing surface...
Old 05-12-2013, 05:48 PM   #25
OBP WRX
Member#: 330185
The leak thing blows! Hope you get it fixed and see what she can really do!
