Old 05-10-2013, 01:57 PM   #1
Rowrx11
Member#: 338312
Default 2011 wrx AFR problem
Hi ! First I ' am from Chile and i like very much this forum... and sorry for my inglish is bad.
Well my problem is my afr with stage 2 , custom tune 19 20 psi peak, down to 14 at the line. ... with the notebook connected my afr is fine! 10.6 - 11.1 max. But disconnect the notebook my afr is 11.7!! ( full boost ) why is that ?? Leaks ? Downpipe? Please help...
Mod list:
Process west tmic
Synapse diverter valve
Air intake k&n short ram
Downpipe tsudo bellmouth catless
Catback invidia n1 dual
Stock header wirh uppipe
Wideband innovate mtlx
Custom tune 19 20 psi Degree of advancement 18 20.
Please help me from Chile... subaru fan.
Rowrx11 is offline   Reply With Quote
Old 05-10-2013, 03:06 PM   #2
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
When you disconnect your notebook, what are you using to read the AFR 11.7?
Mr Wrex is offline   Reply With Quote
Old 05-10-2013, 04:19 PM   #3
Rowrx11
Member#: 338312
Wideband innovate mtlx ( air fuel ratio ) ...
Notebook connected ( 10.6 - 11.1 afr ) full boost
Notebook disconnect ( 11.7 afr ) full boost
This is strange...
11.7 afr is dangerous...
Old 05-10-2013, 04:26 PM   #4
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
11.7 is dangerous if the tune isn't set up for it, that's all up to the tuner.
Maybe the map isn't flashed in? hmm, kinda odd.
-Mark
APM Tuned is offline   Reply With Quote
Old 05-10-2013, 04:40 PM   #5
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Who did the custom tune? They need to be contacted immediately!
Cathexis is offline   Reply With Quote
Old 05-10-2013, 04:40 PM   #6
Rowrx11
Member#: 338312
-Mark
My tuner let it in 10.6 - 11.1 max.... But is strangely changed the number without the notebook.
Old 05-10-2013, 04:47 PM   #7
Rowrx11
Member#: 338312
We found five times to set up the afr.
And I set up the afr in 10.6-11.1 always..
Is the map? Or leaks ?
Old 05-10-2013, 04:57 PM   #8
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
I don't see how hooking up the AFR gauge to a notebook would actually change the actual AFR...
The wideband and it's 02 sensor is a "standalone" system, apart from the ECU. So whether a notebook is plugged into the gauge or not, should have no impact on the actual AFR's. I have a feeling it might be related to the gauge itself not reading correctly either when notebook is plugged in or when it is not. I hope it's not the first possibility.
findurpath is offline   Reply With Quote
Old 05-10-2013, 05:17 PM   #9
Rowrx11
Member#: 338312
It may that the gauge has problems be?
Old 05-10-2013, 06:07 PM   #10
findurpath
Member#: 277487
That's what I think. How would the ECU know if you've plugged a notebook/laptop into the Innovate gauge?
Old 05-10-2013, 06:41 PM   #11
Rowrx11
Member#: 338312
Is a good question.....
Old 05-10-2013, 07:10 PM   #12
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
It's the gauge. Try a different one.
dstroy is offline   Reply With Quote
Old 05-10-2013, 07:42 PM   #13
Rowrx11
Member#: 338312
I will buy a new one and tell how I was!
Thanks.
Old 05-10-2013, 09:27 PM   #14
skatinboarding
Member#: 233960
2011 WRX HATCH
WHITE
I know this might sound crazy but I had a similar problem with the innovate lc1 and it turned out to be a crappy grounding spot. Check your ground wires to the kit.
skatinboarding is offline   Reply With Quote
Old 05-10-2013, 10:03 PM   #15
Schikane
Member#: 337700
2013 WRX
Ice Silver Metallic
Try an AEM UEGO WB gauge. I have read a few posts about this same problem with Innovate LC-1 gauges.
Schikane is offline   Reply With Quote
Old 05-10-2013, 11:27 PM   #16
Rowrx11
Member#: 338312
Ok thanks !! Aem is my next upgrade... innovate never more.
Old 05-11-2013, 02:41 PM   #17
Rowrx11
Member#: 338312
Today i have this problem !! Brake sensor failure ?
But now disappeared... strange :/
https://www.youtube.com/watch?v=Plco...e_gdata_player
Read the comments.
Old 05-11-2013, 10:07 PM   #18
Rowrx11
Member#: 338312
Video with my afr full boost!
What do you thing ?
https://www.youtube.com/watch?v=x9wh...e_gdata_player
Old 05-12-2013, 12:05 PM   #19
darksurfing
Member#: 269804
1997 Sti V-Limited
rally blue
try using a different wideband and then let us know if the results are the same or not. I would do what you were told mate haha check if there's a crappy grounding spot. Often bad grounds have a lot to do with the car electronics. My dad's altezza was running like crap. But honestly, the car wouldnt even starts some times. And it ended up being a crappy grounding spot. Hopefully that your issue and not the wideband. Over here in chile these things are expensive. Take care mate see you around!
darksurfing is offline   Reply With Quote
Old 05-15-2013, 08:09 AM   #20
Rowrx11
Member#: 338312
What do you thing ?
What do you think?
Old 05-15-2013, 09:17 AM   #21
nismopowerdqg
Member#: 312580
2010 WRX [email protected]/334
Cobb/Torqued Performance
Innovate LC-1 is by far one of the worst gauges ive had, always go AEM UEGO. Switch gauges and go from there.
nismopowerdqg is offline   Reply With Quote
Old 05-15-2013, 09:19 AM   #22
nismopowerdqg
Member#: 312580
also is your bypass valve recirculating back into the intake like it should? or is it venting 50/50 into the atmosphere? it seems like it leans out a more between shifts.
Old 05-15-2013, 05:26 PM   #23
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
It should run richer between shifts since the air is being evacuated instead of plumbed back to the system if anything.
I wonder (very odd question), any way you have a ground loop that's causing electrical malfunctions when there is a draw from the laptop? It can also happen when there is too much voltage and the voltage drops from the lap top taking juice....
If by some chance you have electronics in the car like audio or whatever (aftermarket), ensuring that everything is routing as it should be might make a bit of a difference...just in case.
Other than that, look into a new gauge but my thought is that you're having the issue from electrical draw more than a gauge.
-Mark
Old 05-15-2013, 08:17 PM   #24
Rowrx11
Member#: 338312
Synapse Engineering Diverter Valve... in pull mode a+b . Is not a 50/50..
Old 05-15-2013, 11:03 PM   #25
Rowrx11
Member#: 338312
-Mark
Everything stock ( audio etc )
I will change the clock... I'm afraid to break the engine.
Gear 2 - 3 = 11.7
Gear 4 - 5 = 11.3 -4
Is danger i think.
