Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 05-13-2013, 01:01 PM   #1
GrimmSpeed
Vendor Sales Rating: (212)
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Default GrimmSpeed Top Mount Intercooler, Splitter, Y-Pipe - GROUP BUY
The Bar Has Been Raised.
http://www.grimmspeed.com/catalog/pr...roducts_id=264
Quick Specs
  • Smooth End Tank Internal Contours - Designed for maximum flow
  • Machined Throttle Body Connection - Tight, leak and trouble-free seal
  • Machined Flange Faces and Internal Bores - Maximum pressure-tightness and unrestricted flow
  • Permanent Mold End Tank Tooling and Casting - Allows much tighter tolerances and higher strength
  • Stainless Steel Threaded Inserts - Prevent cross-threading or damaged threads
  • High-Density, High-Flow Core - Optimizes heat transfer and minimizes flow restriction for turbo Subarus
  • Cleaned, Inspected and Sealed Prior to Shipping - Prevent Motor Damage Due To Foreign Matter
General Design
There are two primary considerations in the design of an intercooler: maximum heat transfer and minimum pressure drop. Fitment and quality are also critically important to ensure that the most safety-critical part of your turbo system is up to the task every time your foot hits the floor. We began by laser scanning an OEM TMIC to plot the mounting points and space claim in CAD with pinpoint accuracy. At the same time, we designed a custom bar and plate core with overall dimensions, fin density and fin types that would provide the insane heat transfer area we require with minimal flow restriction. With core size nailed down, we got to work designing end tanks that offered smooth flow, perfect fitment and even distribution of the hot charge air through the core. Countless revisions were tested in flow simulation before we finally found exactly the characteristics that we wanted. From there, 3D printed prototypes were used to confirm fitment and we began work on manufacturing details in preparation for verification testing and production. Rather than designing the largest possible core, or the core with the highest possible fin density, we created a well-rounded unit that’s designed specifically for Subaru’s making up to 550whp. That said, this particular core flows over 1500CFM and will support up to 575whp before it’s likely that a FMIC might be better suited for your system. To achieve the quality, tight tolerances, pressure tightness and strength that we required, permanent mold casting became our only option. Each and every end tank is cast from the same CNC machined mold, ensuring not just dimensionally perfect castings with an amazing surface finish, but also excellent repeatability. With this method, we have perfect control over both the internal and external contours of each casting. After casting, every single mating surface is precision machined for a leak-free finish and unbeatable fitment. We will not be outdone.
Assembly
We designed tabs to be laser cut and CNC bent from 5052 aluminum, selected for its ductile nature, to ensure that the bending and welding processes don’t compromise their integrity. These will accept your stock TMIC bushings and offer plenty of adjustability for tweaked brackets and ‘creative’ turbo setups. After each component has been inspected, our welder, Josh, hand TIGs each and every assembly. From there, each assembly is pressure tested to 50psi and is thoroughly cleaned before it’s sealed up and prepared for shipping.
Performance
Performance is a difficult subject when discussing a top mount intercooler that can be used in many different systems, often times with different goals. For that reason, we’ve opted to use primarily stock-turbo cars running higher boost. This particular 2.0l TD04 car is running full exhaust (catted), a GrimmSpeed EBCS and a 19psi tune. First, we tested pressure drop to ensure that our aggressive core design didn’t negate its benefits with a massive pressure drop. The graph below shows boost pressure in the inlet and outlet end tanks, as well as the calculated pressure drop and a trendline. Because of sampling rates and the nature of the pulsing system, you’ll notice that there is a great deal of noise in the pressure drop measurements. What’s important is the trend and as you can see, the maximum recorded pressure drop is just above .2psi with an average of around .1psi. Data was collected using a DATAQ DI-148U sampling a pair of ProSense pressure transmitters at 240Hz. Next, we tested inlet and outlet temperatures using a pair of K-type thermocouples and high frequency multimeters. What we found is that with a stock turbo, the OEM WRX TMIC seemed to keep up OK until 5000rpm or so. At that point, the efficiency of the OEM TMIC drops off very quickly. As we continued doing pulls, performance of the OEM TMIC degraded very quickly and the GrimmSpeed TMIC refused to budge, no matter how much heat we put into it. The graph below shows the post-IC temperatures for the GrimmSpeed TMIC vs. OEM TMIC. Note that these pulls were both completed after the same warm-up procedure (a series of shorter pulls) but before the OEM TMIC was fully heat soaked (and just about useless). Lastly, the third graph shows the calculated efficiency for these two top mounts based on temperatures taken from the same two pulls. This graph shows that even before it’s heat-soaked, efficiency of the OEM TMIC begins to drop significantly after 3800rpm.
Of course, power figures vary from dyno to dyno, and actual power gains will vary from setup to setup. What's shown below are the actual before and after power curves for a Forester XT running a vf39 on an auto trans. After the first pull, the car was tuned for the GrimmSpeed TMIC, to take advantage of the additional cooling and much lower pressure drop. At 5000rpm, the car picked up an additional 35whp and 37ftlb.
Fitments
  • 02-07 Subaru Impreza WRX
  • 04-13 Subaru Impreza STI
  • Subaru Forester XT
  • Baja Turbo
Y-Pipe
http://www.grimmspeed.com/catalog/pr...roducts_id=265
Tired of installing and reinstalling your OEM or aftermarket top mount intercooler using your awful, hard-plastic OEM y-pipe? Just bought an aftermarket or STI TMIC that require an STI y-pipe to fit? Want to stop choking your TMIC with those tiny plastic baffles? Maybe you're just looking to freshen up your engine bay with a touch of GrimmSpeed style. Well, there's something for everybody with the GrimmSpeed Y-Pipe Kit.
  • Two-Piece Casting - Allows for maximum adjustability/flexibility
  • Extra-Thick Flanges - Prevent heat and vibration from cracking casting
  • Machined Flanges - Ensures a leak-free seal, every time
  • 5-Ply High-Grade Silicone Couplers - Smooth interior to maximize airflow and minize restriction
  • Heat Resistant Reinforcement - Couplers keep their shap, even at high boost levels
  • Stainless Steel T-Bolt Clamps - Rust-proof construction with locking nuts
TMIC Splitter
http://www.grimmspeed.com/catalog/pr...roducts_id=263
Tired of popping your hood only to have that ugly OEM Splitter remind you of how badly it deprives your fancy TMIC of the cool, ambient air that it requires? Perhaps you’ve upgraded to an STI scoop and want to really make use of that extra air? Maybe you’ve already got an STI splitter but want to squeeze every ounce of performance out of your top mount. After frustrations with this and more, the GrimmSpeed team has the real solution. Well, five real solutions. Introducing, the GrimmSpeed TMIC Splitter lineup.
  • 70% Increase in flow capacity to your TMIC - Massively improves your TMIC's ability to remove heat
  • Maximizes TMIC Efficiency - Lowers TMIC outlet temps, enables more aggressive tuning
  • Designed for even flow distribution - Forces entire core work to cool the hot charge air
  • CAD design and simulation - Ensures both fitment and function
  • CNC Laser Cut 5052 Aluminum - Resists fatigue due to heat and vibration
  • Durable DuPont Black Powdercoat - Protects splitter with an OEM finish
  • Custom EPDM Rubber Gasket - Provides excellent seal and longevity
GROUP BUY INFORMATION
Closes on: Wednesday, May 29th, 11:59PM
Participant limit: TMIC - 50 Units, Splitter - Unlimited, Y-Pipe - Unlimited
Pricing structure: Flat rate
The Group buy will last 2 weeks.
Shipping of the intercoolers, splitters and y-pipes will begin as soon as payment is received. You'll receive shipping and payment instructions via PM starting next Monday. If you'd like to be added to the group buy list, please be sure to note color for your y-pipe kit and proper fitment for your splitter. All group buy orders will be tracked in a single list, but products are ordered and priced separately.
Normal MSRP: $679.99
Group Buy Pricing: $499.99
Thermal Dispersant Coating (Black): $69.99
Top Mount Intercooler Splitter
Normal MSRP: $199.99
Group Buy Pricing: $129.99
Top Mount Intercooler Y-Pipe Kit
Normal MSRP: $99.99
Group Buy Pricing: $79.99
SPECIAL NOTE: Installation of the GrimmSpeed TMIC requires the use of an STI fitment y-pipe. If you don't already have one, you should consider ours!
SPECIAL NOTE: As TMIC's are completed with welding and or thermal dispersant we will be contacting you individually with payment instructions.
Guys/Gals,
A little update is in order with the GB list, since I know it is a little confusing. I just added the 50th person to the GB list as far as TMIC's are concerned. Even though the number to the left of your screen name may be higher than 50, this is because not everyone on the list is purchasing a TMIC. It is pretty common that with most group buys, not everyone that sign up will end up paying for their TMIC. So with that kept in mind, we will continue to add another 15 people to the GB list, so that when people don't pay, you will receive the opportunity for that TMIC in the order you have been added. So in a nutshell, if you aren't and the list for a TMIC and you want to be, ask to be added, there is still a great chance you will be able to pick one up at this killer price!!
People that are above the 50 TMIC mark will be designated with a RED "PENDING" next to their name.
Lastly, I'd like to extend a big thank you to all of our product testers and the tuners that they've worked with. Special thanks to Chris and the good guys at Fastech Motorsports in Louisville, TN for helping us out with some dyno time last minute, as well as Justin at BuiltNotBoughtAutomotive for giving us some great feedback prior to release.
__________________
| AIM: GrimmSpd | Phone: 612-379-0000
Email:
GrimmSpeed is online now
Old 05-13-2013, 01:14 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Guys/Gals,
Once you have received payment instructions from us via PM, you will have up to 1 week to pay for your items (this is the starting date next to your items on the GB list). If your items are not paid for in this time line, we will extend the offer to people in the pending list.
PARTICIPANT LIST:
1. SAMPLE - TMIC, YPIPE (Black), SPLITTER (02-03 w/STI Scoop)
2. ihasacookie - TMIC (Black Thermal D), SPLITTER (06-07) PAID/SHIPPED
3. BoostinChick - TMIC (Black Thermal D), SPLITTER (06-07) PAID/SHIPPED
4. Jake Zimmerman - SPLITTER (06-07) PAID/SHIPPED
5. inthenameofweez - SPLITTER (04-05 w/ STI Scoop) (Payment instructions sent 5/17)
6. shiftnmadkwik - TMIC (Black Thermal D), YPIPE (Black) PAID/SHIPPED
7. Hah72215 - SPLITTER (02-03 w/ STI Scoop) PAID/SHIPPED
8. jblewis - SPLITTER (02-03 w/STI Scoop), YPIPE (Black) PAID/SHIPPED
9. bjf498 - TMIC, YPIPE (Black) PAID/SHIPPED
10. R L Newb - TMIC (Black Thermal D), SPLITTER (06-07), YPIPE (Black) PAID/SHIPPED
11. Duckee25RS - TMIC, YPIPE (Red) PAID/SHIPPED
12. Hold_Fast - SPLITTER (04-05 w/WRX Scoop) PAID/SHIPPED
13. TAJR02WRX - TMIC (Black Thermal D), YPIPE (Red)) PAID/SHIPPED
14. mekohler - TMIC (Black Thermal D), YPIPE (Black) PAID/SHIPPED
15. Crawlerado - TMIC (Black Thermal D), YPIPE (Black), SPLITTER (04-05 w/WRX Scoop) PAID/SHIPPED
16. Pooky - TMIC (Black Thermal D), YPIPE (Red), SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
17. ogboot - SPLITTER (02-03 w/STI Scoop), YPIPE (Red) PAID/SHIPPED]
18. emperorofdirt - TMIC (Black Thermal D), YPIPE (Black), SPLITTER (04-05 w/STI Scoop) PAID/SHIPPED
19. OBP WRX - TMIC (Black Thermal D), YPIPE (Black), SPLITTER (04-05 w/WRX Scoop) PAID/SHIPPED
20. julozas - YPIPE (Black) PAID/SHIPPED
21. arod35 - TMIC, YPIPE (need info) PAID/SHIPPED
22. FasterTony12STi - TMIC (Black Thermal D), YPIPE (Red) PAID/SHIPPED
23. allfours - YPIPE (Black) PAID/SHIPPED
24. Stickshift84 - TMIC (Black Thermal D), YPIPE (Black) PAID/SHIPPED
25. josedwrx - SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
26. KeevSTI - TMIC (Black Thermal D) PAID/SHIPPED
29. texaspancake - TMIC(Black Thermal D), YPIPE (Black), SPLITTER (02-03w/STI Scoop PAID/SHIPPED
30. krambte79 - TMIC (Black Thermal D) PAID/SHIPPED
31. zeroburnWRX - TMIC (Black Thermal D), YPIPE (Black), SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
32. iaredav1d - TMIC (Black Thermal D), YPIPE(Black PAID/SHIPPED
33. rexworx - TMIC (Black Thermal D), SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
34. superbike81 - TMIC, YPIPE (Red) PAID/SHIPPED
35. mgrantham - TMIC (Black Thermal D), SPLITTER (04-05 w/STI Scoop) PAID/SHIPPED
36. goneotb - TMIC (Black Thermal D), YPIPE (Black), SPLITTER (06-07) PAID/SHIPPED
37. Combat Chuck - TMIC PAID/SHIPPED
38. aamir1632 - TMIC (Black Thermal D), YPIPE (need info) PAID/SHIPPED
39. Ishart - TMIC (Black Thermal D), YPIPE (Blue) PAID/SHIPPED
40. castper - TMIC (Black Thermal D), SPLITTER (02-03 w/ STI Scoop) PAID/SHIPPED
41. MidOhioWRX - TMIC, SPLITTER (04-05 w/STI Scoop) PAID/SHIPPED
42. OptimusGrime - TMIC,(Black Thermal D), YPIPE (Blue), SPLITTER (04-05 w/WRX Scoop) PAID/SHIPPED
43. Whoracle - SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
44. depACE - TMIC (Black Thermal D), YPIPE (Black), SPLITTER (06-07) PAID/SHIPPED
45. Darshu - TMIC (Black Thermal D), YPIPE (Black) PAID/SHIPPED
46. s203.22b - TMIC (Black Thermal D), SPLITTER (04-05 w/STI Scoop) PAID/SHIPPED
47. nysti06 - SPLITTER (06-07) PAID/SHIPPED
48. THE_KING_04 - TMIC, (2x) YPIPE (Black) PAID/SHIPPED
49. Chris_M - TMIC, YPIPE (Black), SPLITTER (06-07) PAID/SHIPPED
50. nurplepurple336 - TMIC, YPIPE (Red) PAID/SHIPPED
51. wywrx - TMIC (Black Thermal D), YPIPE (Black) PAID/SHIPPED
54. abc123abc123 - TMIC (Black Thermal D), YPIPE (Black), SPLITTER (04-05 w/STI Scoop) PAID/SHIPPED
55. jeremy69 - TMIC (Black Thermal D), YPIPE (Black) PAID/SHIPPED
56. b3delta - SPLITTER (02-03 w/WRX Scoop) PAID/SHIPPED
57. ashleysaturdays - SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
58. lbobcat -TMIC (Black Thermal D), SPLITTER (04-05 w/STI Scoop) PAID/SHIPPED
59. bboytkc - YPIPE (Blue) PAID/SHIPPED
60. AFBeefcake - SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
62. kdc - TMIC, YPIPE (Black) PAID/SHIPPED
63. aaronlow - TMIC (Black Thermal D),Y-PIPE kit (Black), PAID/SHIPPED
64. boostedwebgeek.com - YPIPE (Black) (Payment instructions sent 5/23)
65. TXSoobieNoobie - SPLITTER (04-05 w/WRX Scoop) PAID/SHIPPED
66. Formula_15 - SPLITTER (02-03 w/WRX Scoop) PAID/SHIPPED
68. 2007st3 - TMIC PAID/SHIPPED
69. ketchupdtf - TMIC (Black Thermal D) PAID/SHIPPED
70. C_wagginz - TMIC (Black Thermal D), YPIPE (Blue) PAID/SHIPPED
71. lh0628 SPLITTER - TMIC (Black Thermal D), Y-PIPE kit (Red), SPLITTER (02-03w/STI Scoop) PAID/SHIPPED
72. McDreezy - YPIPE (Black), SPLITTER (06-07) (Payment instructions sent 5/23)
73. CAPTAIN1N5ANO - TMIC (Black Thermal D), SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
74. seest - TMIC, YPIPE (Black), SPLITTER (06-07) PAID/SHIPPED
75. lancelucas - TMIC, YPIPE (Black) PAID/SHIPPED
76. 0rk0 - TMIC,YPIPE (Red), SPLITTER (06-07) PAID/SHIPPED
77. TheHammer06 - TMIC, YPIPE (Black), SPLITTER (06-07) PAID/SHIPPED
78. 06 1929 - TMIC (Black Thermal D)(PENDING), SPLITTER (06-07) PAID/SHIPPED
79. texaspancake - SPLITTER (02-03w/STI Scoop) (Payment instructions sent 5/23)
80. k-dogg - SPLITTER (04-05 w/STI Scoop) PAID/SHIPPED
81. Apgaudet3521 - TMIC (Black Thermal D)(PENDING), YPIPE (Black) PAID/SHIPPED
83. kwycstix - TMIC (Black Thermal D)(PENDING), YPIPE (Black) PAID/SHIPPED
84. Rymaster - SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
86. DZXN - TMIC (PENDING), YPIPE (Black), SPLITTER (02-03 w/WRX Scoop) (Payment instructions sent 5/23)
87. WRX USA - TMIC (Black Thermal D)(PENDING), YPIPE (Black), SPLITTER (02-03 w/STI Scoop) (Payment instructions sent 5/23)
88. bluA32 - TMIC (Black Thermal D)(PENDING), YPIPE (Black), SPLITTER (04-05 w/STI Scoop) PAID/SHIPPED
89. SIRR98 - YPIPE (Blue), SPLITTER (02-03 w/STI Scoop) (Payment instructions sent 5/23)
90. talvai - TMIC (PENDING), YPIPE (Color?), SPLITTER (06/07) PAID/SHIPPED
93. Fierysun - TMIC (PENDING) (Payment instructions sent 5/23)
94. El Wray - TMIC (Black Thermal D)(PENDING) (Payment instructions sent 5/23)
95. micahaguas - YPIPE (Black) (Payment instructions sent 5/23)
96. Impreza77 - TMIC (PENDING), YPIPE (Red), SPLITTER (04-05 w/WRX Scoop) (Payment instructions sent 5/23)
97. thatsilver2.5rs - SPLITTER (04-05 w/WRX Scoop) PAID/SHIPPED
98. So-Ofxt - TMIC (Black Thermal D)(PENDING), YPIPE (Black) PAID/SHIPPED
99. RJ2120 - SPLITTER (06/07) (Payment instructions sent 5/23)
100. Rhazel1 - TMIC (PENDING), YPIPE (Red) PAID/SHIPPED
101. tekfoc - SPLITTER (06/07) PAID/SHIPPED
102. DaveE - YPIPE (Black) PAID/SHIPPED
103. edsonmassao - SPLITTER (06/07) PAID/SHIPPED
104. adizzle02 - SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
106. sabreofsd - SPLITTER (04-05 w/STI Scoop) PAID/SHIPPED
107. atomicfire - TMIC (Black Thermal D) SPLITTER (04-05 w/STI Scoop) YPIPE (Black) PAID/SHIPPED
108. lance07sti - TMIC (PENDING), SPLITTER (06/07)
109. NA STI - TMIC (PENDING), SPLITTER (06/07) PAID/SHIPPED
110. EltonKo - TMIC (PENDING), YPIPE (Black) PAID/SHIPPED
112. Gray2006Wagon - TMIC (Black Thermal D)(PENDING), YPIPE (Black), SPLITTER (06/07) PAID/SHIPPED
113. metal manny - TMIC (PENDING), YPIPE (Blue?), SPLITTER (06/07) (Payment instructions sent 5/23)
114. Iowa04wrx - TMIC (Black Thermal D)(PENDING) (Payment instructions sent 5/23)
115. chippy - TMIC (PENDING) (Payment instructions sent 5/23)
116. HammerSG - TMIC (Black Thermal D)(PENDING), YPIPE (Color?), SPLITTER (02-03 w/STI Scoop) (Payment instructions sent 5/23)
117. adjasont - TMIC (PENDING), YPIPE (Black), SPLITTER (06/07) PAID/SHIPPED
118. hulkmax - TMIC (Black Thermal D)(PENDING), YPIPE (Color?), SPLITTER (06/07) PAID/SHIPPED
118.5 - Ilovecugars - TMIC (PENDING)
119. doubleR - TMIC (Black Thermal D)(PENDING), YPIPE (Black) (Payment instructions sent 5/23)
120. jmcarlson - YPIPE (Color?) PAID/SHIPPED
121. omgawg - TMIC (PENDING), SPLITTER (06/07) PAID/SHIPPED
122. jton - YPIPE (Red), SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
123. Bob Elliott - TMIC (PENDING) (Payment instructions sent 5/23)
124. ricerocket123 - SPLITTER (04-05 w/STI Scoop) PAID/SHIPPED
125. Magnum626 - SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
126. guilty_619 - YPIPE (Black), SPLITTER (06/07) PAID/SHIPPED
127. igotone - TMIC (PENDING), YPIPE (Color?) (Payment instructions sent 5/23)
128. H22 - TMIC (Black Thermal D)(PENDING), YPIPE (Black), SPLITTER (04-05 w/WRX Scoop) (Payment instructions sent 6/4)
129. rmj - TMIC (Black Thermal D) (PENDING) (Payment instructions sent 6/4)
130. KenSekiguchi - TMIC (Black Thermal D)(PENDING), YPIPE (Black), SPLITTER (02-03 w/STI Scoop) (Payment instructions sent 6/4)
131. Wade-O - SPLITTER (02-03 w/STI Scoop) PAID/SHIPPED
132. kwan_1104 - TMIC (PENDING) (Payment instructions sent 6/4)
133. |Rev| - TMIC (PENDING) (Payment instructions sent 6/4)
134. dahgoose - TMIC (Black Thermal D (PENDING), YPIPE (Black), SPLITTER (06-07 w/STI Scoop) PAID/SHIPPED
135. sultan81 - TMIC (Black Thermal D)(PENDING) (Payment instructions sent 6/4)
136. STIGR-Wagon-Dad - TMIC (Black Thermal D)(PENDING), YPIPE (Black) PAID/SHIPPED
137. gongloo - TMIC (Black Thermal D)(PENDING) (Payment instructions sent 6/4)
138. gandharvas - SPLITTER (02-03 w/WRX Scoop) PAID/SHIPPED
139. illmatic - TMIC (PENDING), YPIPE (Black), SPLITTER (02-03 w/STI Scoop) (Payment instructions sent 6/4)
140. shagzrex - YPIPE (Black), SPLITTER (06-07) PAID/SHIPPED
141. warped_jer - YPIPE (Black) PAID/SHIPPED
142. jebjkey - SPLITTER (04-05 w/STI Scoop) PAID/SHIPPED
143. fallehero_08 - TMIC (PENDING)
144. BoostinChick - YPIPE (Black) PAID/SHIPPED
145. wiretap_MD - TMIC (Black Thermal D (PENDING), YPIPE (Black) PAID/SHIPPED
146. zeiss09 - SPLITTER (04-05 w/STI Scoop) (PENDING)
147. tortoiseawd - SPLITTER 02-03 w/ STI Scoop) PAID/SHIPPED
148. markesc - TMIC (PENDING), YPIPE (Black), SPLITTER (06-07) PAID/SHIPPED
149.
150.
__________________
Email:
Old 05-13-2013, 01:21 PM   #3
RallyImprezive
Member Sales Rating: (8)
Member#: 5476
2007 WRX UGM
2010 FXT
This is kinda not fair. I JUST got my credit card paid off...
Looks like great products at a very reasonable price!! I just might be able to convince my wife that I simply MUST have this stuff..
RallyImprezive is offline
Old 05-13-2013, 01:22 PM   #4
ihasacookie
Member Sales Rating: (4)
Member#: 236830
2007 STi
In for TMIC and 06-07 splitter!
ihasacookie is offline
Old 05-13-2013, 01:25 PM   #5
T-37
Member Sales Rating: (3)
Member#: 175624
1234 RIGHT IN THE
SYRUP
If I didn't already have a PW waiting to go on, I'd be #1 on that list. If I had known this was coming a few months ago I definitely would have waited...and to think that I thought development for the GD chassis was dying out! Awesome!
T-37 is online now
Old 05-13-2013, 01:28 PM   #6
Wrx Cruiser
Member Sales Rating: (1)
Member#: 277925
2011 WRX Stage 3
What about 08+ wrx?
Wrx Cruiser is offline
Old 05-13-2013, 01:30 PM   #7
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Thanks for the kind words. It's always easier to ask for forgiveness!
Right on! Thanks for getting the ball rolling!
We'll always have you guys covered!
Originally Posted by Wrx Cruiser View Post
What about 08+ wrx?
We're working on it! Now that these are released, going into production with the 08+ is our top priority!
Matt
Engineering
__________________
Email:
Old 05-13-2013, 01:31 PM   #8
Ryouske
Member Sales Rating: (9)
Member#: 283981
2011 WRX
Wicked Rare Blue
Y no 08+ WRX ;_;
Ryouske is offline
Old 05-13-2013, 01:32 PM   #9
BoostinChick
Member Sales Rating: (26)
Member#: 218971
2007 WRX
Is the y-pipe just a stockish replacement? What I am referring to is overall dimensions. I know with my current STi TMIC, I had to purchase another 90* elbow since I needed it to be a tad longer in order to fit my TD04H. Is this option available with the GS Y-pipe?
I'm in for a TMIC & Splitter for MY07 WRX!
BoostinChick is offline
Old 05-13-2013, 01:36 PM   #10
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I'm in for a TMIC for MY07 WRX!
The y-pipe is an STI fitment but with added adjustability. I left both ends of the 90 degree coupler (it actually has a small jog in it as well, not just 90deg) a touch long for different setups.
Awesome! Let us know if you'd like to add the y-pipe.
Matt
Engineering
__________________
Email:
Old 05-13-2013, 01:36 PM   #11
olazy
Member Sales Rating: (5)
Member#: 263322
2011 WRX Limited
WRBP
Matt
Engineering
whew, more time to save up
olazy is offline
Old 05-13-2013, 01:37 PM   #12
BoostinChick
Member#: 218971
2007 WRX
^ ^ Add me for the splitter as well, please!
Old 05-13-2013, 01:42 PM   #13
Jake Zimmerman
Member#: 244974
06 STi
Is the splitter STi IC sprayer compatible?
Jake Zimmerman is offline
Old 05-13-2013, 01:43 PM   #14
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Good question! I'll get that added to the website. The splitters each have three STI intercooler sprayer ports. You've got options!
Matt
Engineering
__________________
Email:
Old 05-13-2013, 01:43 PM   #15
BoostinChick
Member#: 218971
2007 WRX
From their link - http://www.grimmspeed.com/catalog/pr...roducts_id=263
In addition, we’ve added features for up to three intercooler water sprayers to each splitter.
Old 05-13-2013, 01:44 PM   #16
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Return the PW for refund because it "doesn't meet your expectations of fitment and quality." Then get on the list.
Old 05-13-2013, 01:45 PM   #17
Jake Zimmerman
Member#: 244974
06 STi
Matt
Engineering
Awesome. Sign me up for an 06-07 impreza splitter :tup:
Old 05-13-2013, 01:45 PM   #18
inthenameofweez
Member Sales Rating: (14)
Member#: 201374
2004 Broken down
slow ass wagon
In for 04-05 STi splitter.
inthenameofweez is offline
Old 05-13-2013, 01:46 PM   #19
eastwoodsn352
Member Sales Rating: (6)
Member#: 334442
2008 WRX STI
^ And the 08+ STI
Edit: answered as I made post...sorry!
eastwoodsn352 is offline
Old 05-13-2013, 01:51 PM   #20
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Old 05-13-2013, 01:54 PM   #21
shiftnmadkwik
Member#: 83870
2005 WRX
Default casting of y-pipe?
How do the inside of the y-pipe castings look? Any benefit to having these parts ported/coated by Grimmspeed?
In for intercooler and y-pipe kit.
shiftnmadkwik is offline
Old 05-13-2013, 01:56 PM   #22
Kingnothing616
Member#: 277507
As soon as you have one for an '11, I'm in!
Kingnothing616 is offline
Old 05-13-2013, 01:56 PM   #23
Hah72215
Member#: 77815
2002 WRX WAGON
Please add me to the list for the 02-03 splitter with sti scoop. Thanks!
Hah72215 is offline
Old 05-13-2013, 01:57 PM   #24
jblewis
Member#: 22768
04 2.5 XT
YPIPE-BLK, SPLITTER-02-03 w/STI Scoop ('04 FXT 5MT w/ TD04)
Can pick up in person.
jblewis is offline
Old 05-13-2013, 01:57 PM   #25
Enraged
Member#: 304096
2005 Legacy GT
would these fit the 05-09 Legacy?
Enraged is offline
Closed Thread
