Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 05-09-2013, 10:04 PM   #1
vikramaditya1986
Member#: 281606
2011 WRX
Hey All,
I've been mulling a well-rounded brake upgrade package for my 2011 WRX since well 2011 and seeing as how most aftermarket BBK systems seem to cost the moon and also given that I am not actually going to race my car, I've settled on the OEM red 4-pot front and 2-pot rear caliper setup that was originally sold on the 06-07 WRX. In addition to better heat and wear distribution, I've heard that they really improve braking feel (removes "spungy" pedal feel) and I also see that they add some nice bling . Here is the list of parts I have compiled so far, so please let me know if I've missed anything or if I have any incompatible parts on my list. I'd really like recommendations for good vendors for the all the parts I'm looking for; vendors - please feel free to respond to this post. My time-frame for the purchase is within the next month, and I'm more than happy to setup a sick bundle deal with a single vendor B-)
Here is my living parts list that I will update as required:
UPDATE : All the parts are in! Woohoo!! KNS Brakes fulfilled the entire order at a price matched to anywhere else I could buy the parts, and also guaranteed fitment on my car so that is a big bonus. Installation is now 7 days away ........
1a) Subaru OEM red 4-pot front brake calipers pair, each with 1 cross spring, 2 pad pins and 1 pin clip
1b) Subaru OEM red 2-pot rear brake calipers pair, each with 1 cross spring, 2 guide plates, 2 pad pins and 1 pin clip
2) KNS Conversion Caliper Brackets v2 (to mount rear 2-pots)
3a) Stoptech Powerslot '09+ WRX OEM-replacement slotted front rotors (same as BRZ rotor)
3b) Stoptech Powerslot '10+ LGT OEM-replacement slotted rear rotors (compatible with 2-pots and has the correct 190mm handbrake drum size. Same as BRZ rotor)
4) 1 lt ATE Super Blue DOT4 brake fluid
5a) Stoptech Street Performance front pads that are compatible with the front 4-pots
5b) Stoptech Street Performance rear pads that are compatible with the rear 2-pots
6) Goodridge braided SS brake lines for 08+ STi (rear 2-pot attachment point is easier to accomodate with the STi lines)
7) Grimmspeed Master Cylinder Brace
P.S. I had a question about brake balance with this setup and KNS implied that it is a non-issue and that this is a pretty solid brake setup. A perusal of the forums suggests that the brake bias actually shifts a little more to the rear, making the car a little more fun
Also thanks to fellow members ksgoh88, gsrcrxsi and chino_487 for valuable input to this list
vikramaditya1986 is offline   Reply With Quote
Old 05-10-2013, 02:16 PM   #2
ksgoh88
Member#: 95563
2009 WRX
Dark Gray Metalic
I've done this on my 09 WRX, and I got everything minus the calipers themselves from KNS. They are amazing people to work with and while their calipers won't be the cheapest, it's not far off. I bought the calipers from subaruenguineparts for slightly cheaper as I had Subaru Bucks at the time but they were missing the pin clips for the pads.
For the pads go with whatever fits those year calipers you're buying. I went with Hawk HPS and am not impressed honestly. More dust for roughly what feels like the same initial bite. Your parts list is almost exactly what I got. Overall you have the right idea.
ksgoh88 is offline   Reply With Quote
Old 05-10-2013, 06:55 PM   #3
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Originally Posted by vikramaditya1986 View Post
Hey All,
1a) Subaru OEM red 4-pot front brake calipers. Where can I buy these new with all the necessary hardware? (slide pins, silencing clips etc.).
1b) Subaru OEM red 2-pot rear brake calipers. Where can I buy these new with all the necessary hardware? (2 cross springs, 4 slide pins, Guide pins, pad pins, shims, all hardware etc.).
3a) Stoptech 09+ WRX OEM-replacement slotted front rotors
3b) Stoptech 09+ LGT OEM-replacement slotted rear rotors (compatible with 2-pots and has suitable handbrake drum size)
4) ATE Super Blue DOT4 brake fluid
5a) Stoptech Street Performance 09+ WRX front pads (do these work with the front 4-pots?)
5b) Stoptech Street Performance 09+ LGT rear pads (do these work with the rear 2-pots?)
6) Stoptech braided SS brake lines (do these work OK with the rear 2-pots?)
Also are there any issues with brake balance with this setup?
6. Order the rear brake lines for an STi. The mounting points are significantly different between the stock calipers and the 2pots. I was able to make the stock lines work, but it was a pain in the ass an I'll eventually replace them with the Sti lines.
gsrcrxsi is offline   Reply With Quote
Old 05-11-2013, 08:32 AM   #4
RM_2
Member#: 163058
'11 Impreza WRX SWP
'06 Saab 9-2X 2.5i NGM
Subscribed for later. This will come in handy.
RM_2 is offline   Reply With Quote
Old 05-11-2013, 11:07 AM   #5
chino_487
Member#: 209156
2009 WRX Sedan
SSM
chino_487 is offline   Reply With Quote
Old 05-11-2013, 01:11 PM   #6
vikramaditya1986
Member#: 281606
2011 WRX
chino_487 thanks for the link, I'd seen that thread before but it was good to re-read it. I've also come across this thread on ClubWRX on a full FHI 4-pot/2-pot swap:
http://www.clubwrx.net/forums/suspen...-2008-wrx.html
KNS were very prompt in responding to my inquiry with a quote. Now, decisions decisions......
Old 05-27-2013, 08:38 AM   #7
vikramaditya1986
Member#: 281606
2011 WRX
This seems like a really well-written and well-debated post on upgrading to 4-pot fronts on the 08+ WRX
http://forums.nasioc.com/forums/show...&highlight=pot
Old 06-09-2013, 12:18 PM   #8
vikramaditya1986
Member#: 281606
2011 WRX
This is what happens when I have a bunch a nice parts sitting around before I can put them on the car
Old 06-11-2013, 10:46 PM   #9
wrxman02
Member#: 24162
2014 Legacy 2.5i
2012 Impreza 2.0i
nice. why not just put them on.
wrxman02 is offline   Reply With Quote
Old 06-12-2013, 04:34 PM   #10
faSTI666
Member#: 180204
2005 FXT Stg II 1/2
SSM
I just did this same swap. Added sti mc. Honestly not much difference in brake feel but definately bites and stops better. KNS was awesome, I got everything from them execpt the calipers. I got mine from flatirons tuning in colorado. They had the best prices. Good guys over there who know thier stuff.
faSTI666 is offline   Reply With Quote
Old 09-22-2013, 08:47 AM   #11
vikramaditya1986
Member#: 281606
2011 WRX
A long-overdue picture!
Old 09-22-2013, 09:58 PM   #12
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Agreed that these look good and even though the front brakes are pretty much the same, the feel of the fixed caliper is much better than the sliders.
3b) Stoptech Powerslot 09+ LGT OEM-replacement slotted rear rotors (compatible with 2-pots and has suitable handbrake drum size. Same as BRZ rotor)
Just wanted to point out, since you seem to be keeping this list updated as a good reference, that the rear rotor should be a 10+ LGT(or 3.6R) rear rotor the 09 LGT was the earlier generation that rotor won't do.
Power6 is offline   Reply With Quote
Old 09-22-2013, 11:35 PM   #13
vikramaditya1986
Member#: 281606
2011 WRX
Yea the brake feel is substantially better now - not rock hard but better for sure. And the Stoptech street pads have great initial bite but they dust like crazy (and it really shows on my goldies :P).
Got it, I will update the LGT generation to '10+.
Old 09-23-2013, 12:16 PM   #14
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Well you may have framed in windows.....but we still got better brakes! Lol.
Rock on bro! The hawkeye brakes look bling up under there.
Good job.
Scoobiesdoobies is offline   Reply With Quote
Old 09-23-2013, 08:01 PM   #15
vikramaditya1986
Member#: 281606
2011 WRX
I know right - why didn't Subaru keep the 4/2 pots on the GR WRX?? I didn't even know the hawkeyes had them until I started looking for BBKs for my car and I stumbled across Subaru's finest (which of course isn't any bigger than stock GR brakes). I would have definitely optioned them on my car if they were offered as an SPT upgrade for like $1k or something like that, but I guess Subaru is too concerned about differentiating the STI from the WRX (though that didn't stop them from including the 4/2 pots as standard WRX equipment before). Well you know what - it gave me an excuse to mod my car! Thanks for the compliments! And IMHO frameless may be troublesome but it looks cool B-)
Old 09-25-2013, 03:34 AM   #16
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Yea if i was going to get a new car it would be a brand new sti limited hatch in white.
I like the new wrx but downgrading a few components vs the 06-07 to save on production cost.....come on. When you change something that was metal to plastic... You are taking 10 steps in the wrong direction.
The only upsides are the slight hp gains, slightly comfier inside (probably alot less rattling, vibrating and overall cab noise) and the framed in windows lol.
Pretty much everything you look for in a new car generally.
Old 09-25-2013, 10:28 PM   #17
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
In Subaru's defense, Americans have shown time and again they want competitive price over all. Look at the Legacy GT they couldn't move them off the lots after 06. The 4/2 pots are gone it seems Subaru phased those out, but the american WRX is and has almost always been missing a few pieces of equipment vs the rest of the world markets. That's just the way it is we have a very price competitive market.
I love me some fixed calipers though!
Old 09-25-2013, 11:04 PM   #18
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Il take a jdm or edm triptonic 4eat plz. Damn usdm simplistic bull****
Old 10-07-2013, 10:11 PM   #19
vikramaditya1986
Member#: 281606
2011 WRX
@Scoobiedoobies: Believe me if I could have forked out ~ $38 grand for an STi Limited I would have - all the goodies in the drivetrain, brakes and engine are easily worth the money. But unless you were doing a full-on trackday or driving at speed on loose surfaces, you'd have to be driving like an absolute maniac to outrun a WRX with modded suspension and some sporty brake pads and fluid. The badge prestige is nice, but there are other places I'd rather spend my spare $8 grand
@Power6: That's too bad for the rest of us who actually want nice hardware on models other than the STi. As I said, I would have opted for the 4/2 pots as an SPT upgrade if only they bothered to offer it. The only SPT performance mod of any kind available for the GR WRX is the catback which is supposedly inferior to yet more expensive than aftermarket parts from Invidia, Perrin etc. partly due to the 2.5" piping instead of 3.0" . And catbacks alone don't even get you any more power on a WRX :P
Old 10-07-2013, 11:15 PM   #20
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Yea 26g's after trade in and moderate interest is what my 06 limited rex cost.
The 4eat shifts very quick. i have no mods other than dspecs and 3" muffler delete, blew a 2012 wrx hatch away...before and after 4th gear lol.
But buttwarmers, leather and a moon roof are worth it. Adding a little bit of luxury to an ugly subaru world lol.
My extra 8 grand went to a badass mountain bike.
Old 10-09-2013, 01:00 PM   #21
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
That's too bad for the rest of us who actually want nice hardware on models other than the STi. As I said, I would have opted for the 4/2 pots as an SPT upgrade if only they bothered to offer it. The only SPT performance mod of any kind available for the GR WRX is the .catback which is supposedly inferior to yet more expensive than aftermarket parts from Invidia, Perrin etc. partly due to the 2.5" piping instead of 3.0" . And catbacks alone don't even get you any more power on a WRX :P
Yea it really is too bad. They didnt bother to offer it because they didnt bother to make it. They stuck with intake, exhaust, heat shields and keychains....
The spt is only "inferior" because it is aimed at increasing sound mainly while keeping the exact copy of stock back pressure numbers.
Most 3" exhausts arent needed until you get to 350hp and beyond.
Spt is factory made, the 4/2 pots are made by a vendor.
The brakes are a whole other story, and a whole other manufactuer....but agreed, weird they didnt keep the upgraded brakes for an upgraded chassis!!!!!
:Confused:
Old 10-15-2013, 01:07 AM   #22
04Silverex
Member#: 77322
2011 WRX
SSM
Please post more pics
04Silverex is offline   Reply With Quote
Old 11-01-2013, 10:55 PM   #23
Millsie
Member#: 368035
2011 WRX
SSM
Do these clear the stock +11 WRX wheels? I understand the brembos need a 3mm spacer, but I can only assume these are marginally smaller so will not require the space.
Millsie is offline   Reply With Quote
Old 11-02-2013, 08:04 PM   #24
DisrupTer911
Member#: 352071
2013 Impreza WRX
Dark Grey Pearl
thanks for the part list! Helps a ton!!
Fronts dont need brackets? Direct fitment?
I have a '13 WRX any differences?
DisrupTer911 is offline   Reply With Quote
Old 11-03-2013, 02:33 AM   #25
SW21MR2
Member#: 60135
2005 Kona Stink-E
There's likely no difference since there's no reason for Subaru to change the front hubs from the previous years.
Since your car is relatively new, it may be difficult to cross reference OEM replacement parts for front calipers. I'm sure if you select your car in one of the handful of online auto parts store website and search for front calipers, and cross reference it with the OEM replacement caliper for a 2008 WRX, it'll probably be the same part number.
SW21MR2 is offline   Reply With Quote
