Old 05-10-2013, 05:44 PM   #1
manys
Member#: 265277
1999 Outback
Legacy
Default -15% idle issues. Electrical gremlins?
What's up guys. I'll keep it short and on point as much as I can so it's easier to grasp for people who want to help me. Please post any questions below.
I had the car for 6 months. It had SlowBoy Racing 725cc Bosch injectors since the beginning and I always had problems with idle fuel trims.
A trim was always deep into -%(-10/15%) when B,C,D were - 3%
Besides that car was running great. OL fueling was on target, no knock. Did plenty of WOT pulls.
Few days ago car suddenly started knocking in low load and finally started breaking up under low load, I got 'System Too Rich' code and all fuel trims went -15%. Few hours later car suddenly started running LEAN this time. Idled 17:1 AFR and all the trims became +10/15%. few hours later idle fixed itself back to 14.7:1 AFR but A,B,C trims stayed at +10/15% even after long driving.
I checked many things next day and was left with injectors. Replaced those 725cc with stock 420cc's. I set stock 02 WRX latencys and together with stock MAF scaling went to drive the car. Everything is like it was before so A trim -14%, b and C -3%. BUT, when I turn on the fan(NO A/C, ac belt is disconnected,just the fan) car revs up and A trim stabilizes to -5%. Looks like electrical problem?? That didn't happen with 725's
Car idling and fan turning on:
http://s1016.photobucket.com/user/pl...ef1e5.mp4.html
Obviously my 725 injectors started acting up but now I confirmed that I have some issue with my idle. Because second set of injectors is behaving the same way except that now there's another issue with crazy behavior when I turn on the fan.
My questions: what are the possible reasons for large negative fuel trims at idle only?? And how can a fan cause such crazy rev change and fueling change??
manys is offline   Reply With Quote
Old 05-11-2013, 07:51 AM   #2
Larimer
Member#: 205191
2006 Saab 9-2X Aero
Check for boost leaks.
Larimer is offline   Reply With Quote
Old 05-11-2013, 11:53 AM   #3
manys
Member#: 265277
1999 Outback
Legacy
I did, no leaks.
Old 05-11-2013, 04:17 PM   #4
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Maybe dirty or faulty IAC?
nmlittlebigman is offline   Reply With Quote
Old 05-12-2013, 06:30 PM   #5
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
If there are no leaks, bad MAF or bad O2 sensor. If you have a wideband simly force the car into OL and watch what it reads.
BlazeRex is offline   Reply With Quote
Old 05-12-2013, 07:21 PM   #6
manys
Member#: 265277
1999 Outback
Legacy
repaced a maf ,same thing. Replaced a fuel pressure regulator and checked fuel pressure. 37psi with vacuum hose connected and 47psi without.
o2 reads fine compared with wideband at idle. Remember I only have a problem at IDLE.
Maybe exhaust leak in the headers? MAF measured air would escape before reaching front o2 creating false rich condition so ecu would pull back fuel.
I also figured out that the rpm change caused by turning the fan on is normal with stock injectors. My brothers 07 wrx does the same thing.
Old 05-12-2013, 07:44 PM   #7
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Rescale maf? Clean iacv? Fuel flow scaling?
cosseywrx is offline   Reply With Quote
Old 05-12-2013, 08:49 PM   #8
manys
Member#: 265277
1999 Outback
Legacy
injectors,airbox, maf scaling,injector latencys/scaling are all stock so I shouldn't touch the maf or injector scaling to fix the problem.
I'll clean the iacv although I don't see the correlation to my problem.
Old 06-17-2013, 02:34 AM   #9
manys
Member#: 265277
1999 Outback
Legacy
I'll update the thread for people searching for answers for similar questions in the future:
I installed brand new five-o 1000cc's and was able to tune everything out pretty easily.
Idle, cruise, and D range are all nice now +/- 2%
